Everything posted by basment
FordPass no longer updating location while moving
basment replied to dabangsta's topic in Audio, Backup, Navigation & SYNC
My 2019 would intermittently show a location other then where it actually was. This "ghosting" happened whether the vehicle was moving or parked. Took it to the dealer (extended warranty) and was told the Telecommunication module was to blame. Unfortunately that module is reported do be on back order until sometime after the first of the year. -
FordPass no longer can connect to vehicle?
basment replied to eric1's topic in Audio, Backup, Navigation & SYNC
I had a similar issue with my 19 Titanium where Ford Pass would not give me the current location of the vehicle. The dealer had to reprogram the APIM and now it works fine. Another issue to check is if your mobile data provider for your car is current. -
Looking for Recomnendations for Seat Covers
basment replied to mznyc1's topic in Accessories & Modifications
https://www.covercraftoutlet.com/ some deals here -
How do u get rid of this? - head unit connectivity error
basment replied to Itsdjellz's topic in Multimedia
Mine does that if a phone is not connected. -
19 Titanium Heated Steering Wheel
basment replied to basment's topic in Interior, A.C., Heat, Interior Trim
I asked if the temperature could be adjusted via software and mentioned Forscan. I was told they don't use Forscan, and that Forscan is something used by non dealer shops to alter OEM software. I told him I was not happy with the lukewarm temperature and requested a replacement wheel if it could not be adjusted to a more realistic temperature. .......The service writer said he will discuss it with their warranty person and get back to me. -
The heated wheel in my 2018 Sport gets very warm/toasty to the point of almost being hot. The steering wheel in my 2019 barely gets warm no matter how long it is left on. The dealership claims that is normal and state that they compared it to another 2019 Edge which also barely got warm. I wonder if something was changed at Ford for the 19 model year or is the dealership feeding me a line. Temps are in the 20-30's here so that should not be a factor. How warm does your 19 Edge wheel get?
Had the wheels painted and added the running boards.....
Ford also did away with the plastic engine cover on my 19 Titanium.
This post shows by tank.... https://www.fordedgeforum.com/topic/22553-fuel-filter-location-2015-edge/
UPDATE Advisor wasn't sure but believes it was #2 cylinder that was bad. They are going to push Ford for a new crate engine. Advisor stated they had a 1.5 eco need replacing last month and a 2.7 in a F150 with 30K right before that. Dealership believes my case to be a manufacturing defect. We shall see. I was told if they get a replace order once paperwork is complete it could be at least 2 weeks minimum for the new engine to arrive if one is available per their experience........
My 2018 Sport with 7100 miles is now in the Dealer's shop awaiting a new engine. On Monday morning upon startup I noticed a misfire/minor vibration which went away as soon as I started driving. No engine light on dash so I chalked it up to a cold engine. The next morning I again had a slight misfire on first startup which again went away as I drove a few blocks to mail a package. Upon returning to the vehicle and starting it I had a check engine light continuously lit. Shutting off and restarting did not make the light go away. I drove to the Dealer, which is a couple miles from my house, but they were backed up and could not fit me in and asked I come back first thing this morning. I did and dropped off the car. I then got a call from the service advisor a few hours later who informed me a new engine was needed. I will get more details when I stop up there later but I was told that upon checking the problem cylinder with a bore scope they found the inside soaked in oil and also possibly coolant. Because the car is less then 12 months old and still under primary warranty I am to be given a loaner car and the advisor sees no problem with a new long block once required paperwork is filed. The car has never been tuned or modified, has only had full synthetic oil changes (2), and I use Shell V-Power 93 fuel almost exclusively. I have no idea how many weeks/time this will take to get it back. ......
I have the in channel type from Weathertech and have had no problem with them.
Mud Flaps - Guards for 15-17 Sport trim
basment replied to NoDTMF's topic in Accessories & Modifications
I purchased the Weathertech front mud flaps for non sport models.............. -
I also bought the mud flaps from China. The rear ones fit fine after a little difficulty "muscling" into position since the holes did not quite line up. The front ones would not fit. The holes did not line up properly, and the package only came with 4 screw clips instead of the needed 6. The screw clips that did come in the package were too small to fit over the sheet metal tabs on the fender. I gave up on the fronts and ordered some front flaps from Weather Tech. Although not an exact fit on my 2018 Sport, it is hardly noticeable and installation was a breeze. -
True. I first used Collinite in the 80's and over the years have tried alot of the new high tech waxes, polishes, sealers, etc. I want something that is easy to apply, gives a decent shine, and is durable for my cars which are daily drivers not show cars. Collinite fits the bill. If someone wants the ultimate shine there are any number of brands that will provide what they are looking for.
15 edge not recognizing bluetooth
basment replied to ClaytonL's topic in Audio, Backup, Navigation & SYNC
I had a similar issue with my wife's Fusion. It would not connect with her phone but would freeze on the "Trying to Connect" message. I deleted both of the phones it listed in memory and started the connect to phone over and has worked fine since. Don't know if this helps or not, but her Fusion has My Ford Touch.....
