gloria's edge
About gloria's edge
gloria's edge's Achievements
Perhaps this will help.....see attached file. Edge_MKX_08 Battery.pdf
Here is what I was told....unless your vehicle is experiencing any type of heat loss or lack of heat, this field action does not apply to you. The obvious best way to know is by turning the heat on in your car. If you have perfectly good heat coming out (that's the case with me), then there is no need to bring the car in under this field action. I was a bit disappointed since I noticed the antifreeze/coolant in my vehicle is very dark and probably could use a flush/change. Hoping to have had this done under this field action but, I'll have to have it done on my "dime". Best Regards,
Not sure if this issue your having is related to this recent field action from Ford....http://www.fordedgeforum.com/topic/19433-cooling-system-corrosion-recall/?p=143431. Here's some more information on this...http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=182324
I have an appointment with my local dealer to have this looked at
Thanks for the research and posting with more details on this!
Fellow Edge Members, Just got the following Field Service Action from Ford..... You can call Ford at....1-866-436-7332 to see if you vehicle qualifies for this action. Through my call with Ford and understanding, Ford will evaluate your cooling system to determine if you need a cooling flush at no charge to you. FSA Title: COOLING SYSTEM CORROSION Field Service Action Number: 09M04
A bad fuel pump and a how-to on an 09 Edge Limited w/ AWD
gloria's edge replied to Jsmith10000's topic in 2009 Edge & MKX
Thanks for the confirmation! -
Sorry about this misinformation...I meant the fuel filter not the pump is it serviceable? I've read the fuel filter is not? -
May I ask why?
Thanks for the reply! I noticed two "openings" where I thought one would snap into but, was'tn sure.
Hello Everyone, Purchased a 2008 Ford Edge SEL AWD with approximately 68k miles on it and a 3.5 engine. As strange as it may be, I've been trying to figure out what's wrong with the look of the engine when it dawned on me the engine access/appearance cover is missing. Does anyone have any thoughts on where I can buy one at a reasonable price? Look forward to your replies! George,
vibration coming from driver & passenger side under board
gloria's edge replied to gloria's edge's topic in 2008 Edge & MKX
Yes, I just purchased the car about a month ago with approximately 67k miles on it and was "smart" enough to buy an extended warranty. So glad I did! -
Traction Control and ABS Light Comes on
gloria's edge replied to Jimmy Sosinski's topic in 2008 Edge & MKX
UPDATE: Just picked up my 08 Edge. Running great now! Issue causing the problem (according to my local dealer who did the work): The tone ring on the left front wheel went bad. Unfortunately, in this case the entire front left drive shaft had to be replaced. The tone ring is wielded on to the shaft and the only way to replace it. Consequently, the vibration issue I was also having was related to the shaft. Now that the shaft was replaced, it runs great. Thankfully, my extended warranty covered this. Was able to solve two issues for the price of one. Hope this helps someone with a similar issue! -
UPDATE: Just picked up my 08 Edge. Running great now! Issue causing the problem (according to my local dealer who did the work): Left front drive shaft. I was having an issue with the traction control, ABS and Wrench light coming on after 65. The issue causing this was the tone ring went bad. Unfortunately, the entire front left drive shaft had to be replaced. The tone ring is wielded on to the shaft and the only way to replace it. What helped with the lights coming on was the ECM throw out a C1233 code. Consequently, the vibration issue I was having was related to the shaft. Now that the shaft was replaced, it runs great. Thankfully my extended warranty paid off and covered this. Was able to solve two issues for the price of one. Hope this helps someone with a similar issue! -
UPDATE: Just picked up my 08 Edge. Running great now! Issue causing the problem (according to my local dealer who did the work): The tone ring on the left front wheel went bad. Unfortunately, in this case the entire front left drive shaft had to be replaced. The tone ring is wielded on to the shaft and the only way to replace it. Consequently, the vibration issue I was also having was related to the shaft. Now that the shaft was replaced, it runs great. Was able to solve two issues for the price of one. Hope this helps someone with a similar issue!
- 15 replies
- powertrain
- drivetrain
(and 2 more)
