Everything posted by ONEDGE16
SYNC3 Map Updates Available On Line
ONEDGE16 replied to jmr061's topic in Audio, Backup, Navigation & SYNC
How long did it take for the install. The full 60 minutes advertised or less? -
The updated maps will cover all road changes up to Q1 2018. So if the major changes in your city were in 2017, they should be included in this update. Any map updates from Q2 2018 to current date would not be included in the update -
extracted from the site home page looks like they will still be about 1.5 years old *With This Update You Will Find: New Roads Speed Limit Updates New Points-of-Interest Updated Turn Restrictions and Traffic Changes There may be thousands of navigation data points changing every day, but we’ll help you get there with care. *Data points above represent the changes in the HERE Map Database between Q1 of 2017 and Q1 of 2018. Exact data may vary by product. -
Downloading my map updates right now (10.9 GB). Free for online download (complimentary option), $40+shipping for USB. -
Aftermarket Grille options for 2019
ONEDGE16 replied to cardnilogical4417's topic in Exterior & Body
it is black on black, but still will retain the overall shape of the ST lettering. Not very noticeable as the front ST badge is relatively small. -
The ST on the grille is attached with double sided adhesive and can be removed. A bit of heat from a hair dryer, some dental floss and goops remover to clean up the left overs from the double sided adhesive and it's all gone. Other option is to cover the ST with a small piece of gloss black Vinyl wrap. -
2019 Edge Climate Control
ONEDGE16 replied to canmark's topic in Interior, A.C., Heat, Interior Trim
By default you only get the heated steering wheel on the screen. Cooled/heated seats have physical buttons on the main centre console. If you want then on the main screen, you can add them using Forscan. -
BXP. I don't have the original picture as it was posted by Sage, but here's what it reads : -------------------------------------------------- Comment From: Ford Comment Date: Apr-08-2019 12:42:07 Jonathan, After additional research, we identified that there are programmable parameters listed in the Active Noise Control (ANC) and Engine Sound Enhancement (ESE). Attempt to disable the ANC/ESE feature by using the programmable parameters within IDS by going to Module Programming > Programmable parameters > DACMC/ACM. If the system is not capable of being disabled through the programmable parameters in IDS, then the ANC system should be able to be deactivated by disconnecting one of the noise cancellation/control microphones; as shown in wiring diagram cell 132-7. ---------------------------------------------------
If the dealers tells you it's not possible, you can reference the thread below. The screen print within the first post of the thread has instructions from Ford on how to access and disable the ANC system using IDS, and the workaround if they are unable to do it via IDS
They should just deactivate the "Active Noise Cancelling system". They can do that using their IDS software. You can also do it yourself using Forscan ACM 727-01-01 xxxx xXxx xxxx X=0 --> Disable or X=2 --> enabled Usually this Forscan mode is used to disable the Engine Noise Enhancement (fake engine noise piped in) but it disables the Noise cancelling System as well.
here's another youtube video that shows the simple procedure: as for tools, you can use a screw driver as shown in the video, or get a trim removal kit: https://www.amazon.com/Tresalto-Auto-Trim-Removal-Tool/dp/B01L8GHB7O https://www.amazon.com/Removal-Pliers-Fastener-Remover-Storage/dp/B07HRNKY8P/ref=pd_lpo_sbs_263_img_0?_encoding=UTF8&psc=1&refRID=R9242NHKR4VJ7JRFJ31W
Third post in this thread he mentioned, unless he meant Sync 3 V2.0 upgraded to Sync3 V3.0 In any case, the SSM quoted by the tech says that V 2.0 is required for it and not V3.0 - but it does mention an update to APIM could be needed. Sync 3 V 2.0 was release July 2016 and was the first version of Sync 3 to support Apple Carplay and Android Auto SSM 46561 - May 3 2017 4769 - 2016 Ford And Lincoln MKX - SYNC 3 And Navigation - Apple CarPlay And/Or Android Auto - Customer Pay Upgrade Available Some customers with 2016 Ford/Lincoln vehicles with SYNC 3 and Navigation may request an upgrade for Apple CarPlay or Android Auto. In General settings and about check if v2.0 is present. If V2.0 is present no software update is needed. Apple CarPlay requires a new Media/USB hub to be installed. Refer to GSB for Apple CarPlay Android Auto upgrade. Follow WSM, Section 415-00 to update APIM if needed. After Installation Complete pop-up, follow PTS instructions and perform a complete ignition cycle by turning the key off for 5 minutes which is critical for a successful installation. The software and hardware upgrade is customer paid as it is not a warrantable repair per the Warranty And Policy Manual, Section 3, Warranty Coverages – SYNC. G0000135.pdf
Most probably got that answer back cause the search/inquiry in the oasis system is based on the Car VIN and as built info, which would have indicated Sync 3 not being installed on the vehicle. Since you've done the upgrade yourself, you just need to get the USB HUB and do the swap attached is the repair shop manual for the media hub Media Hub.pdf
Mini spare is different then regular rims. Regular rims will only take 18" and over
The issue with the Ford molded Rear Splash Guard not fitting is not new to the 2019 ST. It was there since inception for the 2015+ MY. It does not fit the 2015-2018 Edge sport. They were only designed to fit SE, SEL & titanium trims.
