Everything posted by ONEDGE16
Changing 2019 Edge's weak single horn to dual horn
ONEDGE16 replied to 9mmbullitt's topic in Accessories & Modifications
Both the same no difference. That's what my parts guy told me when I did the switch and ended up ordering for me the level 2. -
HELP!!! Pop/clunk in front end!!
ONEDGE16 replied to Brook S's topic in Brakes, Chassis & Suspension
Has he replaced the strut mounts? -
My 2019 ST has it. It's standard on the 2019 STs. It's also standard for the front camera as well. Put your car in Reverse and press your right stock down as if you wanted to spray windshield fluid on your tailgate window. you will see the rearview camera being sprayed form the built in washer. if it does not spray the rear camera, either it's clogged or not getting any water. Read a case (not sure if it was here or on Facebook Group) the owner had the tubing leading to the rear view camera pinched. it runs under the door sills onthe passenger.left side of the vehicle. below picture shows you where the camera washer is.
Pas de probleme Claude. You can still start with the 3M and add the stainless steel sills on top. After all, most of the after market sills are held by double sided adhesives.
Try these guys, looks like they offer some customization https://aoonuauto.com/products/ford-led-door-sill-entry-guard-light-f-150-fiesta-focus-series?rq=yr_2019~mk_ford~md_edge The other option would be to wrap the sills with 3M clear film.
Check these ones: https://www.amazon.ca/Lining-Chrome-Cover-Scuff-2015-2019/dp/B07J4FB8NN/ref=sr_1_2?keywords=ford+edge+chrome+door+sills&qid=1580152203&sr=8-2 https://www.amazon.ca/FANFAUTO-Stainless-Steel-Protector-2015-2019/dp/B07TG9N59N/ref=sr_1_39?crid=3PRQECJ14LARR&keywords=ford+edge+door+sill+protector&qid=1580152307&sprefix=ford+edge+door+sills+protec%2Caps%2C158&sr=8-39
ONEDGE16 commented on Xtra's gallery image in Member Photo Albums
Brakes on The Ford Edge St are weak
ONEDGE16 replied to JayST's topic in Brakes, Chassis & Suspension
In addition to upgrading the brakes. He should also use engine braking while going downhill: put the car in S mode (sport mode) and use the paddle to downshift and engine brake while going downhill -
"hidden" storage in 2019?
ONEDGE16 replied to IcyFridge's topic in Interior, A.C., Heat, Interior Trim
Few reasons it's there: 1- start the car in case your keyfob is dead 2- display factory set 5 digits code 3- program additional keyfobs (need both orohinam keyfobs in the car and you can program additional ones) -
Edge #2. 2011 SEL & 2019 SEL AWD
ONEDGE16 replied to blkmesamtman1's topic in 2019-Current Edge & Nautilius
This is for the 2019 Titanium but should fit the 2020 as no changes were made on the engine. This is from levittownfordparts.com site
Congrats. Sweet looking ride. Just a question is it a 2016 or a 2018? If it's build in 2018, it would be a 2018 not a 2016.
Aftermarket Grille options for 2019
ONEDGE16 replied to cardnilogical4417's topic in Exterior & Body
It's an overlay you install on top of the existing Grille. OP got it from Trim Illusion (Part No: ABS6498BLK - $ 395) https://iframe.autoaccessoryconfigurator.com/TrimIllusion&hook=iframe_user&layout=product_list Other option from e-bay https://www.ebay.com/itm/Fits-2019-Ford-Edge-Gloss-Black-Grille-Overlay-No-Front-Camera-/153621450565 -
Welcome. You might be interested in this thread
Have a samsung S10+ and charges fine on the Pad in my ST
You're mixing version 3.3 available through Sync3 updates site and version 3.4 that has not yet been released as a downloadable update but only available from factory on 2020 models
Sync 3 software version 3.0 build 19052 is the latest version. Sync 3 software version 3.4 has not yet been released as an update yet but is installed on 2020 models.
Don't recall if it was posted here or on Facebook FEWW or Ford Edge ST Nation group, but might help the tech with further investigation, diagnostics.
New colors for 2020..."Atlas Blue" and "Persian Green"
ONEDGE16 replied to 2FAST4U's topic in Exterior & Body
Have seen the persian green on the 2020 escape. Looks more like a dark blu-ish -
You would also need to reprogram the key fobs to the new bcm. Your new bcm should also have with it a new 5 digits code for the door keyless entry.
liftgate interior panel
ONEDGE16 replied to samxander's topic in Interior, A.C., Heat, Interior Trim
what Year and Trim is your Edge??
