Everything posted by 1004ron
Not sure if that would help me - I work at a power plant and at times the moisture fall-out from the smoke stack is quite acidic and I already have what looks like water pock marks. This product says its chemical resistant, so there's no guarantee that it will protect against acid rain. With words like "resistant" makes the 7 year warranty somewhat meaningless - they have a get-out clause from the get go. I see the application starts at $300 - what does a car of our size actually cost?
What do you mean by "recently started" vs "when its is driven back from the garage in the morning" - if it appeared right after it was at the garage, you should take it straight back there. Also, what makes you think of "application of lubricant into somewhere on axle" - did you actually hear the noise coming from the axle? - Is it FWD or AWD, front or rear axle?
2015 Titanium with 12,885 miles just dropped 3rd and 5th gear!
1004ron replied to Iam2tweet's topic in 2015 Edge & MKX
Sorry to hear about your problem. Is that mechanic at a Ford service centre or an independent? I haven't read about this type of problem being common with these vehicles, so interested to hear how that mechanic came to believe that. -
Yeah, I didn't focus on the key word "bulb".
There is a few and it looks like they're getting started. https://www.autobytel.com/car-buying-guides/features/10-cars-with-led-lights-that-outshine-the-competition-130697/
I had to do a bit a Googling, and if its main function is "sound", I'll definitely be keeping my money in my pocket. What "control" is it meant to do?
That's what mine held, and only that you mentioned the manual I took a look and it states the capacity as 11.8 oz which is clearly incorrect - very odd.
How do you think the retailers get hold of it then, and does that really matter seeing as its freely available across the country? Did you see this? Not sure what's your point. Doesn't mention that they add it to Motocraft.
What do you mean by that? https://www.amazon.com/Genuine-Ford-XO-5W20-5QSP-Premium-Synthetic/dp/B000NU87PM/ref=sr_1_1?s=automotive&ie=UTF8&qid=1514849034&sr=1-1&keywords=motorcraft+oil https://www.walmart.com/ip/Motorcraft-SAE-5w30-Synthetic-Blend-Motor-Oil-12-Quart-Case/937180249
Have you seen this? http://www.fordedgeforum.com/topic/17985-oil-change/?p=179414
You keep using Mobil-1, but you could be a little more courteous to other forum members.The Kendall has specific additive which is lacking in the Motorcraft. Titanium oxide nanoparticles as additives in engine oil
Playing in one side of speaker when in bluetooth
1004ron replied to Darren2828's topic in Audio, Backup, Navigation & SYNC
That's just wild guessing to suit your smear campaign. -
Sony - Surround sound mode-Your settings?
1004ron replied to Chipster's topic in Audio, Backup, Navigation & SYNC
Same response to your multiple posts on the same subject, Sounds like you have a defective product which should still be under warranty, so return the vehicle as you plan, or get it repaired under warranty - by no means is what you describe the norm. -
As mentioned in your other posts on the same subject, Sounds like you have a defective product which should still be under warranty, so return the vehicle as you plan, or get it repaired under warranty - by no means is what you describe the norm.
I don't think that's what was being suggested, but rather that the oil in the plug well would cause electric arcing and plug misfires.
2017 Edge Sport Leather-Trimmed Seats
1004ron replied to FunSizedGirl34's topic in Interior, A.C., Heat, Interior Trim
I bought my 2017 Sport in March and was also a little concerned with the seats, but they're holding up good. I use Lexol leather conditioner on the smooth leather sections to keep them supple, and just wipe the faux suede with a damp cloth. -
Here's an interesting article on using premium (doesn't mean top tier gas) Turns out 'recommended' Premium gas doesn't do much Enough for me to stick with top tier premium - Costco is convenient for me, so I almost exclusively use their fuel, which is typically 20 to 30 cents cheaper.
Good luck finding the parasitic drain, because it takes just one deep discharge to ruin a lead acid battery. The place where you bought the Interstate should still give you a free replacement regardless. Costco has the best deal on Interstate batteries these days, lowest price ans longest warranty at 42 months free replacement.
You need new bifocals LOL.
This is from my manual:
My 2017 Sport that I bought in March 2017 had the drivers side airbag and controller replaced at in Aug 2017 - could have had it done earlier, but chose to wait until I took it in for service.
I'm quite happy with my Sports brakes and plan on sticking with the OEM Motorcraft pads, unless others here convince me that there's better alternatives available. I searched my owners handbook but cant find the Motocraft brake pad part numbers - can someone confirm these for me please.
I believe that the Sport 2015+ has the PTU drain plug. http://www.fordedgeforum.com/topic/10914-ptu-leak-failures/?p=170489 Take a look at the photos in that post and compare it with yours.
