1004ron
    168
Everything posted by 1004ron
  1. We have had these mats in my wife's BMW X5 for one year and like them very much - a week ago while cleaning my Edge Sport I noticed that the drivers mat had worn through where my heel rests and allowed snow and water to wet the carpet. My Sport came with rubber mats which were OK, but nowhere near as nice as the ones that were delivered today. They fit way better than the Ford ones, look far better and are much easier to clean. https://3dmatsusa.com/collections/custom-fit-car-floor-liners/products/kagu-floor-liner?model=MjAxN0BGT1JEQEVER0U= SKU L1FR09301509 Coupon Code for $10 off - GJEEBS3D10
  2. Best get the stored error/fault codes read and that should offer some direction - I'd guess that it's the evap system, but reading the codes is the way to go.
  3. Agree, if those were holes, you'd have an issue going through a car wash - drain holes are typically at a low point and protected against water jets.
  4. The administrators finally responded and created the subsection - 2019-Current Edge & Nautilius
  5. Generally I use OEM but for this being a non critical device and two OEM ones didn't last as long as I'd expect, I went with the DORMAN 994073 at around half the price from RockAuto.com.
  6. CEL triggered again on the way home from work. Gas tank filler cap seal is good. Just read codes and installed a 3rd party evap valve. First evap valve replacement in Oct 2021 at 71K miles and second at 110K miles. ---------------- ===PCM DTC P144C:00-EC=== Code: P144C - EVAP System Purge Flow Performance During Boost Status: - DTC Maturing - Intermittent at Time of Request - Malfunction Indicator Lamp is On for this DTC - Test not complete Module: Powertrain Control Module Freeze Frame #1: Freeze Frame #2: -EVENT_TIME: 254234679 s (Thu Jan 30 16:15:12 2025) - Event time -TOTAL_DISTANCE: 177194 km - Total Distance -FUELSYS: Closed Loop - Fuel System Status (Open/Closed Loop) -LOAD: 62.35 % - Calculated Load Value -ECT: 93 °C - Engine coolant temperature -SHRTFT1: -3.12 % - Short term fuel trim 1 -LONGFT1: 7.81 % - Long term fuel trim 1 -SHRTFT2: -2.34 % - Short term fuel trim 2 -LONGFT2: 8.59 % - Long term fuel trim 2 -MAP: 144.0 kPa - Manifold absolute pressure sensor -RPM: 2784 1/min - Engine Revolutions Per Minute -VSS: 118.0 km/h - Vehicle Speed -SPARKADV: 10.00 ° - Spark Advance -IAT: 12 °C - Intake Air Temperature -RUNTM: 1429 s - Time Since Engine Start -EVAP_PCT: 0.00 % - Commanded Evaporative Purge -FLI: 59.61 % - Fuel Level -BARO: 98.0 kPa - Barometric pressure -VPWR: 13.01 V - Control Module Voltage -TP_REL: 34.12 % - Relative Throttle Position -TAC_PCT: 44.31 % - Commanded Throttle Actuator Control -RPMDSD: 600 1/min - Desired Idle Speed RPM -O2S12: 0.66 V - Heated Exhaust Gas Oxygen Sensor (bank 1, sensor 2) -O2S22: 0.50 V - Heated Exhaust Gas Oxygen Sensor (bank 2, sensor 2) -TQ_CNTRL: None Requested - Torque Control Requested -ENGOFF_TIMER: 32784 s - Timer since Engine Off -APP_FLT: No Fault - Accelerator Pedal Position Sensor Status -MISFIRE: No - Engine Misfire currently detected -IAT_F: No Fault - Inlet Air Temperature Sensor Status -ETC_TRIM_LRN: Yes - Throttle Angle Offset has Learned -TP_F: No Fault - Throttle Position Sensor Status -MP_LRN: Yes - Misfire Profile Correction Learned -MAF_F: No Fault - Mass Air Flow Sensor Status -MAP_F: No Fault - Manifold Absolute Pressure Sensor Status -APP1: 1.92 V - Accelerator pedal position sensor 1 -APP2: 0.96 V - Accelerator pedal position sensor 2 -TP1: 2.84 V - Throttle Position Sensor 1 -TP2: 2.18 V - Throttle Position Sensor 2 -GEAR: 5 - Gear Commanded -GEAR_OSC: 5 - Gear Command by Output State Control -TSS_SRC: 2771 1/min - Actual Turbine Shaft Speed -OSS_SRC: 2770 1/min - Actual Output Shaft Speed -TFT: 63 °C - Transmission Fluid Temperature -TR: Drive/OverDrive - Transmission range ===END PCM DTC=== ===OBDII DTC P144C-C=== Code: P144C - EVAP System Purge Flow Performance During Boost Status: - Confirmed - malfunction is confirmed
  7. Where did you hear this? I don't know about Android, but IOS (FORScanLite) and Windows is still available.
  8. Looks like USPS is on a go slow strike in my area - takes about a week to get past my local distribution center which up until now was one day, max two days. Installed last night and its back to normal operation. The butchered plastic covers also have some odd grey bonding which must have been done by SafeLite. Unlike some of the YT videos I've seen, the gel actually covers the lens, and the gel on the old one was covered in dust/debris.
  9. Yesterday on my way home from work with just over 1/4 tank of gas the check engine light came on. Stopped to gas up at Costco later and read the codes and got P144C - cleared codes and it hasn't reappeared. Looking to replace the evap purge valve for the second time on my Edge. Considering a Dorman replacement this time - $40 on RockAuto.com 2017 FORD EDGE 2.7L V6 Turbocharged Vapor Canister Purge Valve / Solenoid | RockAuto
  10. clay0708 you could just pull the hose and add coolant to bring it back to normal working level, but is it due for complete replacement on mileage/age? Also, check to see if yours qualifies for the upgraded transmission linkage bush. .
  11. On my wife's 2015 Mustang I went with OEM Ford components to upgrade it to Sync3 which included the larger screen at a cost of around $1,300 and more recently for my wife's BMW X5, that replaced the Mustang, I went with OEM components at a cost of $1,700, and if faced with the choice I'd do the same again.
  12. I usually buy from RockAuto.com but they don't stock this type of part. eBay I find is typically the highest price these days or fakes. I was right, the Ford place I bought from drop-ships using RevolutionParts - Sell OEM Parts and Accessories - won't be using them again.
