awake33
Everything posted by awake33
2010 Edge Radio Shuts Off Unexpectedly
awake33 replied to smiged21's topic in Audio, Backup, Navigation & SYNC
I've had this happen a few times over two years. Totally random, smooth driving, slow or fast it didn't seem to matter. Chalk it up to the random computer or integrated circuit glitch. I work in IT and see it all the time. Simple devices behaving as though they are possessed lol. -
While it is entirely possible. I'm sure they can tell the difference between a sound emanating from the front vs the rear. But, more importantly, this is a well known issue with the fuel pumps and thus it is far more likely that that is the culprit. My Edge does it too, noticed it from day one, drives me nuts. The cabin fan did start to whine a bit when I hit 20k miles though. Now I have whining from both ends lol.
Stay Away from Retro-solutions HID !
awake33 replied to BlazedUp's topic in Interior, A.C., Heat, Interior Trim
Sorry to hear that. I've been using mine for 1.5 years without relays with no problems. S**t happens, doesn't mean the kit is cheap or guaranteed to cause problems. -
No issues here with remote start, not a Ford OEM kit though. The information given by the seller regarding LEDs is correct, my map lamps slightly glow while off too. Not sure how a lamp being on or off would make the car/starter think a door is open. If that were the case, then just turning on a light could defeat the starter lol.
Re-Programming Edge for Differant things...
awake33 replied to modette99's topic in Interior, A.C., Heat, Interior Trim
Someone this obviously (and self described) lazy shouldn't bother wearing a seatbelt. -
Continuing issue with HID lights (retro)
I did the same thing for the same reason, and also because sometimes the passenger light wouldn't come on after starting the car. It's a really bad idea to have them come on when unlocking, barely get fully charged up, then turn off for 2-3 seconds and come right back on. I do not have a relay or cap, ballasts are plugged directly into the OEM harness. -
He asked what and why. I've heard of these, but would also like to know why they are a good choice.
Successful aftermarket remote start install
awake33 replied to awake33's topic in Interior, A.C., Heat, Interior Trim
Are you using the D2D cable to connect the bypass and remote start together? You only need to connect bypass harness pins 2 (Green), 7 (Pink), 8 (Orange) to the car PATS harness pins 3 (Violet/gray), 4 (yellow/orange), 1 (Blue/brown) respectively. I had to use a relay for the parking lights, the ford system draws more than 10 amps (potentially). I would like to hook up rear defrost and the heated seats, but couldn't narrow down which wires in the car were needed. It took a few tries to program the bypass, and then my car wouldn't start either lol, sorry I don't recall what it was that I overlooked at the time. Just double check all your connections from the beginning and try again. Also, what does the diagnostic LED say? It flashes a code to help you narrow down failed starts. -
Yep, the top steering column cover removal was actually the hardest part. It felt like it was going to break, in fact I think I did break one tab. No matter how hard you squeeze all the tabs just don't want to let go at the same time. I prefer a clean install and one that, extenuating circumstances aside, will never fail. So soldering directly to the connectors was the way to go. If you're comfortable with it, everything can be done at the kick panel. There were a few wires for the PATS that I stripped in the middle without cutting and heat-shrink tube was used on all connections for insulation and limiting movement when adjusting the steering tilt/depth. I put zip-ties through the ignition connectors and pinned the ends under my feet to serve as a third hand while soldering and keep solder from flowing into the opening. -
No idea on the '07 wires. This is the bypass kit and where I ordered it: Dei PKFM Kit Remote start diagram: As you can see, the majority of the wires are not even used. I removed all unused wires from the molex connectors completely so they are not in the way. Xpresskit notes: I temporarily removed the ignition wires from the Edge's connector and soldered the remote start wires directly to the end OEM clips. Be careful if you choose this method as solder can pool up inside the clip and prevent you from being able to plug it back in, but it can be removed with some solder wick. -
The rest of us are talking about a whine that is present when the vehicle is not in motion.
What lighting (headlamps, interior, turn signals, etc.)? What is the symptom? I have a manual I'll look at if you can provide this info.
I've only managed to get the light to flicker a couple times while driving very aggressively in the snow.
HID XENON Headlight for Edge!
awake33 replied to fly6's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Ah, thanks for clearing that up. -
Just curious, what are 'bow' issues? I have a set installed for low beams. Is there any point to doing high beams? Most of the time I have to turn them on and off quite a bit due to oncoming traffic. Not good for the ballasts and often times, they wouldn't even have time to charge up to full brightness. How does one get around that? -
Automatic Door Locks
awake33 replied to Davy49's topic in Alarms, Keyless Entry, Locks & Remote Start
You don't need anything at all to break a car window, you can just punch it out if you want to, I've done it. Of course there are varying degrees to everything, but every little bit helps. The more layers of deterrents you have the better. Based on your logic, we should not lock our doors at home either, because they can just break the window, so why bother. The guy never said it was 'hard' to lock them manually either. He asked a legitimate question, ease up on the guy. -
This mirror does not have the ability to work with Sync as far as I can tell. That's pretty nifty there securinu. But I have to assume that you own the store. You have posted here and there on this forum, sometimes eluding to some interesting information that you don't ever divulge. You also have never replied to any of my PMs asking for an explanation. You have only mentioned that you run an install business of some kind. Provide some real information, not just links. Don't don't hold your breath while waiting for me to buy from you.
Wrong thread, lol.
Looks great! I was considering that grill, how hard was it to install?
Have not installed that model, but I did use the wiring instructions from it and the Ford wiring diagram book to help me install a Python Responder One with a Dei PKFM XpressKit SoleX Platform PATS Transponder unit. Was way easier than I thought it would be, at least compared to years ago. 11 wires in all to the vehicle. I soldered all connections without cutting any vehicle wiring using a method similar to that outlined for the Ford 9G1Z-19G364-A. The hardest part was getting the steering column apart without breaking it. Since I soldered and took my time making everything perfect, it took about 6 hours total. Soldering joints like this by yourself is a real pain. The PATS bypass unit was easy to install too. Didn't have any programming issues and the range is great, especially for such a tiny remote. I highly recommend one of these over the Ford unit. It's the smallest 2-way long range remote start unit there is, smaller that the Edge key fob with the built-in key. Total cost was about $185, got both units from eBay.
eBay http://cgi.ebay.com/ebaymotors/ws/eBayISAP...K%3AMEWAX%3AVRI Bidding has ended, but they re-list the item repeatedly.
Is it already painted? You can pick these up for $615 shipped +$600 for matching OEM paint.
PLEASE HELP! HID QUESTION
awake33 replied to deepimpact00's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Are you ballasts digital? I have an HID kit installed and did not need to use relays. Everything works fine for over a year now.
