Everything posted by ONEDGE16
Here's the Forscan info most people are using to disable it: Engine Noise Enhancement disabled (Piped in engine noise): ACM 727-01-01 xxxx xXxx xxxx 2 = Enabled 0 = Disabled
found this on NHTSA site: https://www.nhtsa.gov/vehicle/2019/FORD/EDGE/SUV/AWD#manufacturerCommunications February 19, 2019 MANUFACTURER COMMUNICATION NUMBER: SSM 47814 Components: SEATS NHTSA ID Number: 10155571 Manufacturer Communication Number: SSM 47814 Summary Some 2016-2019 Explorer, 2016-2018 MKX, 2019 Edge/Nautilus, 2017-2019 Fusion/MKZ, and 2018-2019 F-150/Mustang/Expedition/Navigator vehicles equipped with climate controlled seats may exhibit a buzzing noise from the front seats, front seats too warm, and/or inoperative climate controlled front seats. DTCs B14BA:13, B1154:4B, and/or B14B9:13 may also be present. This may be due to loose terminal pin fit on the driver seat module (DSM) connector C341D (16 pin). If a loose terminal pin fit condition is found during normal diagnostics per Workshop Manual (WSM), Section 501-10, a new service pigtail connector (part number 3U2Z-14S411-BRAB) is available. Refer to Wiring Diagram, Cell 119 to make sure C341D is a 16 pin connector and not a 20 pin connector. Refer to Wiring Diagram, Cell 5 for the recommended splicing procedures.
ST with regular brakes is good with the OEM SE rims & tire size. Picture posted in an earlier response on this thread. Been running on them all winter with no issues.
Different sites available. Any reputable tires site will provide you with compatible options. You can also see what your local dealership is offering as winter options. One of the sites i use https://www.wheel-size.com
2019 Ford Edge AWD: Transmission and Heated Seats
ONEDGE16 replied to JAYQD's topic in All Wheel Drive (AWD)
Check the belwo thread for the heated seat -
Intercooler Grill & AGS (2016 Sport)
ONEDGE16 replied to snmjim's topic in Accessories & Modifications
You can call Benny at Levittown Ford or PM him; he's a member of the Forum. The part number should be FT4Z-17K945-FA -
Best floor mats for 2016 Edge?
ONEDGE16 replied to RCQ925's topic in Interior, A.C., Heat, Interior Trim
I have the husky's and they are great. -
That site will only work if you bought your car from a Ford dealership and they have the VIN entered in the system. If you buy from a non Ford dealership it will give you the message displayed
Still no updates from Ford except engineering is working on it. https://www.nhtsa.gov/vehicle/2019/FORD/EDGE/SUV/AWD#manufacturerCommunications February 18, 2019 MANUFACTURER COMMUNICATION NUMBER: SSM 47810 Components: EXTERIOR LIGHTING NHTSA ID Number: 10155569 Manufacturer Communication Number: SSM 47810 Summary Some 2019 Edge Equipped With Adaptive Headlamps (High Series lamp - Titanium (301A) and ST (401A)) may be reported that the front headlamp lights are not bending while the vehicle is moving through a curve at speeds above 5 kph (3 mph), or that the system check outlined in the owner guide for this feature indicates the feature is not working correctly. Engineering is aware of this issue and is working on a repair solution. The headlamps will continue to function to fully meet all applicable lighting requirements. Do not attempt any diagnosis or repairs for this issue. Continue to monitor OASIS for updates.
Not sure about US costs, but think it would be in the $200 range depending on shop, type of Vinyl and Brand. I would start by shopping for your top rated Vinyl places around you then ask them for quotes, warranty, material, etc... look for reviews, ratings, images of previous work, business bureau accreditation, etc. Have they worked on luxury cars or only more regular cars...
Today STrr got a bit of a remake. She still needs a good wash and get her summer shoes on. Vinyl wrap in Avery Supreme Gloss Black: - Hood - Mirrors - Shark Fin Antenna - Rear Spoiler - Front and Rear Ford emblems Inspired by the G2 hood wrap post Here's some pics
Locks stopped working
ONEDGE16 replied to BMB's topic in Alarms, Keyless Entry, Locks & Remote Start
When was the last time you replaced your fob batteries? And the car battery? -
2016 Ford Edge engine swap 2.0 to 1.6
ONEDGE16 replied to Apigo200x's topic in Ford Edge & MKX Member Builds
is this just an experiment for fun or there is a legitimate reason to downgrade the engine from a 2.0 to a 1.6? -
With Waze integration already available, manufacturer built in NAV as we know it will be thing from the past. My only comment is you currently still need to connect your phone via cable and cannot do the integration via Bluetooth. The downside is you use your phone data plan to run the navigation Vs built in NAV. It would be good if the Apps where built in with Sync and updates are done through WiFi or your phone. Ford recently announced they are working towards integration with Google Alexa as well; seems like Sync 3 also might be on the way out to be replace by sync 4 or something newer
My ST is showing Navigation Maps Version: NA 1 17
