About Blk182atn7
Blk182atn7's Achievements
Any updates? My 2015 EB Edge has been doing this for some time. Took it in sevttimes and no codes. But its noticeable even using the same chevron for over a month. Tried shell, chevron, 76, Texaco all no change. Even showed ford a video of the tach bouncing around at idle. They said its maybe because I filled the tank to much? But even at half 1/4 almost empty same issue. Maybe needs new spark plugs? Or vacuum leak? I will say there is no loss in power and still gets reasonable mileage.
This looks cool and it's 399 now it looks like the same parts that are in the edge auto lift gate.
Has anyone seen these? http://m.ebay.com/itm/131927931343?_trksid=p2385738.m2548.l4275&_mwBanner=1
SSM 45936 - 2015-2016 Edge And 2016 MKX - Noise From Cooling Fans - Built On Or Before 6/11/2016 i just had it in for this they replaced it no issues. Also had them look at the rear Cabin weatherstrip both sides. Apparently they were not installed properly. All good now.
I sent a note. Not sure of the part number on this one the LED light bar Part numbers are: Rear LED tail light FT4B-13B433-AJ Rear tail lights FT4B-13405 AL You also need to replace the tail lights to get the entire effect.
this is the part #FT4B-13B433-AJ but its only for the rear light bar. you have to replace both tail lights as well to complete the look.
Thank you I added it to my watch list.
That doesn't make sense that the computer would need to be flashed to make "light" work. If I had known it was an actual thing I wouldn't have got mine and got the titanium. Seems like a low move even for ford. I didn't know there was a light bar till I saw an edge with it 5 days after I bought mine so returning it wouldn't happen.
Intelligent access on 2015
Blk182atn7 replied to Blk182atn7's topic in Alarms, Keyless Entry, Locks & Remote Start
Yes the from door handles have the hash marks and a lock just like the other models. The rear doors do not.- 26 replies
- 2015
- intelligent access
- 2015
I think the problem is the Gen2 is still so new no one is getting anything built. I didn't see anything at SEMA but Wasn't 'looking for Ford stuff while I was there. My thought is there isn't even a light in the rear light bar. But you should be able to by the parts from Ford. not sure how cheap it would be. Helm may have the service manual which would have the Part numbers in it.
Ed. I feel the Same way I am pretty sure you can buy the parts, just need to know what to ask for. they have to have them if a Titanium or sport gets into an accident. even the front lighting. I haven't asked them yet, One thing I am not sure of is if the SE and the SEL even have the Lights and they are just not turned or. My thought is that they don't have the lighting that would need to be purchased. If you find out please let me know.
Ford has announced it is adding CarPlay and Android Auto to all 2017 vehicles in North America equipped with BlackBerry's QNX-based SYNC 3 platform, starting with the new Ford Escape. CarPlay and Android Auto will also be available in 2016 vehicles with SYNC 3 as an upgrade later this year.
When you say you have intelligent access for the rear hatch, do you mean that you can approach a locked vehicle with the fob in your pocket and touch the rear hatch button and it opens without having to unlock it first? Yes i can lock it with my FOB, and walk away the rear hatch does not open And when it closes does it lock again? yes if I walk up wit the FOB in my pocket it unlocks when I tap the button under the handle Is it powered or manual opener? Manual open I agree it would be stupid to put in the proximity sensors and simply not turn them on. But maybe thats a paid upgrade. I have had many cars where something was there but nothing said it was and a friend or a forum said just ask for this and they can turn it on. Of course with cost associated.- 26 replies
- 2015
Don't be an A55. I didn't want the titanium its a simple question. The car has the tech built in. Its there. since you are unable to read, 1. you don't need to get the Titanium to get intelligent access its standard on the SEL, Titanium and Sport, its also Standard on all 2016 models so clearly Ford made a change. 2. The rear gate opens with intelligent access 3. all 2015 Edge models come with push button start as does mine I have read that the SE does have intelligent access enabled for the rear gate this is normal operation. And yes I was standing there when the tech took the doors apart to verify that the wiring. this is very simple to answer yes if the hardware is there then does it need to be enabled in software, or no they used all the same hardware, but unable to enable. It seems everything is there to have it it just needs enabled. I have not tried this may i will try this and see http://owner.ford.com/how-tos/vehicle-features/locks-and-security/how-to-program-your-intelligent-access-key.html on the SEL does anyone see in the info intelligent access? I have a my key set up. Mine also has this I have seen it do it: Accessory Mode Battery Saver for Intelligent Access Keys (If Equipped) If you leave the ignition switched on, it shuts off once it detects a certain amount of battery drain, or after 45 minutes. Also to JoeVic - I read it somewhere but (but it may have been and escape forum) I am unable to find it even in the owner manual it only shows how to program keys- 26 replies
- 2015
