spacetanker
About spacetanker
417 profile views
spacetanker's Achievements
  1. I've just encountered the dreaded water pump issue and am facing the prospect of potentially needing a new engine. That said, I'm in good company judging from this and other forums, I'd like to encourage those who have encountered this problem to register your issues with the NHTSA and Ford. It is likely nothing will come from this but silence ensures complacency. We all know that water pumps are maintenance items, but Ford managed to turn a repair of a few hundred dollars into something that costs well over a thousand dollars...IF you happen to catch it before it destroys the engine! Thank you for your support! Included in my NHTSA complaint 11098462: I own a 2011 Ford Edge Limited with a 3.5L, 6 cylinder engine. The vehicle has been faithfully maintained since I purchased it at ~30,000 miles. On 5/25/2018 while driving out-of-state and with approximately 120,000 miles the vehicle began exhibiting symptoms of stalling at stops and while parking; there were no warning lights or indications of trouble. Pulling off the road I inspected the automatic transmission fluid first, since that seemed the most-likely culprit. During this check I overheard a lot of noise as hot coolant was being ejected into the coolant overflow reservoir and it was while the car was parked that the overheat indicator first sounded. After shutting off the engine I noticed water on the pavement under the vehicle. I arranged for the vehicle to be towed to a Ford dealership where it was determined the coolant pump had failed. Though completely without symptoms until the final few minutes, because the pump is driven by the engine's timing chain, enough damage had been done that a significant amount of coolant had entered the engine. The engine would start, but pressures in cylinders 2 and 4 were compromised and unknown other damage had occurred. The Ford service advised that the pump replacement would cost on the order of $2,000 and that life-expectancy for the part was 150,000 miles - two numbers that seem incongruous by themselves for a maintenance item. In addition, the absence of a cooling system warning facilitated driving the vehicle while catastrophic damage was caused to the engine. Not Included in Complaint: In the days since I have read numerous other complaints from owners of vehicles equipped with this engine who have also suffered a loss due to this inferior design. Ford should be required to make owners aware of this issue, caution them to vigilantly monitor coolant temperature, the level of coolant in the overflow reservoir and the presence of fluid at the weep hole (also very difficult to observe). Ford should also install a sensor on the coolan recovery tank to warn operators of low coolant levels and greatly improve the life expectancy of the water pump, given the complexity and expense involved in maintenance.
  2. I was using the Wine version of Foscan for Windows 10 on a PC, so no phone or cell connectivity to interfere. From what I could tell the iPhone version of the Foscan didn't support the service options needed to re-calibrate the camera, so there was no compelling reason to go down that path anyway. The ELM 327 was purchased from Amazon (https://www.amazon.com/gp/product/B00QRE0OOA/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1). The seller was ELM327. No refunds, so S-O-L if I can't get the thing to work. I ordered the USB link cable today; the two devices together will still be cheaper than taking the car to be recalibrated at the dealer. For what it's worth the dealer wanted $900 to replace the camera, parts and labor included. Highway robbery for a $300 camera and what in all likelihood is a maximum of 30 minutes labor with the right software and interface tools.
  3. This past Saturday I replaced the camera. It took about 30 minutes from start to finish thanks to the information linked to this topic earlier by wlepse. Thanks again. Unfortunately I was not able to perform the calibration as described here: http://www.fordedgeforum.com/topic/21159-replaced-rear-vision-camera-2012-edge-sport/ I am using an ELM 327 Wifi OBDII device with the Foscan software. With the ignition in the ON position I could get the ELM 327 to connect (Interface indicator green and log showed connected), but after a long pause while the device read vehicle data it would display two dialogs saying it couldn't read the vehicle data and then shortly thereafter that it lost the connection to the ELM 327. I messed with this for a couple of hours before I ran out of time. I read that some of the ELM 327 use Chinese chips that aren't as reliable as the more expensive devices, and did attempt to access the device's administration page through the browser at 192.168.0.10, but was never able to connect. The device I purchased can't be returned, so I'm hoping someone has some ideas to try. The image with the new camera is better, but I really need the parking aides back!
  4. I'm facing the camera replacement hurdle with my 2011 Edge. I was able to access the camera, but couldn't figure out how to remove it from its mount. I tried pushing in on the tab, rotating, etc. Opposite side from the tab there appeared to be a pivot and a button, but nothing I tried would wrest it free. I've dug around on the forums and haven't found any information on how to remove the camera so a replacement can be installed. Any pointers?
