27Sport
Everything posted by 27Sport
This one is being delivered to my dealer next week that I'm picking up for the wife. http://www.windowsticker.forddirect.com/windowsticker.pdf?token=3fvQkN8zRNfe0SZjMrRVei5nc6fwApsHLhirHJmVtPtfcE7Yfq3GRctiPGsV9OHjhDA5cKE6he8vOYr8ZfKWhbEsLglxD4EYBW919AK4gq%2FRWjHQOKwFsSoIUsuRb8au9qIPFhPWYb%2Fp2XhobSmGSSiUvXd20%2FG75%2F8HQfosSmE%3D&ref=VL
Enhanced Park Assist with Side Parking Sensors
27Sport replied to blitz118's topic in Brakes, Chassis & Suspension
The right side sensors on mine like to freak out for some reason when an object is 10ft away or so but showing red on the screen, like when pulling up to a stop sign where I'm no where near being close to the curb. -
Tow package and hitch on 2015 Edge
27Sport replied to Mark Johnson's topic in Cargo, Hauling, Roof Racks & Towing
They are the same for all models but most people are a little hesitant to cut the lower bumper cover on the Sport to make it fit. -
Factor in shipping and they are closer to $300.
The all-season ones are close to $300 each, summer only ones are around $500.
Loosen filter cartridge cover to allow oil to drain down. Remove oil drain plug (plastic type and can be done by hand). Replace drain plug. Replace filter cartride and use new supplied o-ring. Re-install cartridge cover. Fill engine with oil. Allow 15 minutes for oil level to read correctly as there is a chamber where the dipstick goes in to that has to fill.
How exaclty do you scrape all the wheels that bad?
Tail light Condensation
27Sport replied to d0minicano's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Park it in the sun for a few hours, it'll dry it out. -
The tow rating on the Sport is 2000lbs, check the owners manual. Having the dealer install any of the listed items does not increase it's capacity. -
I recently picked up a set of the dark tarnished 21" wheels/tires and would like to know what the factory recommended pressure is that's listed on the drivers door sticker. Just curious if it's the same 35 psi as the 20" ones.
I noticed that the '16 Explorer is available with Smart Charging USB ports in the rear of the center console for 2nd row passengers. SInce this is more useful for my kids to charge their electronics than the standard 12v oulet, I decided to see if I could install one in my '15 Edge. I found a wrecked '16 Explorer online and had them send me the whole rear panel. I used the outlet cover, USB cords and the power inverter. Only had to connect 12v and ground and used the existing wires from the 12v plug I replaced. Just had to use a dremel to make the outlet cover fit. Took about 30 min total.
- 1 reply
- 2
The Sport does seem to launch better when power braking to 1500 (vs 2000) to build boost.
It's possible but you would have to get someone inside Ford to program it for you. So basically no.
Sync 3 requires a new screen, APIM, antenna cable and USB harness. Not to mention the programming to that specific vehicle.
Sport with 21" dark tarnished wheels.
I'll get them tomorrow if they're not posted by then.
Do not go by the people on the website chats, they have no idea besides the specs in front of them. Trust me, the seat backs are supposed to be cooled also. There are two fans in each seat, one in the bottom and one in the seat back. I've seen the dealer repair manual and it specifically states there are two fans. The repair illustrations also show two fans. It's a poor design with no way to get ambient cabin air to the seat back, and no way to exhaust it out. I have looked at my seats to see if there was a modification I could do to get cool air inside the seatback but there is no easy way to get to the fans. The whole seatback is basically sealed up. The F150 is easilly accessible with a zipper while the Edge is sewn up and uses metal rings to hold it down.
Actually you have it backwards, Too Good to Be Blue is coming to the Edge, not Kona. Both colors will be available on the Flex for '16.
Take it to the dealer, the more people that complain about the same issue the better chance it getting investigated and resolved.
Optional summer tires are Pirelli P-Zero. Same model as the summer tires on Mustang GT's.
The owners manual also tells you how to get the factory code to display in the information display. No trip to the dealer needed.
- 4 replies
- code
- access code
It also says to replace the blower motor with an updated part that has a redesigned air intake.
