27Sport
Everything posted by 27Sport
Do a search and find my write-up of installing the factory trailer wiring. Can be done fairly cheap, especially if you purchase the trailer light module from a junk yard or ebay. Any Ford trailer wiring module will work, it's just the mounting brackets that are different, which easily pop off. Only have to run a power wire to the under dash fuse box to make it work, all other parts and wiring are factory parts and plug right in.
Adding Trailer Hitch and Wirng to 2015 Edge SEL
27Sport replied to Dmtaurus's topic in Cargo, Hauling, Roof Racks & Towing
Yes, I already experienced this and explained previously. Takes maybe 30 min to get the 4-way plug working using factory parts and about 6' of wire to the under dash fusebox. -
Before You Shop Elsewhere......
27Sport replied to Gadgetjq's topic in Dealership & Vendor Experiences
Well that Prestone is the "real" Motorcraft stuff, just in a red container. To each his own though. -
Or you can buy the Prestone longer life coolant at the auto parts store for $15.99. It’s the exact same stuff as Prestone is the supplier for Ford’s coolant. It’s compatible will any and all coolant regardless of color. -
Forscan to enable tow lights
27Sport replied to mr_jason's topic in Cargo, Hauling, Roof Racks & Towing
If you were sitting in the passenger seat, peel down the carpet to the right of where your right foot would be. Between the plastic kick panel and the firewall. There are two large white connectors. It's the one on the right (closest to pass door). Brown/red wire is on the bottom part of the connector, near the edge. It's much thicker wire than the rest. -
While running the power wire I found the issue with the factory power wire (brown/red). There are two large connectors behind the carpet in the passengers footwell where the main body harness meets the under hood harness. The brown/red wire is on one side of the connector (body side), but not on the engine side. That means there is no wire from the under hood fuse box to the main connector. Instead of running your own power wire to the trailer module, you could cut the brown/red wire at the connector and attach your own power wire directly to that. Would only need about 3-4ft of 12awg wire from the connector to the under dash fuse box. I used a micro 2 add-a-circuit with a 20amp fuse into spot 29 for my power wire. -
Success!! I was finally able to get around to looking into why I was not getting power to the trailer plug at the hitch. I initially discovered that there was no 12v power at the factory trailer module. Turns out that even though fuse 78 shows power, it is not connected somewhere between the under-hood fuse box and the connector plug behind the cargo trim panel, even though the power wire is present in the back. I ran a length of wire directly from the battery to the brown/red wire at the trailer module to see if it was an easy fix. Turns out that is the issue. Trailer plug at the hitch now has power. Also, the factory plug can be accessed by removing the little storage compartment on the rear trim panel (pull up on the outside edge first). Don't have to remove the entire panel. I used some double sided tape to mount the trailer module to the sheetmetal next to the plug. I suggest cutting the brown/red wire about 3" away from the module plug to attach your power wire, then run it directly to the battery. Also, use 12awg wire and an inline 30amp fuse at the battery as that is what the factory harness uses. Summary of what is needed to get as close to factory as possible when installing trailer wiring. This also eliminates the need to get an aftermarket light module. The Ford Accessories version has you tapping into the turn signal wires and having to run the wiring through the floor. (Complete at your own risk) F2GZ-13A576-A Harness from 4-pin to plug behind right rear tire F2GZ-13A576-B Jumper harness from factory plug behind right rear cargo trim panel to trailer light module F2GT-19H378-AB Trailer module (I believe all Ford trailer modules are the same, the only difference is the mounting brackets which you will need to take off anyway). I'm using one from a 2017 Escape. As long as the base part number is 19H378 you should be good. Run a 12awg wire with a 30amp inline fuse from the 12+ side of the battery to the brown/red wire of the trailer module harness In theory, you could instead run the power wire to the fuse box under the driver's side dashboard and use an add-a-fuse. Fuses 29 and 30 are 30amp constant 12v and are not used for anything else in the vehicle (spares). -
My 2018 did not have the drawer so I swapped it with the one from my 2016 before trading it in.
Yes, fuse 78 is there and 12v power is going to it. Since I can't get to the back side of that fuse box, I wonder if there is even a wire connected to it. -
Somehow my local dealer had the jumper harness in stock! I plugged everything in but still no trailer power. I used a test-light and there is no 12v power going into the trailer tow module (brown/red stripe wire). I tried seeing if it needed to be enabled with Forscan but it did not detect that module. My next step is to apply power to the 12v wire of the tow module from the battery to see if it works. Might also need to enable it with Forscan as I have seen screenshots from other vehicles that show a trailer tow module, which is different from the factory trailer brake module in some vehicles. -
So I'm in the process of obtaining all the necessary parts to add the factory hitch to my '18 Sport. So far I have the hitch (used), the split liftgate sensors and the 4-way harness that plugs into the empty spot behind the passenger side tire. There is an unused plug behind the panel inside the luggage compartment which I believe is used for the trailer tow module. However, it requires a jumper harness to go from the single plug of the vehicle, to the three plugs on the module. It's part number F2GZ-13A576-B, which is on national backorder. As far as needing to enable the trailer tow module, it's not required. The F150's get the trailer brake module enabled, since the Edge does not have trailer brake capability it only has the lighting module. -
Have the dealer perform TSB 18-2339. It states to install new lower door weatherstripping and mini mudflaps behind the front tires. This is the exact issue for this TSB.
The monthly price difference between a FWD and AWD will usually only be a few dollars as the residual value will be more on the AWD version. Plus you don''t have to pay the full cost of the AWD option, just the residual portion.
Only if you have access to Ford's internal site.
- 15 replies
- build date
- 400a
I see the '19 ST has a digital boost gauge in the left side of the cluster. Anyone have an idea on how to enable it on 2015+ Sport models using Forscan?
Because the dealer ORDERS it SPECIALLY for a customer that wants it a certain way. It's not rocket surgery.
Where exactly does it say the engine shuts off when decelerating? Cutting the fuel off is not the same as turning the engine off.
Because that would have added even more cost to the ST, not only in parts alone but also engineering and testing cost. On a trim level with very small per year sales it just didn't make sense. The ST is already a 50K vehicle which puts it at the limit of what people are willing to pay for a two-row Ford SUV. Plus it's dangerously close to the price of a nicely equipped Nautilus.
Reading individual tire pressure only became available on the 2015+ Edge models. The capability is with the sensors themselves, not the module reading them. Older systems did not have that capability and using a bluetooth adapter is not giving accurate data as it's relying on wheel speed sensor data from the ODB port to "guess" the tire pressure.
Uhh, Continental does more than just make tires. They also make PCM's and other modules.
The 21" wheels are made in Mexico by Prime Wheel.
Just a wheel change does not require an alignment, even changing wheel sizes. Do the new ones come with TPMS sensors?
