Dukhaykh
About Dukhaykh
1,262 profile views
Dukhaykh's Achievements
  1. Many thanks for your support and providing these valuable insights. Regarding the installation process, I found different way on the Youtube and it worked well with me without the need for drilling or removing the Ford emblem.
  2. Many thanks for your time and support. You are right on first point you mentioned about the signal format and compatibility. I figured out how to connect the camera cables with the OEM cables but somehow the video quality was not good enough. I ended up by wiring new cables to the new Android screen directly and it is working perfectly.
  3. ? Hey there, I want to connect an aftermarket camera on my OEM previous camera plug. Any ideas where I connect the power and video wires! I also found digram for Rear plug wiring diagram to help in this case. Any support would be appreciated.
  4. Your right, Update; I did remove the rear did and its axels. After that I balanced both my rear tires. Now everything is okay ?? attached how the car looks like without dif and axles ? Next project will be removing the PTU.? IMG_0824.MOV
  5. Hello, My Edge AWD, I took off the drive shaft to make it runs as a FWD. I am wondering now if it’s possible to remove the rear differential & axles without issues?! If it’s possible, are there any possible effects on car stability & traction etc; Thanks in advance ☺️
  6. Thank you all for your great advices. Hmmm, What about just installing one of the v6 turbo?! My be a rear mounted one. My main goal is to gain some power around 50hp ?
  7. I am thinking to change my engine soon due to many problems. But I want to know is it possible to drop a Taurus Sho engine on 2014 Ford Edge ?
  8. Thanks a lot Omar, Very glad to see these posts definitely these info will help me. ? I have a hope that this issue can be fixed by only programming the steering wheel module. will keep you updated.
  9. Thank you Omar for your feedback. Will read the post you shared and see what I can do.
  10. I have a 2014 SEL Edge. I have installed an Edge Sport steering wheel with (+/- Paddle Shifters). I have currently shifters (+/- buttons on the shift lever). After the swap, unfortunately I figured out that the Paddle Shifters on the steering does not work! Any idea how to get them work by using FORscan maybe? Do I need to make wiring modifications? Appreciate any input on this. Thanks.
  11. Tried that out but I it was very bad idea. Unfortunately this way didn't work and now I can't return it to the factory values! I keep getting error when I hit “Write”: "[17:12:41:891] Service procedure has been interrupted". After communicating with FORScan Support they replied; :(
  12. Thank you @omar302 for your reply This is a very disappointing ?
  13. ? Please follow me on Instagram page: @Fordedgefans
  14. Hi, Can I adjust the time of the Ford Edge 12v powerpoint timeout in 2014my? Would like the 12 volt power socket to go off after a set time, currently it's on permanently, any idea of this can be done ? Thanks
  15. @Special_K Thank you for your feedback, I am thinking also to find out some Mods by Forscan May be! I usually take off the ABS fuse especially during race ? because I can see the difference in power ✈️ . I have driven my car for almost a year without any problems. I even installed a switch inside my car connected to the fuse to turn it off/on easily ? The problem with the fuse when you take it off the ABS system will shut off too. I am thinking now to use my current switch setups on the back clutch instead of using the fuse. Fuse box attached;
