Yes, I have daytime running lights (DRLs). Since my fist post/question, I have found out HIDs on a 2014 Edge with DRLs require Canbus ballasts to work properly (flickering and other issues) and deal with DRL issues. I have ordered 35 watt HIDs with Canbus ballasts (from a different vendor for reasons I will not mention in his forum). Also, I recommend using a dual or 2 power relays to power each 55 watt HID separately thus using both vehicle headlight connectors for HID manual on and off control. You may need capacitors/error canellers also. I won't address using automatic headlight control switch setting, as there are many issues I have read about. Once I install the HIDS on order, I will post my results.
