Buuls eye
Everything posted by Buuls eye
Yes, mac, only the impeller is plastic which being used to pump coolant.
I think ford fill it only up to the min line in factory. I notice that a few weeks later on my 15 edge after i bought it. I then went to buy a gallon of coolant and added to the max line when cold.(dealer cant look at it till a week later, i dont think i can wait thats why i went ahead and bought one then added my self.). I live in Houston where summer temps can easily hit 100s, having a plastic water pump that constantly has go through many heat cycles really worries me. Ford really shouldnt put it inside the timing chain cover. I dont mind it fail, but to cost over $1000 just to replace it really is disappointing.
Great infos. Thank you all very much!
hey thanks for the detail explaination. So that means you wont be able to tell if the temp is up to operating temp by looking at the gauge?
Hello everyone, Got a question on my 15 edge's water temp display. No matter how hot the weather is or how hard I drive it, the temp indicator is always point slightly to the left instead of pointing exactly in the middle. Is this normal? Thanks in advance!
I am going to do it every other oil change(10k). Ford said "drain and fill at 30k for extreme conditions". What Ford is really saying, change the fluid at 30k will most likely keep the tranny trouble free till 60k so you wont come in for warranty works which Ford has to pay. My take on what ford is saying is that at 30k the fluid will start showing oxidation and increase wear on the tranny. I think changing the atf frequently and long before the fluid break down should be sufficent for this transmission to go a long way.
Updates! The part number that listed on TB is different fron the invoice. The real part number is ATE4-9F991-EL . The one that failed ended with "EK". I guess the "EL" is an updated version.
Are there anyone out there has a fail TB but replaced a new one by yourself? I really want to take a look at the failed part to see what went wrong inside. I suspect either the seal inside the electronic module circuit board is not strong enough to hold off moisture causing the circut board to corrode and eventually failed or the plate simply stuck open due to the DC motor malfunctioning.
You would have to check with your local dealer for parts price last time i check was about $400 from dealer. But this is a very easy job most DIYerscan get this done within half an hour. Its just happened that my car is still under warranty so i let my dealer do it.
UPDATES! Dealer replaced my TB, the part number is AT4Z-9E926-B. I hope this will fix the issue for good.
UPDATES! Dealer replaced my TB, the part number is AT4Z-9E926-B. Gotta give credit to Ryan Ford down here in Sealy,TX! They went the extra mile when they couldnt pull the code, they actually tried to reproduce it and got a code of P2112 then promptly replace it within 2 hrs! Awesome dealership for ppl in Houston,TX! I hope this will fix the issue for good.
Mine 2015 edge fail last week, build date is 12/09/2015, with 5100 miles on it. I am scheduled to have it in for service on Wednesday, exactly one week after my stalling on the free way incident.
Thank you so much for making an effort to alert fellow edge owners! I have already filed a complain with NHTSA right after i got home. I tried to made the rep aware that there are tons of similar cases already filed and they really should investigate before someone got serious injuried. The service ppl at my dealership seems to know this issue, i hope they will change the faulty TB quick next week. If they deny, i will show them the video i took when the edge fail. Thank you all again and I will post updates next week!
Thanks WWWPerfA_Z 0W. At least I know this is coming, and I know what to do. Cant imagine others that dont know this jn advance and they stalled in the middle of freeway. I hope ford could fix this for good.
Thanks WWWPerfA_Z 0W. At least I know this is coming, and I know what to do. Cant imagine others that dont know this jn advance when they stalled in thr middle of freeway. I hope ford could fix this for good.
Mine failed yesterday on a mahor free way during rush hour with 5111 miles on it. It went to limp mode, no matter how hard i step onthe gas, it will not go above 15 mph. Scheduled to be in service next Wednesday. The buld date on my edge is 12/09/2015. Stalling on a major freeway is not fun.
Walo, I hope the material ford is using is has the same quality as Hondas. Anyway, macbwt already had said his has gone about 150k without any issue so i think this will not be a problem.
Macbwt, well thats one less thing i need to worry about then. Thanks!
Crimsontidetom, sorry this happened to you. Could you post the part number of the newly replace TB when you got the vehicle back? I am thinking of just go ahead and have it replaced with the new part instead of waiting it to go bad because my wife drives it most of the time to take my daughter to school. Thanks!
i was supprised too when I searched the part number online. I bought this brand new back in Dec of 2015, everything is stock no mod on this edge(as of now).
