About buffaloedge
buffaloedge's Achievements
I'm looking to get my hands on some tint film for my headlights that are similar to the transition lenses on some eyeglasses. Where the the film darkens when exposed to the uv rays of the sun but lightens to pretty much clear under darkness or artificial light. Have any of you seen anything like this? I realize it may be expensive but I would like an alternative to my current smoked film I have on my headlights now. Any help, links etc..would be greatly appreciated.
Dipping the lower plastic def makes it smoother. I had no probs getting my vinyl rally stripe to adhere to dipped portion or bottom spoiler. I put probably 8-10 coats of dip on the rough plastic. Once you get to final 3 coats, I applied it real smooth by moving can in to maybe 3-4"of surfice I was dipping.
- 12 replies
- 2
- grille insert
- removal of grille inserts
- (and 1 more)
Thanks. I'm curious to see how it will hold up over the Buffalo winter too. Not that curious though, 80° here today and I don't even want to think about snow yet...HaHa
- 12 replies
- grille insert
- (and 1 more)
Thanks everyone for your replies! I ended up plasti dipping chrome grill, left on and masked around them. Also dipped my rims black and also the edge, limited and awd emblems. Also blacked out large ford emblems in front and back but didn't like it so removed them. Went with white dip on spoilers below front and back bumpers and also dipped the bottom of doors and rocker panels. Just added the carbon fiber rally stripe yesterday. Let me know what you all think.
- 12 replies
- grille insert
- (and 1 more)
Thank you. So removal of the bumper is necessary to remove and replace the grille inserts, huh? Gonna take me longer than i thought...
- 12 replies
- grille insert
- (and 1 more)
Hello fellow Edge enthusiasts. I just recently ordered the primed 3 piece grill insert described in the following link http://www.ebay.com/itm/2011-thru-2014-Edge-OEM-Genuine-Ford-Parts-Custom-Grille-Grill-Inserts-NEW-/161104896124?fits=Make%3AFord%7CModel%3AEdge I am going to have it painted. Debating on black or white (my limited is white). Any opinions on color? My big question is has anyone gone the grill insert method to change the color of their grille? If so, does these inserts fit over existing chrome or do you remove the original before installing these 3 pieces? If you do in fact remove the original, anyone have detailed instructions? Also, instructions on how to install the newly painted inserts either over existing grill or without existing grill. Any and all info would be appreciated. Thanks!!
- 12 replies
- grille insert
- (and 1 more)
Thanks for the suggestion, ls97. I did try that and left it off over an hour. No luck. Akirtby, you mean destroyed the smart junction box? All other directionals are working both front and back. Just drivers side front not working. Put a test light on it and nothing at the socket. Followed wire to just inside the cabin, where it comes in through firewall and no power either.
Need your help. I installed the V3 switchback signals for my 2011 edge. After installation, the drivers side front signal wouldnt work right. Now after I installed stock bulbs back in, the left turn signal won't work. Bulbs are good and after putting a meter to the turn signal positive wire, i seem to not be getting power. Anyone know what can cause this? All other lights are working, parking and alll other turn signals. Is there a relay, fuse, etc that would control just this one drivers front signal?
Oh, the color temperature is all the same on the LED lights but taking a denent photo I found is nearly impossible. They don't however have the same color temperature as my HID headlights though. I can control all of the lights with a two switches mounted near the drivers side door. The ground affect lights are never on while driving. I power them by tapping into the dome supervision, the mirror puddle lights. This wire was located under the driver side sill plate. I removed it, tracked the wire down and tied into that. The ground affect lights come on and go off automatically with the factory settings. Unlock doors/entry and exit. The switch install was pretty much a must as I wanted to be able to override the front LED's as they come on automatically at ignition start and turn off when I cut the ignition. I installed them in the upper part of the door sill piece while I had it off when tracking the dome supervision wire. I originally was going to install it on the dash like my previous car but there is now a steel plate there. I thought the upper sill was the next best option. Thanks for the comments, fellow EDGE fans!
