Jei
About Jei
Jei's Achievements
  1. Jei
    Ford Edge 2012
    Thanks buddy, I use plasti dip as primer and then plasti dipped rims I repainted with car paint, all that because if I ever want to remove white paint and still have chrome rims I can easily remove it because of plastidip )))
  2. Jei
    Ford Edge 2012
    Quick time lapse of oil change on my Ford Edge 2012 (project Yeti) https://www.youtube.com/watch?v=eHRS3mmUps0
  3. Jei
    Yeti
    Ford Edge 2012 SEL AWD
  4. Jei
    Ford Edge 2012
    Thanks man, I appreciate your help.
  5. Jei
    Ford Edge 2012
    Thanks, already order spark plugs, transmission fluid Motorcraft Mercon LV and PCV valve. How is better to clean it? use mass air flow cleaner or disassemble TB and then clean?
  6. Jei
    Ford Edge 2012
    Thanks for reply. I will try explain as much as possible. On low speed when I hold gas pedal in one position and transmission shift from one speed to another I feel little delay or sometimes no delay but a little kick. Another issue is when I accelerate little bit aggressively and then abruptly let go gas pedal I feel kick. That's the problems that I have. About kick on traffic lights, I never feel that car sways with climate control off, but when it's on, sometimes it's so terrible , car sways back and forth. BTW thanks for info about spark plugs & PCV valve I didn't thought about them.
  7. Jei
    Ford Edge 2012
    Thanks guys. Today I checked transmission fluid level and was really surprised fluid is in perfect level and it's clean like brand new, I don't know what to do now... Unfortunately I don't have any information about it was replaced before or not and I have almost 80K miles, I really don't like how transmission shift on low speed. Maybe problem is not in fluid? :doh: Sometimes with climate control on in auto mode when I'm standing on traffic light I fill kick, this kick is so strong that car sways, plus today I hear hiss noise from braking pedal, I think I have to replace brake power booster and I thought maybe that's why transmission going crazy? or maybe my AC compressor is dies and that's is the reason of this kicks? I do not know what to think HELP NEEDED :hat_tip:
  8. Jei
    Ford Edge 2012
    BTW today at Walmart I found this transmission fluid, is it good for Mercon LV as said on sticker?
  9. Jei
    Ford Edge 2012
    Thanks I appreciate it.
  10. Jei
    Ford Edge 2012
    Thank you but it's not work for me, in Philly is only one gas station with 110 Octane :D Thanks guys, today I fill up my car with 87 I even don't remember when I used it before )))
  11. Jei
    Ford Edge 2012
    Thank you. BTW, I don't want open a new topic and I will ask here, What fuel do you use guys? I know that I can find this info in owners manual but I want to hear this info exactly from owners. I use 89 should I continue use it or better to use 87?
  12. Jei
    White on Black
    Thanks man! I appreciate.
  13. Jei
    Ford Edge 2012
    Now i see, thanks. Thank you. Can anyone tell me this fluid good for transmission? http://www.ebay.com/itm/Ford-Motorcraft-MERCON-LV-Automatic-Transmission-Fluid-12-Quarts-Free-Shipping-/191658451117?hash=item2c9fbbe0ad:g:naUAAOSwT6pVyOM2&item=191658451117&vxp=mtr thanks.
  14. Jei
    Ford Edge 2012
    Thanks. I'm sleeping better after I changed oil by myself
  15. Jei
    Ford Edge 2012
    Thanks for answer, no my car is 3.5L. Okay so i will continue to use Motorcraft engine oil and will choose same brand for transmission. But what's about fuel filter i have to change it with fuel pump or it's good until pump is in work condition? Thanks.
