pedro2u
    2
About pedro2u
pedro2u's Achievements
  1. could be your ballast.... Unless I over compilated the repair, I had to pull off the nose/front bumper so that I could get to the ballasts and swap them from side to side..... and it followed the ballast to the other side. A pain to pull the bumper, but I think that might be your next step
  2. You're welcome! Sharing... isn't that why we're all here?
  3. so 2 of the 6 CarQuest Coils I replaced last fall have since failed in 4 months.. Advance Auto replaced them under warranty. but what a pain. I spoke to my local Indy about coil failures, and his experience is he's seeing the same rate with OEM and the aftermarket coils lately
  4. On my 2011 Limited (which may be different than the SEL), the left side touch pad on the steering wheel controls it. Look at your fuel gauge in the cluster and then hit the down arrow on the steering wheel to get down to Display. Then Hit the right arrow to cycle through the formats it can display. I always chose the combined fuel and temperature gauge myself
  5. Thanks, and agree with you on OEM vs aftermarket. It was all the local part store carried when my car was limping along so I went for it, and true, similar price for OEM which makes the aftermarket failures more painful
  6. I started having rough idle issues and got codes for a coil at 165,000 miles, so I proactively replaced all 6 ignition coils in my 2011 Edge Limited with CarQuest coils exactly a year ago. One of those coils failed in 9 months and was replaced under warranty, another one failed today. Luckily I had saved the original coils I'd removed or I'd be stranded. 2 out of 6 in a year???? Anyone else having bad luck with these coils?
  7. I put Mustang GT wheels on my 2011. Fortunately the Mustang hub was slightly larger than the Edge so I only had to buy the exact size hub centric rings for about $20 on eBay Good luck with the machining! Let us know how it goes (and what it cost!)
  8. this website always helps me, just change the year to do the compares: https://www.wheel-size.com/size/ford/edge/2014/ Center bore: 2014 is 63.4mm 2008 is 70.5 mm You're going to need an adapter
  9. My 2011 Edge with 165K miles had a very similar issue last fall. My wife was complaining that during highway driving there would be an occasional shudder/miss on long hills. I would test drive it and it would run fine. I told her that it could be caused by so many things..... and that I could fix it, if and when it threw a code! It took about a month, but finally.... a code! Bad coil! Of course it was back on the firewall $@&#%!!!, so I figured it was a good time to replace all 6 coils along with the plugs while I've got it torn down, especially given the mileage. Problem solved In your case, if one coil already failed, aren't they all at their end of life? They say "no banana is older than the rest"
  10. Rereading enigma-2's always helpful posts, I see my maintenance log and my Parts log aren't the same. The maintenance log missed several DIY part installations, so to include it all, here's the $1,762 I spent in parts over the years.... 01/24/16 41,000 SPORT GRILLE INSERTS - PRIMED Black 07/02/17 76,197 Mustang GT Wheels Craigslist 07/03/17 76,197 Replace Nav Display Panel - hazards turning on unattended 06/21/18 88,000 Wagner Ceramic Front Pads set - Amazon 08/18/18 88,000 Front Rotors - Advance Auto YH147502P 09/14/18 90,000 Rear Wiper Housing - 9T4Z-17526F 06/19/19 104,668 Optimum Battery - Best Ford 01/25/20 114,752 Wagner Rear Pads - Amazon 01/25/20 114,752 Wagner Rear Rotors - Amazon 04/11/20 118,278 Duralast Outer Tie Rod Ends - Autozone 04/23/20 119,000 Bosch Icon 18in Beam Wiper Blade 04/23/20 119,000 Bosch Icon 20in Beam Wiper Blade 08/28/21 141,888 Duralast Brake pads - Autozone DG1258/DG1377 08/31/21 142,054 FRAM Extra Guard Air Filter, CA10242 12/13/21 148,800 Steering Angle Sensor 02/10/22 151,877 Philips 42302C1 D3S Standard Xenon HID Headlight 02/15/22 151,877 Carquest Premium Ignition Coil 09/10/22 162,000 Rear Calipers - Chuck & Eddie's 11/16/22 167,000 Rear View Park Assist Back Up Camera
