skyvvalker
About skyvvalker
skyvvalker's Achievements
  1. I think I'm going to go with the self install Hidden Hitch on my 2016 SEL Edge, rather than the Curt Hitch (which UHaul uses). If you look at the diagrams for both hitches (see picture attachments or installation instructions), it is clear that the Hidden Hitch square bar sits higher than the round tube of the Curt Hitch, and is therefore less visible. It is worth noting, that the receiver will be at the same height for either hitch installation. BTW, the fact that the Hidden Hitch uses 4 bolts on each side vs 2 bolts on each side for the Curt Hitch, should make for a more robust mounting with the Hidden Hitch. Also, I'm not sure why Curt Hitch is calling for one of the side holes of the "frame" to be made larger for the spacer to get inserted (see CurtHitch2 picture), when it looks like there is already a wider hole forward of the side mounting holes on the "frame", which the Hidden Hitch instructions reference (see HiddenHitch2 picture). Finally, Etrailer.com has posted a nice video for installing the Curt Hitch on a 2015 Edge. Though I plan on installing the Hidden Hitch, some of the steps are the same between the 2 installations: https://www.youtube.com/watch?v=8tBv4AOIV_8 They also have a 2015 Edge trailer wiring harness install video: https://www.youtube.com/watch?v=2lM9HwpNu6E CQT75234.pdf CM_13224_INS.PDF
