Katie Belton
Facebook Member-
About Katie Belton
Katie Belton's Achievements
Hard shifting after TSS/OSS replacement
Katie Belton replied to Katie Belton's topic in All Wheel Drive (AWD)
yeah. I think that is the next thing I'm going to try. Do you know approximately how much they charge for that at the ford dealership? -
We bought our 2008 MKX about a year ago and very soon after that it began shifting hard mostly between third and fourth gear. It would also shimmy when going up hills almost like it couldn't decide on a gear. Then about a month ago I got the wrench warning light. I asked about it on this forum and on Facebook and found out it was most likely the TSS and OSS sensors. I replaced both sensors this past weekend and the shimmying when going up hills seems to be gone. The problem is that the hard shifting is still there. I have read about these issues with Edges and MKXs from a lot of different people but I haven't actually heard about anyone who solved the problem. Does anyone have any ideas? This is really starting to bother me. Based on what I've read this seems to be a design flaw with these cars.
Powertrain malfunction light... the wrench of doom?
Katie Belton replied to Katie Belton's topic in 2008 Edge & MKX
As a matter of fact, yes. You guys are the best. Once we complete the OSS/TSS replacement, this forum, along with the Facebook page and the videos, will literally have saved us thousands of dollars. I can't thank you enough. By the way, I ordered both sensors today. They should arrive in a couple days. Going to do the job this weekend. I will let you know how it goes. Thanks again. -
I found the part that corresponds with the number for the TSS but partsgeek.com says it is for the 2011-2017 Edge. Is it the same part for both generations? -
Thanks Mac. Any suggestions on where to order the parts from? Also, when ordering them, do you order two of the same parts? I seem to be able to find the oss sensors, but no one carries the tss sensors. Is this because they are literally the same part? -
I also have a 2008, although mine is an MKX. I have been having the same issues since I got mine about a year ago. The other day it shifted hard and the wrench light came on on the dash (power train malfunction). I pulled over and shut it off and it was eventually OK. I posted about it on an Edge Facebook page and they said it is most likely the TSS/OSS speed sensors. Apparently the first few production years are notorious for this. $700-$800 repair at the dealer. It's all labor because you can get both sensors for $100. I was told that if you have one from these years they will eventually go bad. Can be done by a diy'er, but it doesn't look easy. Good luck.
While driving down the highway today I felt a hard shift followed by the wrench warning light. I quickly pulled over and shut he car off for a few minutes. When I went to start it up again I felt a hard clunk, but no warning light. I turned it off again and when I restarted everything was fine... no light and running well. A little background: I've had the MKX for about a year and it occasionally shifts hard. I also had to have the PTU replaced about 6 months ago. Last week I had to replace the cooling fan and I used the quick replacement method. I'm wondering if I could have knocked something loose while replacing the fan. Based on other things I've read on the web, it seems like this could be an intermittent fluke that happens with Edges and MKXs. Any ideas? Also, what kind of code reader would an MKX owner buy and approximately how much do they cost? Thanks to everyone who helps on this site. It has been invaluable.
When I ordered it I thaught how much difference could there possibly be? Now I know: you get what you pay for. I'll probably keep it. I'll probably jack up the front end this weekend and make sure it's seated properly.
REPF160902. I actually jus googled it and found it on amazon. It says it the brand is TLN Auto Parts.
I went back to the website I ordered it from and looked up the part number but can't find a brand name (probably not a good sign). I didn't have to unbolt the assembly at the bottom. I'm going to double check that it's torqued down and seated on those little mounting ears properly.
I just replaced my cooling fan with an aftetmarket one. I think it was like $140. The new fan is so loud and vibrates so hard that I'm beginning to think there may be a problem. Has anyone else had this experience with an aftermarket replacement fan? Is this just because I ordered a cheap fan? I would order a higher quality one and replace the one I just got but it was such a pain to remove and install.
Rear brake caliper bolt size
Katie Belton replied to Katie Belton's topic in Brakes, Chassis & Suspension
Great. This website has saved me so much time and money. I wish I give more help than I do, but everyone has been so helpful. Thanks again. -
Does anyone happen to know the bolt size (thread count, length,etc) for the bolts that hold the rear brake calipers onto the caliper bracket? When I was changing my rear pads yesterday one of the bolts snapped and the other looks pretty bad. Just want to know exactly what I'm looking for so I only have to make one trip. Thanks.
I was backing up my 2008 MKX in a parking garage when a cement support pillar jumped out behind me. My upper and lower rear bumper covers were both dented and scuffed. I have been looking online for a replacement and it seems like the bumper covers for edges are less expensive. My question: Would a bumper cover from an Edge fit my MKX? Also, does anyone know how to remove the rear bumper cover on a 2008 MKX? I saw some step by step instructions for the second generations, but nothing for first gen. Any help is appreciated. Thanks.
2008 MKX and I've noticed that when I have my windows down I can hear a jingling/rattling sound coming from my rear driver's side wheel area when I go over bumps. At first I thaught it was a chain jingling on a truck behind me but soon realized it was coming from my car. I'm going to be changing my rear brakes soon and I am wondering if anyone has any ideas as to what I should look for while I have the wheels off and the MKX jacked up. Any suggestions?
