Adam Harush
Facebook Member-
About Adam Harush
Adam Harush's Achievements
Dear Friend I was corrosion in the shifter, I want to replace it, the cable, or part of the (clip), now tied him cuffed, where you can buy for Ford Edge 2012
Hello, about the problem, the shift cable, there had corrosion, does anyone know where I can buy the clips, not the cable, now it has to do with the band, I need it very urgent, http: //www.bushingfix .com / ford-edge-shift-cable-bushing-repair-kit /, is it appropriate, ?? Thanks for the help
Could be a bad shifter and / or transmission range sensor. Or maybe the selector lever cable needs to be adjusted to recognize the proper gear it is in. Is it possible to know the names of these parts? So I would buy them if necessary? I am'll see what you've written, my mechanic, and I will let you know what he said, I thank you very much, thank you brother
Good friend Sorry for the English. I know these tips you wrote. I stood with the vehicle a few minutes, the car was burning, in p, d wanted to go to, and it was busy, I did not know what to do. Turn off the motor, I tried to turn on the vehicle, do not turn on,. I spent a gear, the vehicle is turned off, and I was able to move in d. Gears move like milk, as there is no separation between them. Turn off the motor again in P, and caught again, and again no motive, as before. There dashboard lights, p d n, is not compatible with the chalk, the vehicle is in D, light in n. Now the vehicle in the parking lot, and is taken in P, and came on as before. Is it more understandable ??? Sorry harassment.
What this interchange, (shifter) itself is what is meant ,, ?? Friends, A s doing everything you said, but still hangs p gear, the vehicle is turned on, it goes off Did you know the gears as milk, without feeling the gear box, what does not start,? There is nothing like the computer version update of chalk or something like that
Is there a connection fuse or connection between the gear lever to the chassis of chalk. Are there any clips or something like that, so what comes to mind, forgive the stupidity?
Hello Friends, I need help, I stood with the vehicle in P-powered vehicle, after a few minutes, I wanted to go to D and just stuck the box of gears, turn off the motor, trying to re-light the car will not turn on, here and there I managed to get to D, but the transition between gears was smooth as water is not used, it is possible to turn the vehicle just in d, I drove up to the house, and the synagogue again to p, and again stuck, you can not transfer between gears, (there is no coordination between the gears and lights near the clock does not match, ?? what do you think, thanks in advance
Hello friends, the problem blue screen multimedia system stuck, I went to the garage, and Updated version of Apim, still stuck in the screen, further investigation, we found the issue navigation system, the card had to boot, and the issue has been settled,
Hello friends, Is anyone having a problem, the car on a cold morning, dipping from P to R, I heard a loud boom, when the vehicle warm no problem, I checked residence of chalk, everything is normal, whether there is a link to update the computer version of the gearbox,? The tension of the vehicle, right, what do you think about?
Hello friends, I realized you could check engine light, before starting the vehicle, if flashing 8 times, can anyone explain what should be?
Hello friends, Can anyone explain why, each time after refueling the vehicle, apparently has difficulty starter, paddle perceived not smooth, cleaned the fuel filler? Thank you
thanks a lot for the answer , Is there any interest in cleaning the injectors of the vehicle? And does anyone know where I can buy, upper rear spoiler, liftgate?
Did you see it?
Hello friends Why each time after refueling the vehicle, jump starting, stuttering? I cleaned the gas opening.
