1004ron
    108
Everything posted by 1004ron
  1. robertlane any chance you could look at correcting this when moving to the new hosting service?
  2. Thanks for the update, but I'll believe it when I see it because robertlane sure leaves us with the impression that he's abandoned this forum. Maybe the new hosting service will correct the fault that prevents the profile detail being displayed. Posted August 28, 2019
  3. I've done the Drain/Fill twice on my 2017 Sport at around 45K miles each time and it was not black. If its black I'd be concerned that its been abused or its a sign of issues on the horizon. 70K mile oil change interval for the PTU is way overdue - I do mine at 30K miles.
  4. New windshield installed Friday afternoon and this morning very early I drove to the airport and back in the rain and this afternoon I took it through the car wash and no leaks.
  5. I'm still very happy with them - smooth and quiet. I used the same silver paint on the new front rotors and the rear, and as can be seen they still look better than they would if they weren't painted, but could do with a fresh coat of paint.
  6. Its been an issue with this forum for a few years with the owners showing no interest in correcting it, and that's why it was requested that you add that detail to your signature - https://www.fordedgeforum.com/settings/signature/
  7. I have the JLT catch can installed. J&L Mustang 3.0 Oil Separator; Black Anodized; Passenger Side 3014P-B (11-17 Mustang V6) - Free Shipping (americanmuscle.com) 2015 FORD MUSTANG J&L Oil Separator Co. 3014P-B J&L Oil Separator Co. 3.0 Oil Separators | Summit Racing The installation looks the same as the below.
  8. Please add you Model/Year to your signature - Settings - Ford Edge Forum
  9. When I changed spark plugs on my wife's 3.7L Mustang I found oil in the intake - I replaced the PCV valve and installed a catch-can and no longer get oil in the intake. I doubt that the engine braking would cause this.
  10. I don't believe there's a way to remove it, but I use 303 aerospace protectant to mask it.
  11. I stopped in at their shop on Friday and the identified an error made by the installation tech - they confirmed that the windshield will be removed and didn't do so on Friday because they didn't have stock of mine - the senior tech says that they usually install a complete new one because during removal it often breaks and the time to clean the sealant off the old one also makes it cost effective to use a new one.
  12. A few days after the windshield install I went through the car wash and when I got home I saw a little water on the drivers side mat, so went through the car was again this afternoon checking the mats are all dry before - I have a leak. Will call tomorrow to schedule the fix - wonder if it means removal to reseal.
  13. Two threads merged - one was in "Off topic Lounge". Here's a direct link for you to add your vehicle details to your signature: Settings - Ford Edge Forum
  14. I'm not an expert on this but believe that it is possible to add NAV but it would need a new APIM and GPS antenna - this is what I did on my wife's 2015 Mustang. I can PM you the contact for the person that sold me all the Ford hardware needed, all configured. On my 2017 Edge Sport I no longer use the in dash NAV after getting a wireless Carplay device - Waze is all I use for navigation.
  15. 1004ron
    My other ride!
    WOW that looks brand new - I remember them - they were legend one of the first bikes to go water cooled - I couldn't afford one of those in that era and had its smaller brother the GT250 Ram Air, then later the Kawasaki Z1000.
  16. I would start by reading the stored error codes using Forscan or other device that's know to have the capabilities with Ford. After that I'd use the scanner monitor the O2 sensors paying particular attention to when the engine is warmed and the A/F ratio switches from Open Loop to Closed Loop.
  17. See what I was getting at with regards the scanner? I would start by checking out the transmission selector and linkages, and the connector to the transmission range switch - if that all checks out good then get a wiring diagram and confirm the range switch is giving the correct output at its connector when selecting each gear position. My model had a recall due to issues with the synthetic bush connecting the cable to the transmission range lever - wonder if that's good on yours. Maybe @Haz could help with the wiring diagram.
  18. Safelite replaced my windshield today and did a great job. The only trim removed was the plastic cover at the bottom edge of the windshield. The spec label on the lower right corner is exactly the same as the original windshield. They took it for a 10 minute drive with their calibration device - I never use the lane guidance but tried it on the drive home and it works as it always has.
  19. I wouldn't be taking any advice from that Scotty fool. The BlueDriver is a good OBD2 adapter, so that adapter with ForescanLite (Free) will reliably read the codes, which will most certainly be there based on the symptoms you describe.
  20. Agreed, reputable, but if it were me I'd scan it with Forscan or Forescan Lite. That's my recommendation based on personal experience.
  21. I doubt that kerosene would do much for the sludge build-up on the oil pump suction strainer and the screens on the VVT control valves if the engine isn't run. Most folks are very wary of using an engine flushing product, but I think when an engine has been allowed to sludge up like this it may be the only option - if you do this plan to do a good few short interval oil & filter changes.
  22. PTU drain plug drill and tap - Page 10 - All Wheel Drive (AWD) - Ford Edge Forum Any quality fluid that meets or exceeds the specs in your owners manual is suitable for your Engine, Transmission, RDU (Diff) and PTU. I use Ford fluid for the Trans, Mobil 1 for the Engine, and Amsoil for the PTU and RDU. Transmission Fluid Replace? - Transaxle (FWD) - Ford Edge Forum Try the forum URL in Google with key words.
