unhapfordownr
Everything posted by unhapfordownr
  1. This needs to be a recall not a TSB! I have found many people with the same issue. My edge broke down in the middle of rush hour traffic with no warning at all my check engine didnt even cut on until after I turned it off and restarted to see if it would strat again. Shakes violently and has no power to go. It is an over $2000.00 repair on top of the $700 I have already spent to replace output and input shaft speed sensors 6 months ago! I have only had my edge 14 months and have already put almost $3000.00 into it. Both issues have happened in rush hour traffic with no warning at ALL! I take good care of my edge and just had 4 new tires and brakes all the way around put on 2 weeks before my PCM and coils went out on it. FORD PLEASE PLEASE PLEASE ISSUE A RECALL!!! I could have been killed by my Edge losing power in the middle of 6 lanes of rush hour traffic with no warning not to mention the fact that this issue could cause engine to catch fire if there is gas in spark plugs!!!
  2. I BOUGHT A 2007 FORD EDGE IN OCTOBER OF 2014. I LOVED MY SUV UNTIL LESS THEN 6 MONTHS LATER I HAD TO PAY OVER $700 TO HAVE MY OUT PUT AND INPUT SHAFT SPEED SENSORS REPLACED IN MY TRANSMISSION. MY EDGE BROKE DOWN ON ME AND WOULDNT GO INTO GEAR ON MIDDLE OF INTERSTATE IN RUSH HOUR TRAFFIC. NOW LESS THEN 6 MONTHS LATER MY PCM HAS GONE BAD BURNING UP ALL 6 COIL PACKS IN MY EDGE. I HAVE CONTACTED FORD AND THERE IS A TECHNICAL SERVICE BULLENTIN ON THE PCM AND COIL PACKS, BUT WAS TOLD NOT ENOUGH PEOPLE HAVE REPORTED THE ISSUE TO PUT OUT A RECALL. I CAN NOT AFFORD OVER $2000.00 TO HAVE THIS FIXED. FORD IS AWARE THAT IT IS A DEFECTIVE PART AND I DONT UNDERSTAND WHY THERE IS NOT A RECALL ON IT. THE DEALERSHIP IS NOT TRYING TO HELP ME AT ALL. SO I AM ASKING EVERYONE WHO IS EXPERINCING VIOLENT SHAKING AND LOSS OF POWER AND CHECK ENGINE LIGHT ON TO CALL FORD AND REPORT IT SO WE CAN GET A RECALL ISSUED. AGAIN I WAS IN THE MIDDLE OF 6 LANES OF TRAFFIC DURING RUSH HOUR AND THE TRUCK JUST LOST POWER. I COULD HAVE BEEN KILLED AND RAN OVER TOP OF. I HAD NO WARNING OR ANYTHING THE TRUCK JUST SLOWLY STARTED LOSING POWER AND CHECK ENGINE LIGHT DIDNT EVEN CUT ON UNTIL AFTER I TURNED EDGE OFF AND RESTARTED. THIS IS AN ISSUE IN NEED OF A RECALL ASAP! I HAVE DONE ALOT OF RESEARCH AND HAVE FOUND THAT THE FAULTY PCM BURNS UP THE COIL PACKS AND EVERYONE WHO IS JUST REPLACING COILS IS GOING TO HAVE THE SAME ISSUE AGAIN SINCE IT IS THE FAULTY PCM BURNING THE COILS AND UNTIL THE PCM ($835) IS REPLACED THEY WILL CONTINUE TO KEEP REPLACING THE COILS ($80 X 6 =$480.00) NONE OF THESE PRICES INCLUDE LABOR! ALSO DOESNT INCLUDE THE COST TO REPROGRAM THE NEW PCM TO MY KEYS SINCE IF YOU DONT FLASH THE NEW PCM THE EDGE WONT START DUE TO THE KEYS OUR PROGRAMMED SPECIFICALLY TO THE PCM INSTALLED TO THE EDGE. IF YOU HAVE ALREADY PAID TO HAVE THESE ISSUE FIXED PLEASE STILL CALL FORD WHEN AND IF THEY ISSUE A RECALL (WHICH THEY NEED TO!) YOU CAN SUBMIT YOUR RECEIPT AND BE REIMBURSED FOR COST TO HAVE IT FIXED! THE PCM PUSHES TO MUCH ELECTRICITY TO THE SPARK PLUGS IN TURN BURNING THE COILS AND COULD POSSIBLY CAUSE THE SUV TO CATCH FIRE!!!!! I HAVE NOT BEEN ABLE TO DRIVE MY EDGE IN 3 WEEKS AND STILL OWE $13,100.00 ON IT! PLEASE I BEG EVERYONE TO CALL 1-800-392-3673 IT ONLY TAKES ABOUT 5 MINUTES HAVE YOUR VIN # TO YOUR EDGE AND LET THEM KNOW EITHER YOUR PCM AND COILS ARE BAD OR THAT YOU HAVE ALREADY HAD THE WORK DONE!
