Edgey Guy
Everything posted by Edgey Guy
Driver floor is SOAKING WET
Edgey Guy replied to Blue_Edge15's topic in Interior, A.C., Heat, Interior Trim
No, each dealer was responsible for fixing the cars, and Ford when they bought the cars back, a lot were scrapped and a lot were fixed and sent to the various auctions, but that was 2 years ago. They have all been sold.- 479 replies
- missing floor grommet
- new Ford owner
- (and 3 more)
Call Ford and or talk to the dealer and request a meeting with the Ford District Service Manager. The wire harness runs along the floor of the vehicle and you probably had 3" of water under the carpet/Styrofoam and the water corrodes the connections which ARE NOT water tight. Ford spent millions of dollars repairing these vehicles. Ford set out the procedure REPLACE the Wire Harness for this exact same reason you are talking about. Your vehicle WAS NOT repaired to Ford standards so that falls 100% on the dealer. It is the dealers responsibility to ensure Factory repairs as set forth in a TSB are followed to the letter!- 479 replies
- new Ford owner
- (and 3 more)
They are referring to the ditch seams, channels under the "Black plastic roof trim". I have never seen these clog up.- 479 replies
- new Ford owner
- (and 3 more)
Did you have the TSB preformed for the water leak? Did the dealer do it properly? They are supposed to replace the entire wire harness. You have corrosion in your wires GUARANTEED!!! Make sure they replaced the entire wire harness, dash out, entire interior out....A lot of dealers did not replace the wiring harness the TSB states it has to be replaced.- 479 replies
- new Ford owner
- (and 3 more)
There are NO sunroof/vista Roof/Moon roof drain tubes. It is a gasket/weatherstrip that the glass seals against.- 479 replies
- new Ford owner
- (and 3 more)
Everyone thinks it is an A post...your build date is way out of that problem...- 479 replies
- new Ford owner
- (and 3 more)
How would the dealership check? Rip the car apart and sped hours? NO...Certifying is for safety not for leaks...- 479 replies
- new Ford owner
- (and 3 more)
The electrical component that MUST be replaced if it got wet is under the passenger seat and is a power inverter. Do you even have one of those in your vehicle?- 479 replies
- new Ford owner
- (and 3 more)
Build date 7/9??? It should be 06/15 or 07/15 and the vin should be greater then FBB50000- 479 replies
- new Ford owner
- (and 3 more)
Where are you located? Carpets are available. A dealer can order 1 set per week. An "A" dealer can order 3 sets per week. Inverters are available. What dealer has your car?- 479 replies
- new Ford owner
- (and 3 more)
Work with your service manager and the District Service Manager. You will get more that way. Has yours been fixed yet?- 479 replies
- new Ford owner
- (and 3 more)
Nothing, we saw the leak into June....- 479 replies
- new Ford owner
- (and 3 more)
Yes you are correct there were 200 plus or minus preproduction models made out there...I know of 1 leaker....- 479 replies
- new Ford owner
- (and 3 more)
Hi Supersoaker...I think you misunderstood the post from dpulum...the payment of $600.00 per month id their car payment... the rental car is covered 100% with NO out of pocket money from her.... No one got fired! Can't...unionized. NO issues with the later production Edges or the new MKX- 479 replies
- new Ford owner
- (and 3 more)
NEW NEWS...Today a bulletin was released with times and part numbers and procedures to have all the vehicles repaired. Rumour has it, If bought back the vehicles are going to be repaired then sold at a HUGE discount to 3 rental car companies. The rental companies are aware of the situation and they will be repaired etc...and sold to them at about $25,000.00 each...then when finished the "term they will be scrapped. That is just a rumour from a very good source.- 479 replies
- 2
- new Ford owner
- (and 3 more)
Yes 50,000 or greater. You can se the 17 digit vin it will follow...FBB50000+- 479 replies
- new Ford owner
- (and 3 more)
You can buy an Edge, it just can't be delivered until 15B21 is preformed.- 479 replies
- new Ford owner
- (and 3 more)
Yes, you are right, so am I...It is a delivery hold, that means dealers can sell the cars but NOT deliver them if there is an order or open recall. Once the 15B21 Recall is preformed vehicle hold is off and can be delivered to the consume.- 479 replies
- new Ford owner
- (and 3 more)
- new Ford owner
- (and 3 more)
Agreed...but in life things happen...Ask Toyota or Honda or GM or Bentley or Mercedes...the list goes on for recalled cars etc...- 479 replies
- new Ford owner
- (and 3 more)
I saw it and I believe I even have a copy of it....- 479 replies
- new Ford owner
- (and 3 more)
Ford was working on the issue way before the press came knocking.- 479 replies
- new Ford owner
- (and 3 more)
Canadian customers are getting some bought back as well. Most are being fixed successfully. It is up to the dealer. There are companies out there fixing 1,000's of them successfully. Think about this...all the bought back units will have to be repaired and remediated prior to auction or going to rental agencies at huge discounted prices.- 479 replies
- new Ford owner
- (and 3 more)
Stop Sale Order and repair notice all hit on the same day. It was a Friday in June maybe the 19th???- 479 replies
- new Ford owner
- (and 3 more)
