Everything posted by 1004ron
Welkom Boet. We also get snow in my area, and with AWD I find all season tires/tyres work just fine. I've had Bridgestone - ALENZA AS ULTRA bought from Costco for almost two years and will go with the same next time. Alenza AS Ultra | Bridgestone Tires
Welcome. Could you post a photo so that we can have better idea of which part you're referring to.
2011 Edge Cooling Fans not running
1004ron replied to atrdriver's topic in Interior, A.C., Heat, Interior Trim
Try a search here and Google and you'll find an abundance of reports confirming that none of the 3rd party offerings work - another option would be to take a chance and try another 3rd party unit and report back. -
Loulou Welcome. Judging from this thread it sounds like the engine cover wasn't fitted to your Model/Year.
Welcome. Yes the VIN will confirm if it has ACC. If it were me, I'd make sure that there's an arrangement in place with "my mechanic" that he would carry the cost of the replacement module if it was not the solution to the problem.
Air cleaner, cold air inlets & associated
1004ron replied to enigma-2's topic in Accessories & Modifications
I stick with OEM air filters. -
What battery are you using and where did you purchase them? High ambient temperature won't cause the "leak everywhere", but over charging will definitely do that. If you have a multimeter measure the resting voltage and then the charging voltage with the engine revs at 2000 or higher - the charging voltage should be around 14.3v and anything higher would be an indication that its overcharging. BTW, is there any chance that you have a remanufactured alternator installed?
AC Compressor bracket missing
1004ron replied to Pbear74's topic in Interior, A.C., Heat, Interior Trim
A service shop might consider installing the compressor with a written waiver that they bear no responsibility for anything that goes wrong. It's hard to predict the long-term outcome operating it without the third mount. A creative fabricator might be able to make a bracket that secures to a different location. Looks like you've got nothing to lose giving it a try without the third mount. -
1004ron replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
How many miles have you got on the MAXLife and still feel good? I've contemplated using this when I did my second drain/fill at 102K miles. There loads of good reviews spread across many brands forums, but mixed opinions on this forum. -
Anything else you haven't mentioned?
Check the vacuum line and its non-return/check valve is good. Let the engine idle for a few minutes to build vacuum in the booster then disconnect the hose at the booster and confirm there's an inrush of air.
Who performed the diagnostic test and what equipment did they use?
Wouldn't you suspect the replacement oil pressure sensor?
Ford Edge 2020 SEL 2.0 Ecoboost making loud engine noises
1004ron replied to Deco567's topic in 2.0L EcoBoost
In Canada the powertrain warranty is 5yrs / 100,000km - why don't you have any warranty cover? Is the warranty not carried over to the second owner? -
What's the service history - oil change intervals, and by who? Stop in at a place like Autozone and have them read the stored fault codes. -
Cant make much out in the video/audio. What's the mileage? What's the service history - oil change intervals, and by who? Have you checked the oil level? Stop in at a place like Autozone and have them read the stored fault codes. -
Welcome. What model do you have? - please add that to your profile signature - https://www.fordedgeforum.com/settings/signature/
Mobile Tech - do you service and repair cars? Got to be naive to expect meaningful answers with the scant info you provide.
I just replaced the front driveshaft on my wife's BMW X5. BMW X5 and X6 Forum (F15/F16) - View Single Post - Front driveshaft? (bimmerpost.com) Be sure to use a good molybdenum spline lube/grease when you re-install the driveshafts. Amazon.com: Liqui Moly Long-Life Grease + MoS2 | 100 g | Lithium Fat | SKU: 2003 : Automotive
