1004ron
    121
Everything posted by 1004ron
  1. I would start by reading the stored error codes using Forscan or other device that's know to have the capabilities with Ford. After that I'd use the scanner monitor the O2 sensors paying particular attention to when the engine is warmed and the A/F ratio switches from Open Loop to Closed Loop.
  2. See what I was getting at with regards the scanner? I would start by checking out the transmission selector and linkages, and the connector to the transmission range switch - if that all checks out good then get a wiring diagram and confirm the range switch is giving the correct output at its connector when selecting each gear position. My model had a recall due to issues with the synthetic bush connecting the cable to the transmission range lever - wonder if that's good on yours. Maybe @Haz could help with the wiring diagram.
  3. Safelite replaced my windshield today and did a great job. The only trim removed was the plastic cover at the bottom edge of the windshield. The spec label on the lower right corner is exactly the same as the original windshield. They took it for a 10 minute drive with their calibration device - I never use the lane guidance but tried it on the drive home and it works as it always has.
  4. I wouldn't be taking any advice from that Scotty fool. The BlueDriver is a good OBD2 adapter, so that adapter with ForescanLite (Free) will reliably read the codes, which will most certainly be there based on the symptoms you describe.
  5. Agreed, reputable, but if it were me I'd scan it with Forscan or Forescan Lite. That's my recommendation based on personal experience.
  6. I doubt that kerosene would do much for the sludge build-up on the oil pump suction strainer and the screens on the VVT control valves if the engine isn't run. Most folks are very wary of using an engine flushing product, but I think when an engine has been allowed to sludge up like this it may be the only option - if you do this plan to do a good few short interval oil & filter changes.
  7. PTU drain plug drill and tap - Page 10 - All Wheel Drive (AWD) - Ford Edge Forum Any quality fluid that meets or exceeds the specs in your owners manual is suitable for your Engine, Transmission, RDU (Diff) and PTU. I use Ford fluid for the Trans, Mobil 1 for the Engine, and Amsoil for the PTU and RDU. Transmission Fluid Replace? - Transaxle (FWD) - Ford Edge Forum Try the forum URL in Google with key words.
  8. Still getting errors. User "warnerro_edge201" doesn't show on a member search. An error occurred (500 Error) We're sorry, but a temporary technical error has occurred which means we cannot display this site right now. User warnerro_edge201 already has more than 'max_user_connections' active connections You can try again by clicking the button below, or try again later. Try again Fatal error: Uncaught IPS\Db\Exception: User warnerro_edge201 already has more than 'max_user_connections' active connections in /home/warnerro/public_html/fordedgeforum.com/system/Db/Db.php:205 Stack trace: #0 /home/warnerro/public_html/fordedgeforum.com/system/Db/Db.php(118): IPS\_Db::_establishConnection('IPS\\Db', Array, true) #1 /home/warnerro/public_html/fordedgeforum.com/system/Session/Store/Database.php(77): IPS\_Db::i() #2 /home/warnerro/public_html/fordedgeforum.com/system/Session/Front.php(283): IPS\Session\Store\_Database->updateSession(Array) #3 [internal function]: IPS\Session\_Front->write('60fbcf32ea62466...', '') #4 {main} thrown in /home/warnerro/public_html/fordedgeforum.com/system/Db/Db.php on line 205
  9. This forum is the slowest out of all the ones I frequent and at times, like this morning it just fails.
  10. If you're really confident that the VVT equipment is good, then its likely the timing has jumped. Checking the resistance of the VVT valves isn't confirmation that they're working. Next step would be to use a scanner to verify the Crank / Cam timing correlation.
  11. What's the oil change history - oil change interval, oil used and oil filter? Have you checked the Variable Valve Timing oil control valves? HOW TO FIX CODE P0015, CODE P0016, CODE P0017 ANY CAR, ENGINE LIGHT ON - YouTube
  12. @Haz thanks very much for that. Any chance you have instructions for removing all the trim, glass, etc. and re-installation?
  13. @Haz any chance you have instructions for the windshield replacement? Of course I'll be watching the whole process.
  14. On Monday a stone chipped my windshield and this morning Safelite came to my work place to do the chip repair. The Tech had issues with his equipment and the end result is it now looks worse than it did before his repair attempt, and because you only get on shot at the repair it now needs a new windshield. I spoke with the dealership service manager and he said that Safelite have done windshield replacements and performed the required calibrations etc. Safelite tell me that there's no deductible in Kentucky. Tomorrow I'll make an appointment for them to order the replacement and schedule the installation. Anything I should watch for with this job? Attached photo is the damage after the repair attempt.
  15. 1004ron
    SLOW acceleration
    My bad, I didn't notice that. What did you use to scan for codes?
  16. 1004ron
    SLOW acceleration
    Best get the stored error codes read.
  17. Doubt Admin are going to help - I experimented with image size and file size until the photos posted, but cant recall the specific settings, so if you experiment and find what works please update this thread.
  18. Have you investigated to find the cause?
  19. Welcome. Post photos of your F150
  20. I suggest changing the Forscan display option and select what @omar302 suggested.
  21. Any chance you can tell us what code readers they use?
  22. As long as you're happy to sacrifice filtration for that sound all is good.
  23. With the described symptoms it's unlikely that there's no stored error codes. What are you using to read codes? I have found a good OBD2 interface with ForscanLite to be reliable. Also, keep it to one thread.
  24. The engine cannot ingest more air than the OEM filter can flow, so the main selling point of the K&N is mute.