  11. If this helps, I've kept a log of maintenance done on my 2011 Limited. First few entries are previous owner off the Carfax, I've owned it since 40K miles and any 2016 entries (like the PTU failure) and have attempted to maintain 5K mile oil changes and tire rotations: Date Mileage Service 11/19/11 6,695 Oil & Filter Change 06/09/12 9,375 Oil & Filter Change 04/06/13 16,279 Oil & Filter Change 04/06/13 16,279 Replace Cabin Air Filter 03/20/15 35,377 Oil & Filter Change 03/20/15 35,377 Replace wipers WW2601PF/WW2001PF/WW1412 09/24/15 36,685 Oil & Filter Change 09/24/15 36,685 Front & Rear Brakes Replaced 11/24/15 40,753 Oil & Filter Change 11/24/15 40,753 Replace wipers WW2601PF/WW2001PF/WW1412 11/24/15 40,753 Replace Air Filter FA1884 FP65 01/04/16 40,168 State Insp 04/26/16 43,909 State Insp 06/14/16 47,515 Replace PS Lines - warranty 06/14/16 47,515 Replace PTU - Warranty 06/14/16 47,515 Oil Change/Rotate Tires 11/09/16 55,137 State Insp 11/09/16 55,138 Oil Change/Rotate Tires 11/09/16 55,139 Transmission Flush 04/05/17 62,438 Oil Change/Rotate Tires 04/05/17 62,438 State Insp 08/18/17 70,643 Oil Change/Rotate Tires 11/18/17 76,197 Replace tires Michelin Lattitude 245/60/18 (4) + Mounting 03/23/18 80,761 Oil Change/Rotate Tires 06/21/18 85,064 Oil Change/Rotate Tires 07/02/18 85,354 Michelin blown tire replacement 08/18/18 88,000 Replace Front Rotors & Pads 09/14/18 90,000 Replace Rear Wiper Housing 12/21/18 96,092 Oil Change/Rotate Tires 04/11/19 102,390 State Insp 04/11/19 102,390 Oil Change/Rotate Tires 06/19/19 104,668 Opitimum Battery 10/23/19 109,759 Oil Change/Rotate Tires 01/24/20 114,752 Oil Change/Rotate Tires 01/25/20 114,752 Replace Rear Rotors & Pads 04/11/20 118,278 Oil Change/Rotate Tires 04/11/20 118,278 Outer Tie Rod Ends 04/11/20 118,278 4 Wheel Alignment 04/11/20 118,278 State Insp 12/15/20 124,525 Oil Change/Rotate Tires 08/28/21 141,888 Front Duralast Brake Pads DG1258 08/30/21 142,034 Oil Change/Rotate Tires 08/30/21 142,054 Replace tires Michelin Lattitude 245/60/18 (4) + Mounting 08/31/21 142,054 Air Filter 08/31/21 142,055 Battery replaced under warranty 02/14/22 152,067 Cylinder 1-3-5 Coil pack (EBC1013) & plugs (XP5363) 02/14/22 152,067 CV axle left (tone ring broken) 02/18/22 152,300 Replace Exhaust 02/19/22 152,306 Oil Change/Rotate Tires 05/06/22 158,734 Oil Change/Rotate Tires 05/06/22 158,734 Alignment 09/10/22 162,000 Replace right rear brake caliper and pads 11/03/22 165,700 Oil Change/Rotate Tires 11/17/22 167,000 Replace Backup Camera
  12. You don’t mention it, but assume you’ve done the reset? Works on my 2011 every time this happens. Step 1: Hold down both the climate control power and defrost buttons at the same time. Press down for 5 seconds. Step 2: Release the climate control power and defrost buttons. Step 3: Hold just the temperature control power button for a few seconds
  13. I'm no expert, but I do have 2016 Mustang GT wheels on my 2011 Edge. So I say look at the data and decide Your 2018 Edge wheel sizes can be checked here: https://www.wheel-size.com/size/ford/edge/2018/ The 2019 Mustang here: https://www.wheel-size.com/size/ford/mustang/2019/ Based on that data, seems like you'd need adapters to convert your Edge 5x108 bolt pattern to accommodate the 5x114.3 wheels. Looks like most adapters I find would push the wheel 1.25" farther from the hub if that works for you.
  14. you don't mention what year you have, but on my 2011 it's this: after that, you set your own code like this: Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
