jspec
Everything posted by jspec
  1. The Chinese ones cannot be coded and from what I read they only last a year. There are no differential parts available as far a gears and such so they are not rebuildable units. I put a s-150 in and it seems to be working fine. You can fine those cheap on eBay. I saw a YouTube video where they put a S162 in. I believe either are fine as long as it has the Code to put in. I would just fine the lowest mileage S-150 unit and go with that. They suck to put in. If you are in the rust area forget your rear bearings and just pull the whole rear knuckle.
  2. I just replaced mine. I got mine on Ebay for around $960 from a seller in UTAH. I replaced it with a S-150-A it works fine. I do not notice a difference. I am not sure What the difference is but the S154a was only sold for 2 years in the MKX and Edge.
  3. You have to siphon out the oil. There is no drain plug. If you see metal you can verify That is it is the rear diff going bad. It may just be the front clutch pack which is much easier to replace vs the Whole RDU unit. On a side note If you do get into replacing the RDU it was easier to just pull the rear knuckles then trying to get the wheel bearings out.
  4. Get all 4 wheels in the air and get under and listen. Any metal in the differential oil?
  5. I am going through this on my MKX. I was going to get the Chinese one but I was told they do not code out. There is a seller on Ebay that sells the factory rear ends for around $985 " judgementdeytrading" That is the best deal I have found. My guess is your Rear end is the same as mine but send him a message and ask if it will work.
  6. Did anyone actually replace the rear end with something other then a S154A. Would the s164A work? Seems like they are just revisions of the rear end.
  7. So I figured I would continue this thread as there is a lot of good information here. My 2014 MKX 124k miles needs a new RDU. I just got quoted by the dealer $5400 to replace it. Seems nutty. The RDU is about $1800 online or $2421 at the dealer. Seems like there are a ton on Ebay that are either remanufactured or New coming out of china. Has anyone used these? I have a 2011 parts car but the rdu is leaking from the axle seals and the rear cover. That one maybe a lost cause. Any advice would be appreciated.
  8. So I wanted to pop back on here and help the next guy who is in the same situation. 2007-2010 with 1 bolt oil cooler is fine. If you have an oil cooler and it is a 2007-10 you can buy a motor without an oil cooler and transfer the adapter onto your new motor which is what I did. Be sure to flush the adapter and cooler if there was an oil issue. $300 for a 65k motor and $1000 labor. $240 in parts. Runs great!!
  9. So my waterpump failed at 135k miles. I was going to fix it but I checked on car-part and the motors with oil cooler are around $650 for a low mile motor under 45k miles. I can buy a motor without the oil cooler for even less. $300-400 range. I have also read that the 2007-2008 motors when the waterpump fails it puts coolant into the oil like mine did. Anyways After 2009 they have the 3.5L with a 3 bolt oil cooler. Would that work? Let me know your thoughts. And thanks in advance for the help. Ford Edge Engine Removal.pdf
