theoldwizard1
Everything posted by theoldwizard1
I scored some rims from a 2012 Ford Edge that I want to use for winters on my 2016. IIRC, starting in 2016 they changed the lug to 108mm from 114.3.mm (4.5"). While you can find this size adapter if you look non of them come with the requires M14x1.5 lugs and nuts ! Anyone know of a source for 5x108 to 5x114 - M14x1.5 adapters
When did Ford change the 18" rim from 5 on 4-1/4" to 5 on 110mm ? Does any one know the Hollander Wheel Exchange number for the 108 mm ? (It is not 10044 !)
I was charged for replacing 3 lug nuts because they could not be reused. When I got home, I discovered that more lugs nuts were damaged to the point that the socket that came with the car could not be used. The dealer agreed to replace 4 additional lug nuts at no charge.
The "seat" ( cone shaped taper at the bottom) is an "industry standard" 60° on both. I am not sure why the F150 lug nuts have that extra 1/4" - 1/2" on material above that.
How do I search for topics posted by a specific person ?
Well it looks like I will be replacing most of my lug nuts on my 2016 Edge. I have done all of my own tires rotation for the past 5 years and managed to only bugger up 2 nuts. I am using a Sunex flip lug nut set, which I recommend. The stock/OEM lug nuts require a 21mm socket. I know that some of the aftermarket use 22mm. A 7/8" socket will fit an OEM lug nut (7/8" = 0.875" ; 22mm = 0.866" ; 21mm = 0.826"), but I guarantee they will mess up the chrome cap ! Now here is the crazy thing ! The Edge lug nuts (ACPZ-1012-M) and the F150 lug nut (ACPZ-1012-B) look almost identical. Same threads, same socket But $4.18 vs $0.90
Parking brake limited function
theoldwizard1 replied to sjskowron's topic in Brakes, Chassis & Suspension
Same problem ! I need to check that routing before the other side fails. Anyone have a link to that YouTube video ? $350 out the door ! (Thank you for being a customer $20 for "shop supplies" !) -
Under engine splash shield push pins
theoldwizard1 replied to theoldwizard1's topic in 2016 Edge & MKX
The shield appears to be 6P013. The retainer in question is HS1/HC1/HN1, but the description does not match the part (IIRC !). -
The splash shield under the engine must be removed to do an oil change. It is held in place by either plastic push pins of screws into plastic inserts. Except for the back 2. I have not been underneath since the last oil change (7,500 miles ago) but I know one or both are failing and these are different than the others. They are square and are inserted into a square hole in the frame. Anyone know where I can find some of these without paying an arm and a leg ?
New Owner of 2016 Edge, what maintenance?
theoldwizard1 replied to TXHoss's topic in 2016 Edge & MKX
Sorry for being late to the party. PTU fluid and transmission fluid changes are not "required" maintenance, but are "feel good", cheap insurance ! If you are doing it make sure to ONLY USE GENUINE MOTORCRAFT FLUIDS ! You may have to get the PTU fluid directly from the dealer, but good auto parts stores stock (or can easily get) Motorcraft transmission fluid and engine coolant. Don't get upset about draining every drop of transmission fluid or even changing the filter. Even if you only get 50% of the transmission fluid out, because you are changing it so early, you should be fine. Transmission filters NEVER need to be changed. -
I am looking for a part number/source for the square "push rivets" that are used to attach the under engine splash shield to the chassis.
Admittedly, my old '98 E150 used 1/2" "course" thread buts. The Edge use M14 (0.549 almost 9/16") and I think they would be classified as "fine" (1.5 mm) threads. Fine threads can handle more torque.
The book says 162 lb. ft. My torque wrench only goes to 150 ! Why so high ? Mu old '98 E150 say 100 lb. ft.
Where is the oil pressure warning light ?
Oh well ! I can never keep MFT and Sync 3 separated ! As I said, it has the small screen for HVAC, radio and rear camera. Actually, that is when I realized the oil pressure light was "missing" ! "Door ajar" comes up as a overlay on the center display. -
The title says it all ! 2016 Edge SEL, without My Ford Touch (small screen).
