Everything posted by 1004ron
When I changed spark plugs on my wife's 3.7L Mustang I found oil in the intake - I replaced the PCV valve and installed a catch-can and no longer get oil in the intake. I doubt that the engine braking would cause this.
Best way to get scratch out of console?
1004ron replied to gibbey531's topic in Appearance - Detailing, Wash & Wax
I don't believe there's a way to remove it, but I use 303 aerospace protectant to mask it. -
Windshield Replacement
1004ron replied to 1004ron's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I stopped in at their shop on Friday and the identified an error made by the installation tech - they confirmed that the windshield will be removed and didn't do so on Friday because they didn't have stock of mine - the senior tech says that they usually install a complete new one because during removal it often breaks and the time to clean the sealant off the old one also makes it cost effective to use a new one. -
A few days after the windshield install I went through the car wash and when I got home I saw a little water on the drivers side mat, so went through the car was again this afternoon checking the mats are all dry before - I have a leak. Will call tomorrow to schedule the fix - wonder if it means removal to reseal. -
Two threads merged - one was in "Off topic Lounge". Here's a direct link for you to add your vehicle details to your signature: Settings - Ford Edge Forum
Can nav be added to a 2022 Edge with Sync 4A?
1004ron replied to JohnCT's topic in Audio, Backup, Navigation & SYNC
I'm not an expert on this but believe that it is possible to add NAV but it would need a new APIM and GPS antenna - this is what I did on my wife's 2015 Mustang. I can PM you the contact for the person that sold me all the Ford hardware needed, all configured. On my 2017 Edge Sport I no longer use the in dash NAV after getting a wireless Carplay device - Waze is all I use for navigation. -
I would start by reading the stored error codes using Forscan or other device that's know to have the capabilities with Ford. After that I'd use the scanner monitor the O2 sensors paying particular attention to when the engine is warmed and the A/F ratio switches from Open Loop to Closed Loop.
See what I was getting at with regards the scanner? I would start by checking out the transmission selector and linkages, and the connector to the transmission range switch - if that all checks out good then get a wiring diagram and confirm the range switch is giving the correct output at its connector when selecting each gear position. My model had a recall due to issues with the synthetic bush connecting the cable to the transmission range lever - wonder if that's good on yours. Maybe @Haz could help with the wiring diagram.
Safelite replaced my windshield today and did a great job. The only trim removed was the plastic cover at the bottom edge of the windshield. The spec label on the lower right corner is exactly the same as the original windshield. They took it for a 10 minute drive with their calibration device - I never use the lane guidance but tried it on the drive home and it works as it always has. -
I wouldn't be taking any advice from that Scotty fool. The BlueDriver is a good OBD2 adapter, so that adapter with ForescanLite (Free) will reliably read the codes, which will most certainly be there based on the symptoms you describe.
Agreed, reputable, but if it were me I'd scan it with Forscan or Forescan Lite. That's my recommendation based on personal experience.
What scanner is that?
I doubt that kerosene would do much for the sludge build-up on the oil pump suction strainer and the screens on the VVT control valves if the engine isn't run. Most folks are very wary of using an engine flushing product, but I think when an engine has been allowed to sludge up like this it may be the only option - if you do this plan to do a good few short interval oil & filter changes.
PTU drain plug drill and tap - Page 10 - All Wheel Drive (AWD) - Ford Edge Forum Any quality fluid that meets or exceeds the specs in your owners manual is suitable for your Engine, Transmission, RDU (Diff) and PTU. I use Ford fluid for the Trans, Mobil 1 for the Engine, and Amsoil for the PTU and RDU. Transmission Fluid Replace? - Transaxle (FWD) - Ford Edge Forum Try the forum URL in Google with key words.
Ford Edge Forum: WHAT HAPPENED?
1004ron replied to robertlane's topic in Forum Help & Site Suggestions
Still getting errors. User "warnerro_edge201" doesn't show on a member search. An error occurred (500 Error) We're sorry, but a temporary technical error has occurred which means we cannot display this site right now. User warnerro_edge201 already has more than 'max_user_connections' active connections You can try again by clicking the button below, or try again later. Try again Fatal error: Uncaught IPS\Db\Exception: User warnerro_edge201 already has more than 'max_user_connections' active connections in /home/warnerro/public_html/fordedgeforum.com/system/Db/Db.php:205 Stack trace: #0 /home/warnerro/public_html/fordedgeforum.com/system/Db/Db.php(118): IPS\_Db::_establishConnection('IPS\\Db', Array, true) #1 /home/warnerro/public_html/fordedgeforum.com/system/Session/Store/Database.php(77): IPS\_Db::i() #2 /home/warnerro/public_html/fordedgeforum.com/system/Session/Front.php(283): IPS\Session\Store\_Database->updateSession(Array) #3 [internal function]: IPS\Session\_Front->write('60fbcf32ea62466...', '') #4 {main} thrown in /home/warnerro/public_html/fordedgeforum.com/system/Db/Db.php on line 205 -
This forum is the slowest out of all the ones I frequent and at times, like this morning it just fails. -
Started Edge and CEL shows 4 codes P0011, P0016, P0018, P0021
1004ron replied to CrossBnes3129's topic in 2010 Edge & MKX
If you're really confident that the VVT equipment is good, then its likely the timing has jumped. Checking the resistance of the VVT valves isn't confirmation that they're working. Next step would be to use a scanner to verify the Crank / Cam timing correlation. -
What's the oil change history - oil change interval, oil used and oil filter? Have you checked the Variable Valve Timing oil control valves? HOW TO FIX CODE P0015, CODE P0016, CODE P0017 ANY CAR, ENGINE LIGHT ON - YouTube -
@Haz thanks very much for that. Any chance you have instructions for removing all the trim, glass, etc. and re-installation? -
@Haz any chance you have instructions for the windshield replacement? Of course I'll be watching the whole process. -
On Monday a stone chipped my windshield and this morning Safelite came to my work place to do the chip repair. The Tech had issues with his equipment and the end result is it now looks worse than it did before his repair attempt, and because you only get on shot at the repair it now needs a new windshield. I spoke with the dealership service manager and he said that Safelite have done windshield replacements and performed the required calibrations etc. Safelite tell me that there's no deductible in Kentucky. Tomorrow I'll make an appointment for them to order the replacement and schedule the installation. Anything I should watch for with this job? Attached photo is the damage after the repair attempt.
My bad, I didn't notice that. What did you use to scan for codes?
Best get the stored error codes read.
Doubt Admin are going to help - I experimented with image size and file size until the photos posted, but cant recall the specific settings, so if you experiment and find what works please update this thread.
