Everything posted by 1004ron
In the case of my wife's BMW it was the tensioner doing a jiggle that drew my attention to the need to replace these components, and the reports that when the belt goes on the BMW engine it typically trashes the crank main seal. The failure mode that leads to the tensioner oscillation is a worn or contaminated (oil) friction damper - not a worn spring as many suggest. A previous vehicle of mine used a flat friction disc whereas the BMW use a friction drum - you can see in the attached photo of the old tensioner that I tore apart. The tensioner's bearing felt and sounds rough while the idler felt and sounded smooth.
Thanks - appreciate the practical tips. Just done the same on my wife's BMW X5 and the Ford isn't going to be nearly as awkward. Ordered all Motorcraft from RockAuto.com.
With 103K miles on my Sport I'm looking to replace the serpentine belt kit. I'm leaning towards Motocraft or Gates - anyone know the best place to find a kit or should I just go with buying the three items (belt, tensioner and Idler) on RockAuto.com ? @Haz would you be able to help with more detailed instructions?
You say it "cranks" and then a few lines down "it does not turn over" - those are conflicting comments. Pull the spark plugs and try turning it manually with a wrench on the crank. If the "no crank" started with the new starter, then I'd take a very close look and compare the bendix gear to the old starter. I guess your friend has learnt a life lesson never to buy a used vehicle that doesn't have a good service record.
The one in the link I posted has a "Timeout lock" so that the 3rd brake light behaves as if it doesn't have the flasher module if in traffic where the brake is used repeatedly - mine are set to flash rapidly three times then solid, and will not flash again if the brake is applied for the next 30 seconds.
You could replace the flashing unit with a less offensive higher quality device. Search for YouTube videos for the installation of these flasher units and that will show you how to remove them and restore the wiring to original. This is what I use. https://www.amazon.com/dp/B0BN983DCS?psc=1&ref=ppx_yo2ov_dt_b_product_details
1004ron replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
102,091 miles and first rear brake pads replacement and second transmission fluid drain and fill. Previous transmission drain and fill was at 46,175 miles. Drain and filled the transmission and new rear brake pads. I went with Akebono brake pads that have the mechanical wear indicators, which the original pads did not, and if they had they'd have been screaming. I used my Gerber multi-tool to turn the caliper pistons back in (clockwise), but will get a basic tool before the next pad change in 7 years. -
What did you use for reading the stored error codes?
Member's details not shown anymore?
1004ron replied to handfiler's topic in Forum Help & Site Suggestions
Edge Guide any chance this issue could be addressed? -
Fluttering Noise from Undercarriage and Dashboad Rattle
1004ron replied to CCMAYES72's topic in Brakes, Chassis & Suspension
And what 2018 model is that? Please add that to your profile signature - Settings - Ford Edge Forum- 90 replies
- dash noise
- dash rattle
(and 4 more)
Uriah rios why wouldn't you trust the service shop that you took the vehicle to? There's a multitude of potential causes of hydro Lock, fuel, oil or coolant - a blown head gasket would allow coolant to fill the cylinders ......... but there's insufficient information provided for anyone here to make an informed suggestion, however the service shop has the benefit of inspecting the vehicle.
They're recessed so unless you get right below them you might not see them - also possible that Ford made a change with your Model/Year - maybe @Haz can confirm.- 90 replies
- dash noise
- dash rattle
(and 4 more)
This is what I have on my Sport and Mustang, and will be installed on my wife's BMW X5 tomorrow - very happy with these all season tires. Bridgestone Alenza AS ULTRA
In winter mine will fill up in much less than 2,000 miles - I suspect yours has been overflowing for some time. I get the same emulsion in my 2017 Sport and empty it every second or third tank of gas during the winter months and in the warm climate I'll double that interval. The teflon must have been from the catch can assembly, and there's no way magnetic particles are going to make their way into the catch can.
Why is this site servers so unreliable ?
1004ron replied to 1004ron's topic in Forum Help & Site Suggestions
It took a whole lot longer than it should have, but overnight changes were made and its a whole lot better. -
In winter my morning routine, as I start brushing my teeth before putting on my work clothes, I remote open the garage door and remote start the car - looing for the confirmation on the key fob and the visual plus audible on my phone for the garage door. Cannot hear these two steps from within my bathroom.
Backup Camera - Enhanced Parking Aid - 2011 edge
1004ron replied to mitchjs's topic in Audio, Backup, Navigation & SYNC
Did you try a forum search? IDS/Scan tool? - Lounge - Ford Edge Forum -
Attention - there's an uptick in accounts being hacked
@therealratfink account was hacked and used to post SPAM today . No option other than removing the account. Shameful that the owners of this site don't apply IP blocking. IP: 38.170.254.69 https://www.stopforumspam.com/search -
I did it now! Team RXP 2020 dual catch can kit
1004ron replied to DrivingofftheEdge's topic in 2.0L EcoBoost
I'm sure there are work-around's such as dropshipping I've used drop box shipping a long time ago, but it wasn't to CA. https://www.dropbox.com/ -
I checked my email from the time I purchased and its the JLT Model: 3031P-B https://www.amazon.com/JLT-Separator-Passenger-Anodized-Ecoboost/dp/B07GJX14QK https://www.jlosc.com/jl-3-0-oil-separator-passenger-side-2015-2020-edge-sport-st-lincoln-mkx-2-7l-ecoboost/ -
My 2017 Sport has lived a "sheltered life", never driven hard, has had a catch-can on it from 27K miles, and it is running as smooth and efficient as it did when I bought it in March 2017. When I next do a spark plug change I'll take a look at the intake valves - when I did the first plug change the combustion chambers and intake were spotlessly clean, which could be due to it only using Costco Top Tier gas. I was surprised to see that my Honda lawnmower had a wet timing belt - at 7 years its still going strong and haven't heard of failures - I'm in a wait and see mode on this type of application.
