Everything posted by 1004ron
New control arm installed - alignment needed?
1004ron replied to DrivingofftheEdge's topic in Brakes, Chassis & Suspension
It is best to do the alignment after replacement of this type of suspension component. -
Welcome. With it being an interference engine there's bound to be piston and valve damage.
Universal Catch Can Hose 3/4" x 4' | Mishimoto PCV/Fuel Rubber Hose, By The Foot Hose & Tubing | Damond Motorsports
Your best option is to buy the catch can kit from a reputable supplier which includes hoses with the appropriate specification. I expect that the correct hoses don't only meet temperature and pressure requirement but also a vacuum specification. Ex. High-Temperature Vacuum-Rated Coolant Hose
That's what happens if you go with the el-cheapo catch can and its hoses.
Yes. Is yours FWD or AWD? Please add your Model & Year to your profile signature - https://www.fordedgeforum.com/settings/signature/
Excessive smoke on cold start - 2017 Ford Edge Sport 2.7l
1004ron replied to JohnR0983's topic in 2.7L EcoBoost
My catch can gets full at about 1000 miles, so I empty it every second or third gas tank - that's in winter and its a mix of oil and water. In summer I empty it less frequently and its mostly oil. If your PCV is good then it might be excessive crankcase pressure causing the catch can to fill at that rate. -
Welcome. I also have a 2017 Sport and at 112K miles now and haven't seen this at all. It sure does seem similar to what's reported in the TSB. TSB 19-2188.pdf -
Correct - there's a few tire size calculator sites such as the one below. Revs per mile 687 vs 680 delta 1.0% https://www.wheel-size.com/calc/?wheel1=265-40-21X9.5ET40&wheel2=275-40-21X9.5ET40&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm https://www.willtheyfit.com/index.php?width=255&aspect=50&diameter=19&wheelwidth=9&offset=37&width2=315&aspect2=35&wheel_size=20&wheel_width=11&offset2=28
Please add your Model & Year to your profile signature - Settings - Ford Edge Forum
Some of those code readers aren't reliable with Fords, so I suggest a basic OBDII dongle and the free app FORScan Lite. Veepeak OBDCheck BLE Bluetooth OBD II Scanner Car Check Engine Light Code Reader, Auto Dual Mode Bluetooth Diagnostic Scan Tool for iOS & Android
I find the electronic/digital version way more useful mainly for the word search, and don't need my reading glasses.
I change my PTU oil at 30K miles, and sometimes less miles than that - I wouldn't go over 30K miles.
That depends on the Model/Year. Please add your M/Y to your profile signature - Settings - Ford Edge Forum Amsoil is a good brand, but there's many others as well.
Had to wait until I got home to measure it. Silicone Tube 5mm ID x 8mm OD 1.64' Flexible Silicone Rubber Tubing I use Amsoil for the PTU and RDU.
Service advance trac, collision warning not available
1004ron replied to pdilow's topic in All Wheel Drive (AWD)
Sport, SEL, Titanium, ? Please add that detail to your profile signature - Settings - Ford Edge Forum -
Welcome. Do you have any preferences in mind, ... are you looking for performance improvement, looks, or good reliability and service with low dust? After trying two sets of drilled and slotted I'm very happy with the solid CENTRIC 12561118 High Carbon Alloy rotors and AKEBONO ACT1818 ProACT Ceramic bought on RockAuto.com No vibration or noise under braking at any speed, and good feel with low dust from the Akebono pads.
This is what I use for extracting the RDU oil. I made the shepherds hook/candy cane with a wire coat hanger inside some silicone tubing, used with my BMW oil extractor.
There isn't one on my 2017 and don't expect one on the 2018.
None of those codes or the engine temperature sensor would prevent the engine start. Puzzled why the Ford Dealership couldn't diagnose the issue. What did they report following their diagnosis? - did they confirm that the codes were unrelated to the no-start issue? If the no-start is repeatable with regards the 45 minute wait then you need to make them aware of that and they can diagnose accordingly - could be fuel rail pressure bleeding off. Another thing, is there any other info you haven't disclosed, such as the Ford Dealership doing diagnostics?
- 8 replies
- hard start
- ford edge
(and 2 more)
Welcome. From your description I don't believe its the belt. More likely an exhaust gasket leaking. Possible the CAT's getting fouled causing higher pressure upstream.
There isn't an easy way to check for potential damage caused by the coolant in the oil other than a teardown inspection of the bearings. I don't think that the timing chain is sensitive to a short run with the coolant unless the tensioner was impacted. Probably best to take a chance and replace the coolant pump and hope for the best. Did you hear or feel anything with the engine running in this condition?
Cleaning carbon off intake valves on direct injection engines
1004ron replied to enigma-2's topic in EcoBoost Mod & Tech
Very good video and would be my preferred method when or if I decide its needed on my cars. One thing that I believe could be contributing to the fouling of the intake valves is the Exhaust Gas Recirculation function that the Variable Valve Timing now performs, and that would apply to GDI and MPI. After resisting the need for OCC (my negative opinion can be found in post a few years ago) I'm now 100% onboard with the need for them - any reduction in the oil contact with the inlet valves and in the combustion chamber is an advantage. I have 111K miles on my Sport and when I changed the spark plugs at 106K miles I inspected the intake valves and top of the pistons and they were remarkably clean, so not expecting to do this cleaning for quite some time - this may be due to the OCC, only using Costco Top Tier Gas and very gentle driving style.- 1 reply
- 2