Changing 2019 Edge's weak single horn to dual horn
ONEDGE16 replied to 9mmbullitt's topic in Accessories & Modifications
Did the switch today. Took about 15 minutes total. What a difference! Thx for the video tutorial. -
Interresting! They won't warranty a dual horn setup if done outside dealership or as replacement of a defective single tone? Wouldn't they warranty the part itself? What could the swap tk a dual horn cause if the swap procedure is done properly? -
Just had a road trip, mainly highway with a bit of back coutry roads. Average speed about 110 KPH. Fuel consumption
There are a couple of SSM for d has issued for this issue and others: April 11, 2019 MANUFACTURER COMMUNICATION NUMBER: SSM 47925 Components: ELECTRICAL SYSTEM, EQUIPMENT NHTSA ID Number: 10159506 Manufacturer Communication Number: SSM 47925 Summary SSM 47925 - 2019 Various Vehicles - SYNC 3 - Infotainment Screen Concerns, Wi-Fi ConnectionMessage, Rear View Camera Operation Some 2019 vehicles equipped with SYNC 3 may have the following intermittent symptoms: a Wi-Fi connection pop up every key cycle, frozen unresponsive screen, a solid blue screen when moving forward at speeds above 10 mph, the rear view camera remains on the screen at speeds below 10 mph, or poor App performance. To resolve this concern, check for a SYNC software update under the OASIS Tab SYNC selection. If an update is available, update the APIM software per Workshop Manual (WSM), Section 415-00. Follow the onscreen instructions provided by the programming process. To verify success after programming, turn the key off with the dooropen for 5 minutes. Perform this SYNC programming before taking any other repair steps. For claiming, use causal part 14G371 and applicable labor operations inSection 10 of the SLTS manual. APPLICABLE VEHICLES March 5, 2019 MANUFACTURER COMMUNICATION NUMBER: SSM 47846 Components: ELECTRICAL SYSTEM NHTSA ID Number: 10156564 Manufacturer Communication Number: SSM 47846 Summary Some 2019 Mustang, Continental, Fusion, MKZ, F150, Transit Connect, Ranger, Edge or Nautilus with SYNC 3 may have the following intermittent symptoms: a solid blue screen when moving forward at speeds above 10 mph, the rear view camera remains on the screen at speeds below 10 mph, or inoperative infotainment applications. To resolve this concern, check for a SYNC software update under the OASIS Tab SYNC selection. If an update is available, update the APIM software per WSM section 415-00. After the complete pop-up appears, remove the USB flash drive and install it into the IDS tool to update the Ford database. Perform a complete ignition cycle by turning the key off for 5 minutes, which is critical for a successful installation. For claiming, use causal part 14G371 and applicable labor operations in section 10 of the SLTS manual.
I guess these are US prices. I paid $54,450 CAD out the door (tax, fees, registration....included) (that's about $41,360) . Got 401A, Cold Weather + 21"rims (performance brakes not available in Canada).
It only fixed the remote start issue. Not the back lumbar section of the seats heating/cooling and cooling fan too loud. They still have to fix that one. There is SSM 47814 out there but doesn't seem to address it either. February 19, 2019 MANUFACTURER COMMUNICATION NUMBER: SSM 47814 Components: ELECTRICAL SYSTEM, SEATS NHTSA ID Number: 10156883 Manufacturer Communication Number: SSM 47814 Summary Some 2016-2019 Explorer, 2016-2018 MKX, 2019 Edge/Nautilus, 2017-2019 Fusion/MKZ, and 2018-2019 F-150/Mustang/Expedition/Navigator vehicles equipped with climate controlled seats may exhibit a buzzing noise from the front seats, front seats too warm, and/or inoperative climate controlled front seats. DTCs B14BA:13, B1154:4B, and/or B14B9:13 may also be present. This may be due to loose terminal pin fit on the driver seat module (DSM) connector C341D (16 pin). If a loose terminal pin fit condition is found during normal diagnostics per Workshop Manual (WSM), Section 501-10, a new service pigtail connector (part number 3U2Z-14S411-BRAB) is available. Refer to Wiring Diagram, Cell 119 to make sure C341D is a 16 pin connector and not a 20 pin connector. Refer to Wiring Diagram, Cell 5 for the recommended splicing procedures.
Took the car in to the dealership yesterday to get the Adaptive Headlamps recall done, at the same time asked them to look at the climate seats for a couple of issues: 1- with remote start, only driver seats come on (heat/cool) on 2- only the bottom part of the seat function, the back lumbar area not cooling/heating 3- when cool is on, the seat fan is loud enough to hear it with the radio on Gets a call in the afternoon to let me know that they need to replace BCM. Here's what the tech put on the work order
Recall order 19B11 - Adaptive Headlamp Software
ONEDGE16 replied to Tedseed's topic in Recalls, TSBs & Warranty
I had the recall done and they are working. Still dealership did not add the Adaptive headlamp menu to left IPC as indicated in owner's manual Page 105. Tried doing it wit Forscan using the codes from the F150 Forum, but had partial succees. The adaptive headlamp menu is added, but greyed out - cannot select or deselect it also adding cross traffic, it adds it under the main lighting menu and not under
