my 2012 edge
About my 2012 edge
1,482 profile views
my 2012 edge's Achievements
  1. Sometimes it chimes after I take the key out. I put the key back in and start car and turn it off and it goes away
  2. I have this code on my 2012 ford edge any ideas thanks
  3. Thanks I'll try and figure it out
  4. I have a 2012 edge just replaced battery two weeks ago. Now I have this code I cleared it and it came back any ideas
  5. When I pressed on the brake it would go straight to the floor
  6. I had a very soft pedal. I changed master cylinder and bleed brakes it's better but not good. My son come over with scanner a day code COO2O-13 came on any one familiar with this
  7. Battery died thus morning. My mechanic said its the alternator
  8. I don't have any aftermarket things except remote start
  9. Yes it was acting up the battery died it was 3 years old. Hiw do you rest the bms? Is locking the vehicle overnight enough?
  10. I get this warning when I start my 2012 edge. It goes away after I start driving. I put a new serpentine belt on and a brand new battery. Auto zone says the alt. Is good. When I drive the car I use the torque app to check batt voltage and it is usually 14 volts. Any idea why I keep getting this warning thanks
  11. Sorry for the confusion. I changed the pvc valve also at the same time as the front valve cover.. after I did that the smell was there one more time.then I cleaned out the tube that connects to the throttle body and it never happened again. Pretty simple job changing valve cover
