Damir Čolak
Facebook Member-
About Damir Čolak
Damir Čolak's Achievements
Ford Edge 2016 SEL - same problem, rear right passenger, near the roof handle. Has less than 6 months. Creaks and rattles appearing all over the vehicle. So much for the quality manufacture. Maybe 50.000 USD is not enough for Ford to create a car that at least feels as a quality vehicle?
Anyone Replace Their Sony Speakers?
Damir Čolak replied to bill valley's topic in Audio, Backup, Navigation & SYNC
Yes only one in the dash. The other one you can use as a spare. I replaced only middle speaker and sound got much better. -
I replaced it with one of these, it's a drop in: http://www.crutchfield.com/p_108R3022CX/Infinity-Reference-REF-3022cfx.html?tp=96 Infinity Reference REF-3022cfx It helps a lot create a better sound stage. By the way, the stock speakers in Edge 2016 9 speaker system are ABYSMALLY BAD. The magnets are so small, the speakers are so bad. Use a plastic prying bar to move upwards the plastic dash covering the speaker. It can be done without disarming everything, just remove the cover, take out old speaker and put new one in. You will be VERY surprised when you see how bad are the stock speakers Be careful when putting back the dash over the speaker, do not push it all the way down or it may cut the speakers suspension. -
Yes, how in the world could I change radio station from my wheel and also from buttons or touch screen? Just imagine, accidentally changing a radio station by clicking on a button. I bet they are all so confused. I agree with you, the only controls I use from the wheel are climate and phone calls and sometimes entertainment... hell I guess I use them all but the navigation. :-)
You cannot select the lowest speed of fans when on auto. You cannot select the air ducts to be used when on auto. With steering wheel controls it's easy. Up for hotter, down for colder, right, up for faster, down for slower fan. Done. Perfect. And you can see the changed settings in front of you, no need to look for the button to press, screen to read results.
That actually is not true. On auto mode, you cannot select air ducts to be used. On auto mode, you cannot select the slowest fan speed. Even in auto mode, I have to look down and search for the button in order to change the temperature then look up and read the new temperature, all the while the car is moving down the road.
Oh, that's awesome news. At last I will be able to control climate without trying to make it understand my command, repeating YES etc. How do you SAY "hotter, hotter, stop, colder, stop, fan, faster, stop?" Up or down to make it hotter or colder, right, up or down to make fan go faster or slower, never taking my eyes off the road, always seeing the changed settings in front of me. Just like I could on my ford fusion
I just saw Ford Fusion 2017 come with the climate control via steering wheel controls. I'm looking at the OBDII scanners and www.forscan.org and thinking, could it be possible to enable the climate control? Why would Edge 2016 not have it, is there a hardware missing or what? I keep having to stare at my central dashboard trying to figure out what button to press, in order to control my climate. Several times I almost hit a car in front while fiddling with climate buttons and trying to figure out at what speed are fans working at. For some reason, Ford made it really hard to find buttons without looking and gives almost no visual or haptic clues of what's going on while changing fan speed or temperature. It doesn't make it easier the fact that they put in the same horizontal orientation both fan speed and temperature buttons.