Towing with 2.0L Ecoboost
theoldwizard1 replied to Hawgman's topic in Cargo, Hauling, Roof Racks & Towing
I concur on the AWD, especially when towing a boat (slippery ramps, plus the ramp shift more weight away from the the front drive wheels). If you get the 2.0 EcoBoost, be sure to feed it PREMIUM when towing ! It is weird that the 2.7L V6 EcoBoost can not be ordered with the Trailer Tow Option so it is limited to 2,000 lbs. I'll be it has to do with the fact that the 2.7L is only available on the Sport model with those (ridiculous) super low profile tires. -
Rear brakes not releasing completely
theoldwizard1 replied to JL6173olds's topic in Brakes, Chassis & Suspension
I had the same problem with a 2007 Fusion ! I do my own work, so through trial and error (several sets of rear pads), I think I found the solution, My current process for a suspect wheel(s) is to buy a re-manufactured caliper AND BRACKET ! This will also come with new pre-lubed guide/slide pins and boots. Stick with a known quality brand (Wagner, Raybestos, AC Delco), These are reasonably priced on RockAuto.com, after you return the core. For rotors and pad I have had excellent performance from Raybestos parts, but you have to buy the correct ones ! For rotors, stick with the Raybestos Advanced Technology ones NOT the Professional Grade. Yes, they cost more, but don't seem to warp and the last few I have bought were either made in the US or Canada ! For pads, it is Raybestos again, but only their "Enhanced Hybrid Technology" ceramic pads. One of the reasons I like them is Raybestos sells Disc Brake Pad Drag Reduction Clips that help retract the pads ! Dealers will not use aftermarket parts, even if they are better so try to find an independent shop, especially one that will allow you to bring in your own parts as that will save you several hundred dollars. -
Front brakes not releasing
theoldwizard1 replied to superdavis78's topic in Brakes, Chassis & Suspension
I have owned and worked on several different high mileage Ford products that have had similar issues. Many have had problems with the slide pins not moving freely in the bore, even within a few months of being greased (first gen Fusion are notorious for eating rear brake pads). My current process for a suspect wheel is to buy a re-manufactured caliper AND BRACKET ! This will also come with new pre-lubed guide/slide pins. Stick with a known quality brand (Wagner, Raybestos, AC Delco), These are reasonably priced on RockAuto.com, after you return the core. For rotors and pad I have had excellent performance from Raybestos parts, but you have to buy the correct ones ! For rotors, stick with the Raybestos Advanced Techmology ones NOT the Professional Grade. Yes, they cost more, but don't seem to warp and the last few I have bought were either made in the US or Canada ! For pads, it is Raybestos again, but only their "Enhanced Hybrid Technology" ceramic pads. One of the reasons I like them is Raybestos sells Disc Brake Pad Drag Reduction Clips that help retract the pads ! -
We just picked up a new Edge SEL and so far I am very happy with it ! The 200A (cloth interior) option package had everything we could ask for. Well, we did add the "roller shade" cargo cover for the back ! This the first SUV/CUV we have ever owned. Relatives have owned several from small (Escape) to huge (Expedition EL). We traded in a Fusion so this seemed to fit us "just right". The biggest negative was probably the limited choice of color and limited availability in the metro Detroit area. I made certain the wife was "actively" involved in choosing the vehicle. I drove company vehicles for years so she really has not had much input for over 20 years. The "Magnetic" (dark gray) was sort of the only choice left after she crossed off all of the other colors. If the 2017s come in Burgundy Velvet (like the 2017 Fusion) I am in trouble !
- 1 reply
- 2
Well, by now I am sure that a few people have purchased an Edge with the 2.7L EcoBoost, so how about some feed back ? I am disappointed that Ford does NOT recommend this engine for towing ! My guess is that the HP/Torque output of the 2.7L EcoBoost is too much for the 6F50 and they don't want to drop in the 6F55.
