kevin_ramoutar
About kevin_ramoutar
665 profile views
kevin_ramoutar's Achievements
  1. Has anyone tried/done the rear view mirror swap from the framed mirror to the frameless mirror like what is found in the Nautilus? I've seen someone do it on a 2020 Escape with no problems, but i was wondering if it can be done on a 2019 Edge ST. It looks much nicer in my opinion.
  2. I agree, Ford should have had the MKX style cluster in the Edge's, they look a little better than what we have now. I am aware that Sync 4 comes with the 2021, but i would think that the cluster and infotainment system don't correlate in terms of displaying the fuel range since the only thing you can control from the right cluster display is the radio. Most of the vehicle information is done from the left, barely anything from the infortainment
  3. Hey guys, i was wondering if it is possible to have the screens on the instrument cluster updated on a 2019 Edge to reflect the 2021 Edge model. I've noticed on the right screen that Ford has added the Fuel Range as a permanent display, which i like. They also removed the time from the bottom right corner, and it looks like that screen accent is now all blue, just as the left screen instead of the colors changing between Entertainment, Navigation and Phone. (See picture attached of the updated info screens) Im thinking of asking my service advisor if this is possible. Any thoughts?
  4. Hey guys, does anyone know when is the expected release for SYNC 3 V3.4? ? From some of the info i have found, anyone who's vehicle was shipped with at least V3.2 should be able to update as normal.
  5. the gauge cluster does show "object approaching from left" with multiple beeps and the blind spot indicator flashing but that's only in reverse for the cross traffic alert. do you think it has something to do with the MFT system itself? i was thinking about trying a master reset to see if it resolves the issue
  6. Hey guys, i've noticed over the last week that when i get close to objects and its detectable by the surround sensors, the image pops up on the screen and i start hearing the beeps but it does not show the indication of how close I am on my sides to an object. it only shows the front and rear indications. anyone else have this problem?
  7. CJH, love how your Sport looks! I really like the DRL LED swap, they look much better than the standard halogen. Im actually looking into getting myself a pair, is there any flickering or anything? are they just plug in a play?
  8. Okay I've got the fob programmed! Thanks for all who helped. Seems like you have to time it perfectly as well when pushing the ignition button and rotating the fobs
  9. Okay I've got the fob programmed! Thanks for all who helped. Seems like you have to time it perfectly as well when pushing the ignition button and rotating the fobs
  10. Thats what is says but how can it if the fob wont stand in the slot? it doesnt make any sense. i'll experiment and see if i get it to work
  11. I did find this at first. I tried following the steps to program the fob but it hasnt worked. I will give it a try again and see what happens. If not I'll have to go into the dealer and see what's up. Thanks a lot guys!
  12. That's what I have been doing but I still cant seem to figure it out. I know on some other Ford's there is an actual slot where the fob sits in. the only thing in the center console that I'm finding is on the bottom, there's a weirdly shaped grove. I have tried placing the fob in that grove and following the programming steps but I have been unsuccessful.
  13. Hey guys. I am trying to reprogram a IA Fob for my 2015 Edge. i lost the second fob and had the dealer replace it wish a new fob. My service advisor told me that if we found the lost fob, I can reprogram it since they deleted the information on the car for the lost fob. I've been looking at the manual for reprogramming the IA fob but I cant seem to find the "backup slot". Any one have and ideas or programmed a fob by themselves?!
