Everything posted by 1004ron
Doubt you're going to hear from the OP any time soon. @Adawg Joined: September 6, 2019 Last visited: January 27, 2023
19’ Ford Edge Sport SCT Livewire (for sale)
1004ron replied to Dieselboy's topic in Accessories & Modifications
What price? -
@TinaV713 Welcome - give the forum search a try for your next query. Please consider adding your location and Model/Year to your profile signature - https://www.fordedgeforum.com/settings/signature/
Not sure what to make of this - are you referring to the stud size? I use a 21mm six-sided deep socket and my original style lug nuts are in perfect condition - not long ago Discount Tire installed a tires and unlike my local Ford dealership they did not use an impact wrench to remove or tighten the lug nuts.
About two years later I got this done - I also painted the chrome part black. Used the satin black with satin clear coat.
There's an abundance of reports on here of the 3rd party units not functioning and folks had to cough up and go with OEM.
OEM or 3rd Party fans and controller?
The symptoms associated with P0456 is rough idle, with no other performance issues, so the rough acceleration is something else. When I replaced my evap purge valve on my 2.7L the service manager mentioned that the code is most often resolved with the replacement of this valve, but a very limited number have needed to replace the canister vent vale near the rear axle. The P0456 points to the evap purge valve typically mounted close to or on top of the engine, as is the case with my 2.7L, but could also be the canister vent valve or poor sealing gas cap. How's the coolant level - losing any coolant? Maybe @Haz can help with more info.
Questions about brakes on a 2020 ST
1004ron replied to gwbmcse's topic in Brakes, Chassis & Suspension
Had two sets of drilled & slotted rotors and now very happy with the solid rotors. Brake Pads & Rotor Replacement Option for Edge Sport (2016-2018) - Page 3 - Brakes, Chassis & Suspension - Ford Edge Forum -
fan speed Fan Speed Control Issue - Fuse Box
1004ron replied to Pete61's topic in Interior, A.C., Heat, Interior Trim
If you plan too stick around best you add your Model/Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ -
Is that possible? - the turbo is upstream of the CAT in the exhaust gas flow path.
What model/year/engine ? Please add your vehicle details and location to your profile signature - https://www.fordedgeforum.com/settings/signature/
It’s apparent that you didn’t take it to a reputable mechanic - the first thing that should have been done on finding an issue with the timing and before going ahead with the replacement of the timing components, would be to assess the consequential damage knowing that this is an interference engine. Throwing more parts at it isn’t going to help - you need to consider a replacement engine.
Take a photo of the fault indication and show it to the service manager - the service manager can report it as a failure without mentioning that its intermittent - if its the dealership where you bought it they'll be more inclined to help get it passed by Corp.
Installation of a seat in EDGE SEL from TITANIUM
1004ron replied to Yurez's topic in Accessories & Modifications
"Salon" ? -
Would be good to get photos of your installation. Does yours have separate pads for the parking brake, not shoes like the above YT video ? If its pads squealing I would put a small bevel/chamfer on the leading and trailing edge of the pads.
Welcome. I haven't seen any other posts with oil consumption issues in the 2.7TT which leads me to believe that its not a common problem. Do you have an extended warranty? - if so take it in for an official oil consumption test, and depending the outcome they should cover the repairs or replacement engine. Asl check the Positive Crankcase Ventilation (PCV) valve and make sure its not allowing oil to be fed into the intake, if that's good then do a compression and leak-down test. I use a Catch-Can and it will alert me to any malfunction with the PCV system.
- 20 replies
- oil
- consumption
(and 2 more)
Manage Wi-Fi Networks Unavailable
1004ron replied to jsalva04's topic in Audio, Backup, Navigation & SYNC
Welcome. Not familiar with the latest models, but my 2017 updates over WiFi were so slow - I tried it once and cancelled it and went with downloading to USB. Check this site to see if download to USB is available. https://www.ford.com/support/how-tos/search/Download SYNC with MyFord Touch software updates to a USB drive/ Maybe @Haz can help. -
The TPMS sensors installed one year ago in my Edge are working great, and so are the ones installed in my BMW motorcycle two years ago - both sets bought from the same country that made my 4 yo cell phone which is still working flawlessly.
2nd TED unit changed. Seat works.
1004ron replied to enigma-2's topic in Interior, A.C., Heat, Interior Trim
I replaced my evap purge valve and the only symptoms was a minor stumble at idle immediately after gassing up and a stored error code - haven't had any further issues since installing the new evap purge valve. I doubt that an evap purge valve could cause it to die while driving.
