testedone
About testedone
testedone's Achievements
  1. OK, thanks for the clarification.. Been awhile since I dove either AWD or FWD, mine is a 2013 AWD
  2. I think I know the answer and it may be normal... This is my first AWD vehicle and it seems when I am at a stop or say doing parking maneuvers the steering is a little tougher.. Is this normal with AWD.. Feels lie when I have my Jeep in 4WD High... Thanks for any help...
  3. Dealer programmed both fobs and enabled remote start.. Good to go..
  4. If you read my original post I have tried that. The only response is the horn beeps. Other places I have read (F150) sate that this indicates you have a setting only accessible through the IDS tool that allows extra remotes or limits the number
  5. I asked this in another thread but thought it might have got lost in the mix somewhere so starting a new thread.. 2013 SEL I have both my original keys and have programmed my new keys (2) to the point they will start the car. I get a message on the display after programming that states "unable to program integrated key" and none of the remote FOB features work. I have tried the on and off 8 times method and all it does when I press any button on the new remotes is sound the horn.. Any ideas before I go to the stealer?
  6. got my keys cut at Lowes..for free Tried all the programming methods in this thread and the keys will not program. I followed the procedure and they are able to start the car but I get a message that sates unable to program the keys. When I use the cylce 8 times and I press a button on the new remotes the horn sounds.. only thing I can think of is this from the directions NOTE: This procedure works only if the customer spare key programming is enabled. If customer spare key programming is disabled, refer to Key Programming — Enable/Disable Spare Key or Key Programming Using Diagnostic Equipment in the workshop
  7. OK so got my parts today.. I am confused. I looked at the thread you spoke to get the panel off http://www.fordedgeforum.com/topic/8434-2011-ford-edge-200-series-remote-start-diy-bb5z-19g364-c/ And they show anther module being installed with some little blue antenna also... This is all I have in my kit.. Do I need another module?? http://www.ebay.com/itm/11-thru-14-F-150-OEM-Genuine-Ford-Remote-Starter-Kit-Plug-N-Play-RPO-NEW-/181322577281?hash=item2a37aaf581&vxp=mtr
  8. Well the remote start module is on the way, I have installed the hood switch. I have called a few dealers and they all want $100.00 to activate the remote start option.
  9. I like $155.00 Cheaper Those 2 links say they are not compatible with a 2013 Edge
  10. Is this the right kit? http://www.ebay.com/itm/NEW-OEM-ONE-WAY-REMOTE-START-KIT-2011-2015-FORD-F150-EDGE-F250-F350-F450-F550-SD-/331495947985?fits=Make%3AFord%7CModel%3AEdge&hash=item4d2eb2bed1&vxp=mtr
  11. So I have read that the Ford OEM Rear Bumper Protector is nothing more than a sticker, does anyone know of a better one? Thanks
  12. Got my ford (grill inserts) parts in yesterday and starting the plasti dip process. Did as some have directed through various videos but the final product isn't "smooth as glass" is that normal with plasti dip?
