Everything posted by ONEDGE16
The 2020 order guide is out 2020 Edge Order Guide.pdf
Get in touch with Chris Lister on FEWW Facebook page: https://www.facebook.com/groups/fordedgedriversunited/permalink/2246771765450585/
ONEDGE16 replied to ben senise's topic in Accessories & Modifications
Try these Forscan codes: 720-02-02 (2013+ MY) xxxx XXxx (IPC) 00 (Disabled) AA (Enabled - Vehicle Without Heated Seats) FA (Enabled w/Climate Control) - 2013-2014 FD (Enabled w/Climate Control) - 2015+ FE (Enabled w/Climate Control and Heated Steering Wheel) 720-02-02 xxxx *xxx Rem Start - Climate Settings (RSCS), Rem Start -Driver Seat (RSD), Rem Start - Feature (RSF), Rem Start - Pass Seat (RSPS) 0=RSCS disabled, RSD disabled, RSF disabled, RSPS disabled 8=RSCS enabled, RSD disabled, RSF disabled, RSPS disabled 1=RSCS disabled, RSD disabled, RSF disabled, RSPS enabled 9=RSCS enabled, RSD disabled, RSF disabled, RSPS enabled 2=RSCS disabled, RSD disabled, RSF enabled, RSPS disabled A=RSCS enabled, RSD disabled, RSF enabled, RSPS disabled 3=RSCS disabled, RSD disabled, RSF enabled, RSPS enabled B=RSCS enabled, RSD disabled, RSF enabled, RSPS enabled 4=RSCS disabled, RSD enabled, RSF disabled, RSPS disabled C=RSCS enabled, RSD enabled, RSF disabled, RSPS disabled 5=RSCS disabled, RSD enabled, RSF disabled, RSPS enabled D=RSCS enabled, RSD enabled, RSF disabled, RSPS enabled 6=RSCS disabled, RSD enabled, RSF enabled, RSPS disabled E=RSCS enabled, RSD enabled, RSF enabled, RSPS disabled 7=RSCS disabled, RSD enabled, RSF enabled, RSPS enabled F=RSCS enabled, RSD enabled, RSF enabled, RSPS enabled 720-02-02 xxxx x*xx Rem Start - Rear Defrost (RSRD), Rem Start - Steering Wheel (RSSW), Not In Park (NIP) 0=RSRD disabled, RSSW disabled, NIP disabled A=RSRD enabled, RSSW disabled, NIP disabled 1=RSRD disabled, RSSW disabled, NIP enabled B=RSRD enabled, RSSW disabled, NIP enabled 6=RSRD disabled, RSSW enabled, NIP disabled C=RSRD enabled, RSSW enabled, NIP disabled 7=RSRD disabled, RSSW enabled, NIP enabled D=RSRD enabled, RSSW enabled, NIP enabled -
I believe he is referring to the remote start menu on the left IPC. Vehicle-->Remote start-->Climate Control--> Auto / last setting That menu seems to be greyed out now and not accessible. -
Forscan to enable tow lights
ONEDGE16 replied to mr_jason's topic in Cargo, Hauling, Roof Racks & Towing
did you check the fuse box and confirmed you have the "Trailer lighting Module Fuse" Fuse # 78 - 40A M Case Fuse. (Owners Manual - P 272) -
Illuminated door sill retrofit
ONEDGE16 replied to scorpionking0102's topic in Accessories & Modifications
The "Ford Performance" door sills on the ST are not illuminated. -
The instrument cluster swap has already been done. Not a lot of info though in the install and programming.
No, the Ford molded ones will not fit the ST.
Minimum for 15+ edge is 18" rims
Vynil wrap might be faster and cheaper
Recall order 19B11 - Adaptive Headlamp Software
ONEDGE16 replied to Tedseed's topic in Recalls, TSBs & Warranty
related to Adaptive Headlamp -
Got it as well.
I'm experiencing a vibration around 70/80 kph. Started once I switched from winters to the 21" all season. most probably balancing issue. No noise or anything else. The 21" all season are still brand new since i got the car in Feb and switched to the winters right away. Have it booked for dealer visit next week
Congrats and she is a beauty, except she's not a 2019, but a 2018.
No need to disconnect the microphones. Youcan easily do it using Forscan. See following thread:
Dealer wants me to trade-in my '16 Titanium, but...
ONEDGE16 replied to 2FAST4U's topic in Buying, Leasing & Ordering
MSRP is in the 55-60 K, but dealers and Ford have rebates. My current dealer has an ST listed for a bit under $50K CAD. So if your dealer really wants your Titanium, they can give you a deal. The one below has the 401A package, 21" black rims and is White platinum (although their website says Silver the Window sticker says white platinum). Basically fully loaded for under $50K. -
If you absolutely want the V6, go for the ST. it is though a V6 ecoboost and not a naturally aspirated V6. The naturally aspirated is no longer available on the edges. I understand you don't like the black appearance on the window trims but you can always have it wrapped in chrome. Plus depends on the dealers, there are some sweet deals available you can get it for less the $50.000 CAD. -
you are correct, it was introduced starting MY 2016 on SE trims - Auto Start-Stop Technology is included on SE 100A with FWD (not available on SE 100A AWD) 2016 Edge Order Guide-3.pdf -
2015-2018 EDGE SE trim level is the only trim that came with the Auto start-stop feature. -
That was the first install following instructions but ended up changing it as I noticed if you run it under the wiring it makes it difficult to access the oil filter
There are a few videos on YouTube as well showing a Silver ST
