Everything posted by ONEDGE16
19 Titanium Heated Steering Wheel
ONEDGE16 replied to basment's topic in Interior, A.C., Heat, Interior Trim
The stearing wheel on my ST gets so hot it would almost burn my hands. -
I would be more worried about the rust then figuring out the part.
Changing 2019 Edge's weak single horn to dual horn
ONEDGE16 replied to 9mmbullitt's topic in Accessories & Modifications
This for the 2015-2018 but it's the same for a 2019 -
Some of us already replaced the weak horn. Easy and cheap fix and makes a huge difference
I have a 2019 ST and it does not have rear seat belts warning chimes (seat-minder). Only front driver and a passenger seat belts. Even checked the manual and no mention of the rear seat belts.
Mirror replacement
ONEDGE16 replied to mrmikesdeuce's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
mirrors are sold seperatly: mirror assembly: FT4Z-17683-AA mirror glass: FT4Z-17K707-G mirror motor: AU5Z-17D696-A etc.. The matching paint cover can be removed from your existing mirror and transferred over to the new assembly. it's holding to the assembly with 4 tabs. Go to your dealer parts dpt and show them the broken part and they'll tell you if it's available on it's own. you can also check online any dealer site that has a parts catalog online. -
and here's some reference sites for spreadsheets available out there (as listed on the first tab of the Explorer spreadsheet) Name Source Link Decimal to Hex Converter http://www.asciitohex.com/ As-Built Data from Ford Ford https://www.motorcraftservice.com/AsBuilt/ FORScan How-To DanMc85 http://www.2gfusions.net/showthread.php?tid=4573&pid=80488#pid80488 SYNC 3 APIM Reference 2gfusions.net https://docs.google.com/spreadsheets/d/1sPYdxO3XHZ1Uz1LngcQpIj4Xu-vDu1yzZyr_B1ueGwM/edit#gid=0 Explorer Forum - FORScan explorerforum.com http://www.explorerforum.com/forums/index.php?threads/new-forscan-update-allows-module-programming.442848 Tire Size Calculator on Google Docs forscan.org https://docs.google.com/spreadsheets/d/1mWnuQZlDTUGjKjmJje1QJIR8Z2c7Kf8KBZxKnw_8EqU/edit#gid=0 2013 PI Sedan briansbench.com http://briansbench.com/2017/02/25/unlocking-features-on-the-2013-ford-police-interceptor-sedan-taurus/ 2011-2018 Explorer explorerforum.com https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2011-2018_Explorers 2011-2015 Explorer explorerforum.com https://docs.google.com/spreadsheets/d/1JHLK2oCBe-E5om9VNeY6e3NwboO9Em0dDBZIgUVyGxc/ 2015-2017 F-150's f150forum.com https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466 2013+ Ford Fusion 2gfusions.net https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true 2015+ Mustang S550 mustang6g.com https://docs.google.com/spreadsheets/d/1-gytuV9qPfxvLLcFBIl6nt9h5MGW-NWEPc04cN-ro60/edit#gid=0 2015+ Mustang GT350 mustang6g.com https://docs.google.com/spreadsheets/d/1k0ZBnLT5CnHuL6BbkKg0AxhCmNlE_0Zev3zVnyz-5_A/edit#gid=0 2016 Super Duty powerstrokearmy.com https://docs.google.com/spreadsheets/d/17e_PIE5s3H266gWgSG7xdFLGKxIr1-K_RwrIx4qIAtI/edit#gid=882975515 2017 Super Duty powerstrokearmy.com https://docs.google.com/spreadsheets/d/1qf2gYgkhmsX-dnFO3Ki0nYUvr7aeLKsHsA0WxhDns1s/edit#gid=0
- 9 replies
- abs
- traction control
This is taken from the Ford F150 spreadsheet and works on the 2015+ Edge 724-01-01 xxxx x*xx xx 0=1 flash & OUC false 8=4 flashes & OUC false 1=1 flash & OUC true 9=4 flashes & OUC true 2=1 flash & OUC false A=5 flashes & OUC false 3=1 flash & OUC true B=5 flashes & OUC true 4=2 flashes & OUC false C=6 flashes & OUC false 5=2 flashes & OUC true D=6 flashes & OUC true 6=3 flashes & OUC false E=7 flashes & OUC false 7=3 flashes & OUC true F=7 flashes & OUC true
- 9 replies
- abs
- traction control
Cell phone app to remote start '19 Edge?
