lildisco
    37
About lildisco
6,418 profile views
lildisco's Achievements
  1. I had EBC's on my focus years ago, geez 20 years ago at this point 🙃, & I wasn't too impressed with them. I found Centric when I did the SVT brake conversion & have been loyal ever since. When I converted back to stock before selling the focus, I missed a driveway entrance as I was so used to bigger brakes of the SVT conversion. I really miss that car sometimes, but it was never engineered to last through northern winters 😢
  2. I believe that I have them on my 2020 without issue, but I have the Centric Premium Blanks on that one. I was looking at the weather protection mainly as the northern salt & brine are always a factor. I believe that I had the power stop z23's on there before, but they also put out dust, just way more manageable. What do you recommend? Luckily the pads are the cheapest part of this whole process.
  3. Just ordered front pads & rotors for our 2016 2.0L FWD. Centric high carbon coated rotors & centric posi quiet ceramic pads from Rock Auto for $185 shipped. Most places wanted $93 a rotor. They ~9 years old, so I'm sure that they're due for replacement.
  4. That model year & trim did not come with a 2.7L V6. The SE trim only came with the 2.0L 4 cycl turbo. The 2.7L V6 was only offered in the ST version. Some Lincoln's may of had that engine available to it, but all models of Edge's, except the ST, got the 2.0L cylinder Ecoboost. As far as purchasing, all depends on maintenance price. I'd swap all fluids & check for brake & tire wear. Overall, those model years are good, but all depends on how well the vehicle was maintained.
  5. If you've only done 1 drain & fill, you'd probably want to do 2 more. Someone did the math & (I could be wrong) but doing a drain & fill, drive around for 15-20 minutes & repeat 2 more times gets ~70-80% of the old fluid out. Especially if you're ~75,000. I've done our 2020 2.0 once already & it's at 38,000 & I've done our 2016 2.0 twice & it's at 80,000.
  6. I had to buy the trigger tool & a Bluetooth Adapter with FORScan to get our 2016 to work early on. People said that they just swapped theirs & the car would learn the new sensors & locations. Swapping on our winters & after driving for over an hour, they still wouldn't learn. Made an appointment for a tire place & magically they started reporting on the way there. The next spring when installing the summer wheels, I used the trigger tool & FORScan & haven't had any issues since.
  7. Its on top of the engine, kinda just behind the oil dipstick & oil fill cap. Between the engine & the firewall. Pre 2019 2.0's are under the engine between the engine & the splash guard.
  8. 3x drain & fill on my mom's 2012 fusion fwd with the 6F35. She never changed it from new & lasted till 122,xxx miles 😬😬😬😬 She said that it shift way better & doesn't hang when shifting. Hopefully Valvoline Maxlife can work miracles.
  9. Did an oil change a few weeks ago on the 2016 fwd & drained the Catch Can. Decent amount came out of the catch can since it was mostly winter months. Just hooked up our little 5x8 trailer to our 2020 AWD & picked up my mom's ztr. Mowed her 5 acres & our little 1/4 acre. 2nd cut of the year. Grass really grows in the spring. After mowing, I changed the oil. OLM was ~55%,but still like to change it before 50%, which is ~5,000. Mobil 1 5w40 & Puralator Boss Filter in both.
  10. I ran mine through the wiring harness going through the spare tire well, through the drivers side panels to the mini fuse panel in the drivers foot well. Pretty easy & used a extend a fuse or add a fuse & wired it to something that only turns on when the power to the car is on, like the radio I believe.
  11. I wired up my 2020 SEL AWD pretty easy. I think that the hardest parts were popping the taillights off, getting the bolts through the frame rails & getting the power wire for the trailer lights through the tire well. On a scale of 1-10 it was ~4. Probably would have been easier if I had a helper, but wasn't terrible. I installed the Curt Class 3 hitch & curt trailer harness. I believe that both were purchased from HomeDepot.com as they were the cheapest at the time the downside to the aftermarket hitch is that it sits ~3-4 inches lower than the factory location & if you had the kick to open the hatch feature, it doesn't work as good, unless you buy the kick sensors meant for the Edge's with the factory towing package.
  12. The Altimax 365's did really good tonight in the 'dusting' we got tonight. Only thing I had to worry about it was the other people on the road being stupid. So far I'm impressed. We have ~1,500 mile on them with this being the 1st 'snow'.
  13. Year & Model? I find that mine, not factory setup 2020 SEL AWD, comes on when parking lights are on when the doors open or close & stay on for a few seconds after the doors close then go off. That's probably due to the aftermarket trailer wiring kit, Curt, that ties into the the drivers side Taillight with a plug & play harness. I'm not sure about the OEM setup, but I imagine that it's similar.
  14. Stayed home from work to not spread the germs. Worked from home till about 2 & then decided to throw the winter rubber on our 2020 SEL AWD. Had some free time time to undercoat or touch up the undercoating with Fluid Film. Oil life monitor is at 55%, so it's teasing me. If the weather is decent enough tomorrow, I'll clean the summer rubber & then hit it with McKee's 37 Hydro Blue before storage.
