IWRBB
    5
About IWRBB
3,209 profile views
  1. I change the oil in all my cars every 5000 miles. Time does not matter to me.
  2. So we sold the ST. After the engine was replaced- the problems started. Things the dealer touched or swapped from engine to engine started to fail. The first was a total limp mode failure on the highway 1 month after we got it back. Crankshaft Position Sensor + Wiring Harness + Tow = $1100 The second was a failure of the high presure fuel line (!). That in my opinion, should be something that never fails. Fuel sprayed all over the engine and another $2400 to fix. Ford acted like they had nothing to do with either failure. Thinking about those two quick failures after the engine swap, along with the ongoing rattling sunshade Ford refused to do anything about, the wipers that sometimes stopped working in the rain (not good at all), and the overall general level of pain it takes to service the ST- I decided to trade it for a 2024 ST Line with the 2.0L instead (poser). It has noticably less power, but it has SO much more room in the engine bay. The Edge ST is *by far* the worst thing I have ever worked on in the last 40 years of servicing my own vehicles. Look at nearly any spot on the engine from the top down and you'll find: turbo air tubes, then vacuum hoses, then metal hard lines carrying oil to/from the turbos, then some electrical, then rubber cooling hoses, then fuel lines, then more electrical harness, then PCV hoses. Maybe after you remove all of that, you might be able to catch a glimpse of the fastener you are after for the sensor you still can't even see without using a mirror. The engine bay is small in general. It's just downright brutal in every aspect. If you Edge ST owners can still get extended warranties, I'd recommend getting one. Flood Ford ESP. Search it up. The hours of labor required to service this vehicle drives the cost of any repairs way up. When I mentioned the level of pain required to service these vehicles, the service writer said "be glad it doesn't have a hybird system slapped on top of all of that." I hope you guys have better luck than we did! I still love all of my other Fords, but our 2019 Edge ST was really bad from a reliabilty standpoint.
  3. Extract and replace is fine IMO. Small shavings don't harm the hardened steel gears. The issue is the oil breaking down and providing no lubrication- which the extract and replace corrects.
  4. Where are you finding this info? It seems impossible to work on anything new-ish without this kind of detail.
  5. Yep, less than a month left. We got it back- seems OK, but after having it for 2 weeks it came back with the added bonus of a door ding. Now we have to get the dealer to acknowledge it was thewir staff that dented it- and get it fixed. This is why I avoid taking my cars to anyone and service them myself whenever possible...
  6. So it was low coolant after all. Turns out coolant was leaking into the cylinders. Needs a replacement engine. Ford is covering a longblock replacement under the 5yr/60K powertrain, which was going to expire in July. Has 40K miles on it. Drive it home and we are waiting for the new engine to come in to get it replaced. It's the first Ford I've ever had trouble with the shortblock, and I've owned quite a few.
  7. Cheked the coolant first thing. Now that it's hot- it's doing the same thing in reverse, kind of. Wife says the A/C get's warm on the highway or at RPMs above 2000. Slow down or drop the RPMs and the A/C goes cold again. It's going to the dealer soon, I have no clue what it's doing.
  8. 2019 ST with around 40K miles. We get no heat at all unless you are above 2000 RPMs. Then it works as normal. I did see a code using Forscan about a coolant pump- but it never turned on the light, it's just stored. I will pull it again and get the number. I also tried the method to recalibate the HVAC system and everything didi what it was supposed to in that process, but nothing changed. I'm about to take it to the dealer, but I thought I'd make a post here first to see if the hive mind has knowledge.
  9. IWRBB
    20150718 210635
    If you want to paint it, you have to disassemble it. You can do plastidip without taking it apart, but Plastidip will never come close to the same look. I've since sold this Edge, but the painted grille held up well. I had a bit of lifting on the bottom lip, but that was my fault for not scuffing the chrome better in that area and getting more paint on it. I thought that edge would be covered when it went back on, but it wasn't. You can see it's still shiny in this pic on the left side down low.
  10. Well, then we have the update prior to the June 2nd update. Still no issues.
  11. We've had the latest update since March and so far no clunks. Nice job Ford. If Ford would only fix the noisy moonroof/shade instead of saying could not duplicate, we'd be good. My wife is taking someone from their dealer around to hear the noise next time.
  12. I always thought it was the rear gate "unlocking" after sensing the key, but I guess now that I think about it there is no true lock on the gate like the doors have.
  13. For anyone reading this in the future, I took the plates off the car and used a hydraulic press to push out the old bearing. It took a LOT of pressure but we did not bend the plates.
  14. I know when people arrive at my house because I can hear V6s and I4s when they pull in the driveway. You can't hear the exhaust, you just "feel" the rumble created of the lack of firing events. Never forget rolling around in a manual trans 1990s Civic with one cylinder out, and 5 people in the car. You could clearly feel each cylinder firing as we took off from a stop on an uphill.
  15. It's fine. A single LCA is capable of handling 100% of the weight of the vehicle, and then some. I mean, you CAN do damage jacking on the wrong control arm at the wrong spot- but assuming he had a clue as to what he was doing, it's not a problem.