ONEDGE16 replied to 2FAST4U's topic in Alarms, Keyless Entry, Locks & Remote Start
Do you have a Ford Owners Account? If yes, you can use the same credentials for your Ford Pass app. If not try creating an owners account and set up your Ford Pass through the owner's site. Owner.ford.com -
245/60R18
2016 Edge offset is 52.5. The snowflakes will fit. Here's a picture of a 2019 ST with the snowflakes on
you'll need an adapter: https://www.amazon.ca/UGREEN-Adapter-External-Stereo-Headset/dp/B06XP5R449/ref=pd_bxgy_147_img_3/134-9934936-2876707?_encoding=UTF8&pd_rd_i=B06XP5R449&pd_rd_r=aed271e4-db60-476d-b9e2-ab62de1ad2a4&pd_rd_w=hpGyw&pd_rd_wg=93ysd&pf_rd_p=48fa4823-918c-4290-bdea-b573af9832e2&pf_rd_r=2RZE30JDW8D1X8JTJ68C&psc=1&refRID=2RZE30JDW8D1X8JTJ68C https://www.amazon.ca/TROND-External-Adapter-Integrated-Microphone/dp/B07L56C28R/ref=sr_1_3?gclid=CjwKCAjwxaXtBRBbEiwAPqPxcFyvuefeLKkZGS06m7zKYcPiz2qDatlYv40Qw3d2xPtzdF3oxCcbshoCJpAQAvD_BwE&hvadid=220844030587&hvdev=c&hvlocphy=9000791&hvnetw=g&hvpos=1o1&hvqmt=e&hvrand=1274572989873804924&hvtargid=kwd-316357140363&hydadcr=4651_9337947&keywords=usb+to+aux+female&qid=1571385118&sr=8-3
For Sync 3 , the latest software version available is 3.3 To check for installed version, settings, about sync
I recommend you follow the discussion on this subject on the thread below. it has the most up to date info on the transmission issues and some workarounds. For me, I had done the original TSB, then clearing the adaptive learning cache using forscan and s far been running relatively smooth.
SYNC3 Map Updates Available On Line
ONEDGE16 replied to jmr061's topic in Audio, Backup, Navigation & SYNC
Tried that too. No luck on the 19 ST. In fact plugged in the USB this morning while out for a drive, 40 minutes in, tells me all done and I can remove the USB. Continues driving for another 30 minutes no additional updates or messages -
Tried the update on my 19 ST last week and again this weekend but no changes; it continues to display the previous "About" information - i.e NA 1 17 Map version and same gracenote version. Tried 3 different times, even re-downloaded the software just in case. still no changes to the original "About" info. What is odd is it took only about 35 minutes to give me the restart message and after the updated is finished message. Think it's not taking. I'm running Sync 3.0 Version 3.3. I was going to do the updates on the Wife's 2018 Escape TI this weekend to see if it's specific to the 2019; but she got T-boned/rammed by F150 who ran a red light on Wednesday. So no escape for now. -
16 Edge Sport - Cannot update Sync - Ford Website
ONEDGE16 replied to EdgeDet's topic in Audio, Backup, Navigation & SYNC
Glad to hear all worked out. Now for me to do the map updates on my ST -
you'll be fine once you update your Sync from Sync 2.0 to 3.0 version 3.1 to 3.3 are minor updates to Sync 3.0 Minimum requirement for the map updates is the Major version Sync 3.0 FordInstructionsSyncPre Sync3.2.pdf -
Remote Windows
ONEDGE16 replied to seanmarshall's topic in Alarms, Keyless Entry, Locks & Remote Start
Forscan will not allow global close/open on the rear windows or moon roof. It will only allow you to add global close on the front windows. -
Programmed mine and no issues. First it will prompt You to enter the Factory admin code that came with the car, then it will prompt you to set your personal code and confirm your personal code You cannot change the default Factory code. you can just create additional ones.
I usually use a leaf blower to flush as much of the water out, then fold the mirror in, manuallly dry, fold it out the opposite way and manually dry again
Known issue with TSB. Ford working on it
July 22, 2019 MANUFACTURER COMMUNICATION NUMBER: SSM 48095 Components: POWER TRAIN NHTSA ID Number: 10163590 Manufacturer Communication Number: SSM 48095 Summary Some 2019 Edge/Nautilus vehicles equipped with an 8F57 transmission may exhibit harsh engagements when shifting from PARK to REVERSE, PARK to DRIVE and or REVERSE to DRIVE. These harsh engagements may result in an engagement clunk from the driveline. Do not attempt any repairs at this time. Engineering is investigating, monitor OASIS for updates. 2 Affected Products 1 Associated Document Request Research (Services fees apply)
