penman36
Everything posted by penman36
  1. I bought a intelligent key fob on eBay for $50. Before you buy look at the numbers on the inside of the key fob (where the key is) so you know what to look for on eBay. Also note there is one for "remote start" and one for "NO remote start". Again be sure you are buying the correct one. Now here is what I did when I received the intelligent key fob from eBay. How to program a Spare Intelligent 5 Button Access Key For a 2015 Ford Edge (may apply to other models & remotes) You can program a maximum of four intelligent access keys to your vehicle. You must have two previously programmed intelligent access keys inside your vehicle and a new un-programmed intelligent access key (or one bought on eBay) accessible. Make sure the ignition is switched off before beginning this procedure. Make sure all the doors are closed before beginning and that they remain closed throughout the procedure. Carry out all 5 steps within 30 seconds of starting the sequence. Stop and wait for at least one minute before starting again if you carry out any steps out of sequence or made a mistake. Read and understand the entire procedure before you begin. 1. Open the floor console storage compartment lid. 2. With the buttons facing up and the key ring facing the rear, place one of the previously programmed intelligent access keys into the backup tray in the bottom of the console storage. 3. Press and release the Start/Stop button. Wait five seconds then press and release the Start/Stop button again. Remove the intelligent access key. 4. Within 10 seconds, place a second previously programmed intelligent access key in the backup tray then press and release the Start/Stop button. Wait five seconds then press and release the Start/Stop button again. Remove the intelligent access key. 5. Wait five seconds, then place the un-programmed intelligent access key in the backup tray then press and release the Start/Stop button. If programming is successful, the doors will lock. Press the unlock button on the newly programmed key and Check that the remote control operates all functions and your vehicle starts with the new intelligent access key. If programming is not successful, repeat the 5 steps after one minute. Timing is critical, so you may have to repeat the steps a few times. After I programmed the key I set it up as a "My Key" with specific restrictions. So if I loan my car to, say a child or grandchild, I give them the "My Key". Good luck.
