IWRBB
Everything posted by IWRBB
Big time swirls in black paint ?
IWRBB replied to John Rom's topic in Appearance - Detailing, Wash & Wax
Gonna be a lot easier to do it all with a machine, but doing it by hand is a good workout. Glad you are getting it cleaned up. -
I use this type since it's so compact. It's only USB 2.0, but I only have to fill it up once. It has a light too. https://www.amazon.com/gp/product/B00812F7O8/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
I use these to keep the terminals in good shape. Lifetime supply. https://smile.amazon.com/NOCO-B603S-Corrosion-Terminal-Protectors/dp/B004QCBLJC
Its the only active Ford Edge forum that I've found. Welcome aboard.
Yea, doing it by hand is going to be impossible. You need a random orbit polisher with a good foam cutting pad and mid/agressive polish to get the swirls out. Then work you way up to a light cutting pad/polish, then a wax. I agree you don't need to use "compund" - that's too agressive IMO. If you go by hand, or don't use a heavy enough cutting pad/polish, you'll never get it done. You can do it yourself, no problem. Just go one panel at a time. -
My 2015 SHO had 3 of the 4 wheel bearings replaced at less than 40K miles.
Tempered glass just fails sometimes. Usually shatters completely though.
People drive cars to a million miles. 100K is nothing.
2016 Edge Rear Window Exploded
IWRBB replied to Tango's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Unless it's something physically hitting/rubbing the edge of the glass pane that they are correcting (which I doubt), I'd guess they limit the voltage/current to the rear window defroster to slow down the thermal change rate. -
My wife would point out that Ford hasn't had a purple color on anything since 2008. Dark Amethyst Metallic I believe it was. 2008 models are all high mileage and used up at this point, so my wife is still waiting for Ford to sell something with a similar dark purple color. Not big on the grey primer looking Leadfoot paint on the truck. Seems so just- massively blah. Only thing I'd think is more blah is harvest gold trucks.
Jack points and jack stand placements?
IWRBB replied to Vortechtral's topic in Brakes, Chassis & Suspension
Criss cross allow the tire to spin the other way and the scalloping that happens at the front edge of the tread block gets corrected better if it spends 15,000 miles rolling the the opposite direction. If keeping them on the same side works for you though- then keep on keeping on. -
Porsches and BWMs must drive you crazy...
There is a separate hole cast in the AWD trans for the shaft feeding the PTO. You'd have to somehow plug that.
Finally did our 2010 Fusion yesterday. It's over for us now at least.
It's tempered glass- it just shatters sometimes. Our glass top table shattered for no reason, as did one of my co-workers. I've heard of shower doors shattering when no one was home. F150 rear windows shatter on a regular basis. Get it covered under your insurance glass coverage and move on. -
What kind of fire extinguisher should I have in case of engine fire?
IWRBB replied to neoweb's topic in Mods & Tech
They way things go with lawyers today- no way I'm dispensing my fire extinguisher on someone else's car to save yet another person's property. Call the fire department. "Your honor, we maintain the fire extinguisher blast pushed the oil ONTO the building, therefore accelerating the fire and eliminating any chance of the fire department being able to save the building. Had the reckless actions of the defendant not occurred, our national historic landmark that is cherished by every person in a 500 miles radius, would still be intact." No thanks. -
Still rolling in the rental we've had for our Fusion since June. 5+ months so far.
MS-CAN access is good for troubleshooting anything on that bus though. You will be able to datalog it and see it in real time. You might as well get a wired one with a switch. That is the most reliable way (wired) and you have access to everything possible with the switch for both busses.
You have to buy an OBDII adapter than has a USB connection. $40 or so. Hook that up to a laptop with Forscan installed with an "extended license". You get that from their forums- it's free. Once you are connected, all the modules in the vehicle show up in Forscan. You can go into each module and see what "values" are set for each line of "code". You will need to know what the current APIM has for values- so hook it up before you replace it and see if you can download the valvues (Forscan allows you to save one or all lines/vavlues in a file). If not- I believe you can still get all of the as-built values for your vehicle online from Ford. I know you used to be able to do it dince I downloade them for my truck, but Ford may have pulled that down. Not sure. I think it came form the ETIS site. Anyways, install the new APIM and enter the correct as-built values using Forscan and you should be good to go.
[rant warning] ST options in Canada. WTF are you thinking, Ford?
IWRBB replied to ben senise's topic in Edge ST
There is no free lunch when it comes to brake compounds. -
You can replace it yourself by programming the replacement APIM with your Edge's original as-built values using a program called Forscan. Frod might say the APIM is "dealer-serviceable only", but it's really not if you know how to use Forscan.
Pad compounds. A compound that is designed for heavy braking loads on a high horsepower, heavy vehicle will not perform well in sub-zero temps. It's all a trade off. A pad that does well when it's -30F will not take abuse on a road course in the summer very well. Since the magazines will all take it to a track to test it- they cannot use a pad that would get smoked. -
From NTHSA site: https://www-odi.nhtsa.dot.gov/recalls/recallproblems.cfm "Each notification letter must contain the following information:describe the defect or noncompliance; the risk or hazard posed by the problem, including any warning of the problem; a brief description of the free remedy, including when the remedy will be available and how long the repair will take; and a description of what the owner can do if the owner is unable to have the problem corrected within a reasonable time and without charge. Remedy without charge means the repair, replacement, or repurchase of the vehicle or item of equipment that will correct the safety defect or noncompliance. The manufacturer initially decides what the remedy will be, but it may be changed if it is not effective. Owners should have the recall work completed as soon as possible. Recalls involving tires are specifically limited in the Safety Act such that the owner must have the recall work completed within 60 days of receiving notification that it must be done. All other safety recalls are in effect for the life of the product."
