Everything posted by 1004ron
As long as you're happy to sacrifice filtration for that sound all is good.
2013 4 cylinder stalling and not starting
1004ron replied to Justin Israelson's topic in 2.0L EcoBoost
With the described symptoms it's unlikely that there's no stored error codes. What are you using to read codes? I have found a good OBD2 interface with ForscanLite to be reliable. Also, keep it to one thread. -
The engine cannot ingest more air than the OEM filter can flow, so the main selling point of the K&N is mute.
Drain and fill is what I do every +- 50K miles. 2015 Ford Edge Sport 2.7 FWD Transmission (transaxle) Service - Transaxle (FWD) - Ford Edge Forum
- 2 replies
- transmission
- fluid change
- (and 2 more)
Looks like Nibs3675 has abandoned his thread - last seen on 22 Feb 2023. Serves little value and should probably go in the trash.
Your Sport is in perfect cosmetic condition, but for me the performance modifications would exclude it if I was in the market for one. There might be a few more folks out there who are like me that wouldn't consider a modified used vehicle, so it might be worth a try advertising it without mention of the MOD's or that its been raced, just to draw attention of prospective buyers.
New 16-19 ebony leather driver seat back and bottom replacement covers
1004ron replied to Summers22's topic in Classifieds
Thats a superb deal and I would have jumped on it but my seats have the suede inserts. -
As far as I can tell those that have had their oil pans done correctly as per the procedure haven't had any issues, so I question the skills of your dealership. It might also be a good idea to contact Ford Customer service and let them know your concerns and possibly with that on record it might be covered if it leaked again, and I'd definitely take a different dealership.
Group 65 Battery in 2nd Gen Possible?
1004ron replied to omar302's topic in 2015+ Edge & MKX Generation II
@omar302 Its been a while - what battery did you end up installing? -
Group 65 Battery in 2nd Gen Possible? - 2015+ Edge & MKX Generation II - Ford Edge Forum
2020 SEL AWD RDU Fluid - Redline lightweight Shockproof work?
1004ron replied to lildisco's topic in All Wheel Drive (AWD)
I've got 90K miles on mine and have changed the RDU oil three times and the above mentioned method extracts just about the full volume of oil. The last fill I used Amsoil SEVERE GEAR® 75W-90 My RDU oil has looked like new each time. -
1004ron replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Actually a good sign that the catch can is working well. -
That's what mine looks like and even more of it in the cold months. -
Give the search feature a try. -
GSB 23-7003 - Various Vehicles - Paint And Bumper Concern Analysis
1004ron replied to Haz's topic in Recalls, TSBs & Warranty
My 2017 Sport paint is completely etched from the acid rain from the power plant that I work at. I'm very surprised that there's any form of warranty on this - need to look what the fine print says about this. -
Welcome. What's the mileage? What's the service history - oil change interval - what oil used - what oil filter used - who does the oil changes? I would trust the oil pressure switch is functioning correctly unless proven otherwise by a gauge.
Fluttering Noise from Undercarriage and Dashboad Rattle
1004ron replied to CCMAYES72's topic in Brakes, Chassis & Suspension
No, not a "pushnut" - its one of these: Self-Threading Nuts - Washer Type https://www.amazon.com/Dorman-Help-45384-Thread-Cutting/dp/B000COCTDK/ref=sr_1_3?crid=1P1YYZBZNSRU2&keywords=Thread+Cutting+Nut&qid=1676246531&s=industrial&sprefix=thread+cutting+nut%2Cindustrial%2C121&sr=1-3- 90 replies
- dash noise
- dash rattle
(and 4 more)
They're pressed steel nuts. Maybe @Haz can identify them for you and where they can be bought.- 90 replies
- dash noise
- dash rattle
(and 4 more)
Need Help -- 2008 Limited Battery Drain Problem
1004ron replied to Peveto's topic in 2008 Edge & MKX
I'd get that new battery load tested. -
What's the mileage? What's the oil change history - oil used and miles between changes ?
What are you using to read the codes? - I ask because an app that I trusted didn't read codes that were present and showed using ForscanLite. You could try a shot of starter fluid - that would identify if it was a fuel delivery issue and if it has spark.
Attention - there's an uptick in accounts being hacked
1004ron replied to 1004ron's topic in Forum Help & Site Suggestions
Hacker with Russian IP address has been busy today, hacked a couple of accounts of members that joined back in 2012.
