elsengaby
About elsengaby
189 profile views
elsengaby's Achievements
  1. Thanks a lot guys I will change the oil first and check it again hope that will work. The car made 225000 km until now. And all the engine work made in the garage.
  2. Hii Guys, I have Ford Edge 2007 and i just repaired from 10 days the engine cooling as replace the water pump and some pipes and before one year i replace the oil cooler and radiator, also i change 6 injectors after i got the car it was move smoothly without any problems and suddenly engine light come up and when i check it, give P0020 CamShaft Postion Actuator, i changed the Camshaft sensors upon my garage advice at that time the engine light off for 2 days and come back again and when chick it the code is P0020 Intake Camshaft Position Actuator Circuit (Bank 2) .... Status-FF (Above Maximum Theshold). I return back to the garage and they didn't know what is it meaning. Kindly advice what is the problem and what i should do? By the way i regularly change the oil and use Total engine lubricant but last time the garage add .Zeal engine lubricant i don't hear about this lubricant before but the garage told me it's good.
