13EdgeSport
Everything posted by 13EdgeSport
  1. I'm not sure why people aren't filling it up all the way. edit Divide by 12, carry the 1.
  2. https://m.youtube.com/watch?v=jNP3V_EZSsg
  3. If you go to the Dealer with a completely cooked PTU, that smells like burnt gear oil and sulfur (rotten eggs,) they'll replace the entire unit.
  4. Album: http://imgur.com/a/zsuZd Before: After: Daytime with the lights on: So far these look great! When I placed my order for the old style lights, I received this message from Dan almost immediately: With this image: I told him send me the news ones ASAP! I really like the -new- dark red color and the install is super easy, they include instructions with the taillights, but it's very basic. If you've changed an automotive bulb before you can do this install in about 10 minutes.
  5. It was a compromise with my Wife. We both like performance vehicles, but we hadn't had something "nice" to drive for a while, and weren't ready for a "sports car." The Edge Sport has all the looks and the engine to back it (even though it weighs 4,000+ pounds.) I consistently get 20+ MPGs, enjoy the interior, and nothing matches it's looks for the price point.
  6. Probably really easy, but would cost more and take up more time. Wait till I get my black worm clamps and it'll look "almost" factory.
  7. I haven't noticed too much difference in sound. I recently changed my oil and did the mod. I can tell acceleration is smoother, and easier to get up to speed. I have my Afe filter coming in tomorrow, and I also ordered some black hose clamps. I'll keep you guys updated.
  8. Bumping with pictures. The stock clamps only need the little tooth bent back, that's holding the stock clamp on, and then it'll just fall a part. Do not over tighten the new rubber caps, just tighten till you feel some resistance. This is under $8 in parts, and less than 10 minutes time.
  9. I was still thinking about this. If someone did want to take legal action, wouldn't it be easiest to prove that the fluid doesn't last for 100,000 miles? If the dealership isn't willing to change the fluid, or if Ford is telling Dealerships it isn't needed, doesn't this escalate the issue? Then on top of that it seems pretty common to "cook" the PTU fluid in to black sludge by 30,000-50,000 miles, where the entire PTU fails due to heat? The solution is pretty simple.
  10. @FordService, I do feel Ford needs to acknowledge this. This would be my ideal situation, if Ford was to take action: First by adding the PTU fluid change and maintenance to the scheduled (reoccurring) 30,000 mile service. With recommended checkups scheduled every 10,000 miles. Second by blanket covering all PTUs (up til the date the first steps are taken) with extended coverage for repair and/or replacement, up to 100,000 miles. This would mitigate almost all of their customer service issues, legal or otherwise.
  11. Where the handle of the wrench is pointing is where you stick your hands, and feed the tube. There is plenty of room on that side. You basically reach up and over the subframe and the heat shield. I did it, it didn't get on anything as you can see, while lying on my back in the garage. These pictures were taken while I was laying on my back, looking straight up at the PTU, in my garage. I have the 3.7L.
  12. I was meaning to get a picture for one of the other guys. I'll try to get one tomorrow.
  13. The best I've been able to get is about 23mpg, with 20 being my lowest. That's with the last 3 fill ups, three weeks of ownership. My lowest mpgs have been when I completely floor it, which surprisingly drops mpgs drastically.
  14. Hopefully you still have a nice rental... I may purchase the extended warranty when I get closer to the end of the 5/60.
  15. The rear diff caused me many more problems than the PTU. The PTU has so little fluid, if you're lucky it won't be burnt goo, the fluid should just pump out easily, and refiling should happen without a mess. I should post a picture of my garage floor, with all the splatter from the rear diff, and no mess from the PTU. (I'll do a better job with the tarp placement on the rear diff next time.)
  16. I hope I can avoid this, but I'm glad dealers are stepping up to take care of this.
  17. I can take a picture if needed. I have the 3.7l, so the exhaust could be different, but I still had room to work around it. Picture this: Laying on your back looking up at the drain plug. You can place the handle of the ratchet facing towards the front of car, while positioning the 3/8" head of the wrench so it slides in to the drain plug. It should only be torqued to 25-30ft/lbs, so it should loosen fairly easy. When looking at the PTU, and drain plug, there was a sub frame in between my body and the PTU. I was able to reach down (towards my legs) and around (above) the sub frame, with plenty of room to feed the drain hose.
  18. I did use marine grade 80w90... Two birds?
  19. Just finished the PTU and rear differential. My PTU seal was serviced last June, I'm certain the fluid was fully changed then. So when I changed the fluid it came out dark, but was still easy to pump out. I was worried about over filling, but I think I added about 12oz. The rear differential fluid was grey and milky, and was much harder to pump out. I tried to use the 1/8" tubing to pump it back in but gave up and used some 1/4" tubing, which sped everything up. I'm not sure how full it was but I filled it till it drained out. I did check everything while I was under there, and my rear passenger CV housing seal is seaping a bit. My Edge is a CPO, and still under the 5/60 with 43,000 miles, is this something to worry about, or am I asking for more problems having them tear in to the differential? Doing the PTU was really simple, I didn't even need the 3/8" wobble. I just stuck the wrench up there. I laid on my back and had plenty of room for my hands.
  20. Has anyone heard from @FordService? Is that user legit? I'm going to service my PTU tomorrow.
