I believe that fog lamps are an option on the SE. If you don't mind not having the original fog lamp switch, it's pretty easy. The only difference between the two models are that one has a black out plastic cover and the other has a chromed plastic insert with the lamp assembly. The fascia is identical in both. Both the black out and the chrome insert fit the exact same way. One can be taken out and the other put in it's place. There is a left and a right insert, the lamps are identical. The fascias or bumpers "call them what you want" come from the supplier complete with black out or fog lamps installed. So now it's a question of wiring the lamps. I don't know if your vehicle has the original wiring ready to receive the fog lamps. If not you will need two male connectors for the lamps "one for each". I hope that I have been a help.
