Fordedgesport2016
About Fordedgesport2016
Fordedgesport2016's Achievements
  1. Hello I just put on put on my new winter black replica 20" rims on 255/20/50 winters (the tires were from my previous 2014 Ford Explorer ) These rims stick out more than the 21 inch I used the bolts that were already with the 21 inch wheels so no need to buy new bolts
  2. Hi I wont be using tpms.... Yes, the new replika rims require 60 degree Conical Seat lug nuts, but are my OEM lug nuts from my 21 inch Ford Edge 2016 also 60 degrees and can i use my OEM lug nuts on my NEW replika rims? Thanks
  3. Can you please let me know the specs of the oem or the lug nuts you bought? Are they 60 seat? Thanks
  4. Hello all I just got my winter 20 inch rims. Replika r189. The reason i went with 20 inch is because i already have 255/50/20 winter tires (3 winters) from my returned lease 2014 ford explorer. So i only had to buy rims See the 2 pictures of my brand new replika r189 Here is my question to all It says that these new rims r189 use lug nuts "60 seat" Can i use my oem lug nuts on these rims? Are my oem lug nuts 60 seat? I dont understand this terminology Thank you
  5. Hello all I have an emergency questions regarding oem lug nuts I just bought 20 inch winter rims for my 2016 sport edge https://www.replika.ca/productinfo.aspx?wn=r189&fn=gloss+black It says that these r189 use lug nuts "60 seat" i dont know what that means but can i use my oem lug nuts for those rims? Thank you very much
  6. Hello all I bought my 21 inch sport edge. (This car mooooves wow!!) I want to buy 20 inch wheels for winter I already have 255/20/50 winter tires from my ford explorer (3 winters with those winter tires) so i thought of buying 20 inch rims These are the rims i want to buy rwc LR88 the LR88 has a direct fit 20x8.5 5x108 ET45 CB63.4 http://www.rwcwheels.com/en/site/collection/wheel-collection/land-rover/lr88-black Because the offset these tires will stick out about 5mm more than the 265 of the 21 inch rims And the height of the wheels is 2.5% more than the 265 of the 21 inch Question Will the size difference in tires affect the odometer? Will the fact that my winter tires stick out about 5mm more cause me issues? Anyone have any other suggestions for 20 inch rims with direct fit only? Im looking for direct fit only Thanks
  7. Ok Do you guys thisk this is normal? Oops it is crooked 397km till empty ... On full tank
  8. Hello How did you post your picture I have a couple of pictures to post but cant seem to do it Thanks
  9. Hi I think there is something wrong with my fuel meter From a full tank and after i drove about 300km my fuel indicator stated i was low on fuel and fuel needle was at empty .... This was weird So i went to the gas station and filled up. I only used 15 liters to fill back up to full status ... 15 liters is not much So after filling up with 15 liters my fuel needle is backup to full My fuel reading is between 21L/100km-25L/100 Can anyone confirm: on a full tank my reading states 394km Distance to Empty Thats about 245 miles Distance to empty Can you guys please confirm? I have pictures How do i post pictures?
  10. I replaced a 2014 ford explorer (6 cylinder) that was getting me a little over 19 L/100km in city driving, i will see if the ford edge sport which right now is at 22L/100km can match the ford explorer We will see Also what should i do about the 4inch scratch (not deep but visible in the clear-coat on top side of the rear spoiler) i dont want the dealer touching my car anymore. I will get this buffed out by a professional??? I had to also very delicatly remove any tiny glass fragments that were stuck to the paint. All this becuase the dealer broke the rear window. At least they teplaced the window.
  11. I will give it a bit of time but i am worried seeing i drove 60 km and used up 1/4 of a tank DAMN!!! Also the dealer scratched the top part of my rear window spoiler when they replaced the rear window
  12. The car has 90km (thats about 56miles) i understand that the fuel economy will improve but it is REALLY bad right now And im driving slow.....it is all city driving i might add
  13. Omg I just got my ford edge sport (dealer broke my rear window , they replaced it) it now has less than 100km it actually has 90km on it, i am getting around 22L/100km My numbers are awfull!!! Did anyone else experience the same? Thanks in advance
