Ntrain2k
Everything posted by Ntrain2k
Decent job, yea. Over a half of a second drop when I had my 11 edge from an intake I made, filter and throttle body.
Ported upper and lower intake, 73MM Throttle body, True cold air, Tune and Exhaust. Did this on my 3.5 NA 16 explorer and shaved over 2 seconds off of my 0-60. More info in the description.
I beg to differ. Stock was nearly 9 seconds. A stock Explorer sport is 6.4 seconds.
PCM should handle the change fine, it's only 12ish more CI. It's been done in an Explorer with no problems. A good tune will really wake it up though.
For those interested in a GOOD radar detector
Ntrain2k posted a topic in Accessories & Modifications
For those interested in getting a GOOD radar detector. I've been using the Uniden R3 for several months now. VERY impressed. I have caught police from 1/2 mile away or more! Filters most of the newer radar signals put out by cars for lane assistance, etc. Frequent updates available also. For areas where you get alerts from doors, etc you can mark them with mute memory so that you will not hear them any longer. Very solid unit and mounts up high with a mirror tap. They also have the new R7 who's benefit is showing if it is coming from front or rear. I HIGHLY recommend! Uniden R3: https://amzn.to/3czel2Y Uniden R7: https://amzn.to/31t5vNY Mirror tap I use: https://amzn.to/2O4hOwY Picture is how I have it mounted, tucked up nicely above the rear view mirror. -
That's nice. Welcome to my post from over 3 years ago...... Still using the same filter in my 2016 explorer. Still really happy with it. K, thx, bye.
There is a campain from Ford for a new throttle body that you need to talk to your dealer about.
- 30 replies
- ford edge
- heistation
(and 2 more)
Has the throttle body been changed under the ford campaign?
- 30 replies
- ford edge
- heistation
(and 2 more)
2010 Ford Edge Limited stiff pedal
Ntrain2k replied to ADAMnHUTTO512's topic in Brakes, Chassis & Suspension
Need to check the brake booster and the vacuum line going to it. -
Ford Edge 13 2.0eco engine compartment question
Ntrain2k replied to Purple31's topic in 2.0L EcoBoost
https://www.fordedgeforum.com/forum/80-20l-ecoboost-specific/- 1 reply
try https://www.12volt.solutions/collections/ford/products/2015-2017-ford-edge-remote-start-plug-and-play-kit-1 I installed a remote start module from them in 5 min on my 16 explorer.
I'd suspect bad coil(s) or plugs.
There are different kinds of "knock". Knock, as in mechanical knock from excessive engine clearances (PTW, crank and/or rod bearings). Preignition or detonation knock. Could be caused by low octane fuel, massive piston crown carbon build up, etc. Tappet noise from the valvetrain. Which is it?
Pretty sure they are a direct bolt in.
Why have people been putting turbo chargers on vehicles that didn't come turbocharged from the factory for more years than most on this forum have been alive?
So some wiring burnt, the car didn't catch on fire......
A mod moved it already.
Thanks guys. This is of course for my new explorer. Their forums are DEAD!
Might be better to move this to the engine section?
Do all 2016 models have the drain in the PTU?
Sorry, I may have missed it. What kind of intake temperature drops did you see?
Ntrain2k replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Exhaust for Edge Sport AWD 2011-2014
Ntrain2k replied to gene328is's topic in Accessories & Modifications
Bolts right up. -
Fits perfectly on the regular 3.5 AWD, not tight. Unless there is something different on the exhaust with the 3.7 it should be fine.
