jasoneg
jasoneg's Achievements
Community Answers
blindspot system fault/cross traffic fault
jasoneg replied to jasoneg's topic in Audio, Backup, Navigation & SYNC
Ok. I’ll have to look into that. I did check all the sensors (back up) and they all work. Just the BLIS and cross traffic on the pass side. Probably that module behind the bumper on the pass side. I was rear ended a few years ago and it started acting up a few months after the wreck. Probably related. The modules say “set aside if dropped “. Sounds fragile. -
No codes -
My 2014 Edge has a blindspot system fault AND cross traffic system fault. The alerts show up every time I turn on the car (tried to upload pics but wont work). Is this something that has to be fixed by the dealer? Is there a way to fix myself? Unfortunately both dealers near me have bad reputations. i know they would probably charge me something outrageous. ALSO, is there a module on the left side and right? Or just one.
Replaced with a new one for $28. Took 20 minutes. Filled up twice already with no issues. Thanks again!
Awesome info. Just watched a video. Looks super simple. Thanks!!!!
My 2014 Edge (90,000 miles) runs great, but right after I fill up the gas tank it idles rough. The idle goes up and then down to about 500-600 rpms. Sometimes it almost feels like its gonna stall. It will be rough going up and down until I start to drive. Its not horrible, but just enough to feel it. After I drive it for a couple miles its fine. Idles perfectly. No other issues at all. Had the fuel pump replaced at 56K due to CEL. But it had the issue before that. Thought that may fix it, but it didn't have any effect. Had the fuel injection cleaned at 40k and I use fuel system cleaner at every oil change (5K).
So....I went to the dealer this morning and met with the service mgr. They brought my Edge back to the shop and the service mgr. said he would be back in 10 minutes after a test ride with another customer. When he returned about 20 minutes later we went to the shop. Approached my car and the tech was already under it!! And he was frantically rushing. I was pissed. He had already removed the old fluid before we arrived and was starting to pump the new fluid in. As he pumps it in he shows me that its full because the fluid is OVERFLOWING FROM THE FILL PLUG. All down the side of the PTU like it should have been before! I could tell he was mad or embarrassed , and was trying to cover his tracks, he never mad eye contact. He was so frazzled to get the PTU full he knocked over the quart of fluid onto the floor. The service mgr. and I walked back into the service advisor area and I lit him up. I told him its obvious he didn't do it the first time. He couldn't wait to fill it up so oil could spill all down the side of the PTU. But I had pictures of it before. When I showed the pictures to him he didn't respond. I told him I wanted to see the dirty fluid and the fill plug and the tech purposely started before we got back there. The service mgr. said that he showed me the fill plug, and I told him I wanted to see it when it first came off and if it had any metal shaving on it. He proceeded to tell me he picked up the drain plug and "he personally cleaned off all the metal shavings with his fingers" and showed me his greasy hands. I told him thank you for proving my point. There shouldn't have been any shaving on the plug if the fluid was changed yesterday, and it was obvious from my pictures that no fluid had ever touched the outside of my PTU. He then told me he would give me a full refund for the job. Just shameful. 99.99% of people would never know that they got ripped off. Unfortunately for him, I was the .01%
Yeah. I'm going in the morning and I'm gonna watch them do it. What a pain! I just watched a you tube video of a mechanic doing the PTU fluid on a Mazda CX9. He was able to remove the old fluid without making any mess really, BUT when he had to fill it there was gear oil dripping all down the casing and even some on the exhaust. I will let you all know what happens tomorrow!!! I will be shocked if the fluid is clean...
I agree. Not happy. Maybe it was done, but highly unlikely. I called the service manager and told him what happened and that I believe that the fluid was not changed. He said the mechanic had been there for a year and a half and has done a very good job. He said he may be promoting him to shop foreman. Not sure how a fluid changer gets to be a foreman, but whatever....The service manager (who was VERY nice) said I could come back tomorrow and they would do the fluid change and I could watch it being done. Just seems very AWKWARD to be standing there watching after I accuse the mechanic of lying to me.....but at the same time I want the fluid changed.....I was very polite the whole time, and told him I didn't want anyone to get fired, but I feel I got ripped off.
The mechanic knew for sure it was the PTU. I saw the mechanic in the bay after the car was on the ground and he was putting the injection cleaner in the tank. I confronted him about the fluid change (after knowing it was only up on the lift for 20 minutes). I honestly figured he was going to do the injection cleaning first. I never saw anyone or any machine under the car when I saw it on the lift. So, I asked him WHEN he changed the PTU fluid to let me know how it looks. He said he already did and it looked fine. We had a small discussion about PTU's and I let him get back to work. I really found it hard to believe that it was changed that quick, but I didn't want to call him a liar to his face. I figured I would just check when I got home.
It was $129.91. One hour labor charge of $100 (and they only spent 20 minutes in the shop) and $29.91 for the fluid (which is expensive). I dont really mind paying $130, but i really dont think it was done.
I can. Is there something specific you are looking for on the invoice??
Can someone tell me how long it should take to suck out the old gear oil from the PTU and put in the new? I was at the dealer today and it was literally done in less than 20 minutes. I got home and put the car up on jack stands and crawled underneath. I see no evidence of a change. The corrosion that was on the fill plug (and in the socket drive) was still there (changed my engine oil last week and looked at it) and there was no signs of oil drippage or clean up from the fill. Is it even possible not to spill a drop? Thanks for any input.....
I have a 2008 Ford Edge with a bad drivers side seat track (it rocks back and forth) and doesn't move back and forth when you get in and out. Has anyone ever replaced one of these themselves? The seat track is over $400 online, so I was hoping to do it myself and save the labor from a dealership.
