Frank Drebin
Everything posted by Frank Drebin
May be this? http://www.fordedgeforum.com/topic/18267-titanium-tailgate-and-hill-wont-close/?do=findComment&comment=133557
Rattle drive me crazy! Edge Sport 2015
Frank Drebin replied to Frank Drebin's topic in Brakes, Chassis & Suspension
Exact, remove the bench, unbolt the 2 bolt you see, flip down the rear rest, unbolt the 2 other bolt, move up the rear rest and put the foam under the metal bracket between the bracket (black) ans the tole (white). -
16mm / 4 bolts with a rench -
I did it during the week-end and...it's FIX!! I use foam used under Wood floor. -
Driver seat off vs steering wheel!?
Frank Drebin replied to Frank Drebin's topic in Interior, A.C., Heat, Interior Trim
The peddles are correct BUT...the footrest is too thick for nothing!! It's annoying...Have to rest my left feet on the ground! If I rest my feet on the footrest...after 5-10 minutes, I realize I'm pushing with my left feet (because my left knee is 2 inch higher than my right knee (footrest too thick)) on the floor and creating a back pain. And you?? -
Exact! It's the next thing i'm gonna try -
It's not the problem. The dealer remove the nut and tightened it down correctly. I'm gonna put a layer of foam between the parts and try it again on the road during the week-end -
After a couple month, I sat in an another Edge Sport, Explorer 2016, Taurus 2016, Escape 2016 and every car had a little off steering wheel... I think it's for a proportional space between the door/seat on the driver side and door/seat on the passenger. -
FOUND!! Under the bench of the rear seat, passenger side, left bracket who fix the rest on the floor -
Yes, 2015 Sport awd There's only 1 wire on the driver side under the bench. Easily disconnectable.
2015 Edge Sport - engine shut down while driving
Frank Drebin replied to djrjr's topic in 2.7L EcoBoost
Primo: GO with the lemon law!! Second: "you're not eligible for a rental...WTF are they serious!?! After 10 days !?! -
Finally, having the work done on my Edge. 1- They change both rail for the pano roof ("toc" while opening gone...) SOLVE 2- Rattle under the bench of the rear seat... After searching...didn't found something wrong !!?!?! NOT SOLVE 3- Weird sound over my head (roof? headliner?) while the body structure are under light torsion... NOT SOLVE For #2... I'm testing something else tomorrow For #3... I do not find where (exactly) the sound is coming.... -
Thank!! I'll try tomorrow
I was able to remove mine quickly and easily. Push the front clip (under the bench/front side where the legs rest) on each side. Push the bench (toward the back rest as much as you can) and pull out the rear of the bench (each side separately). I don't ok if it' clear (I'm a french guy)...
This one? (Over my head...driver side...near of the B pillar)
Take a look herehttps://youtu.be/sHs14Yr0NUM
From inside or outside of the vehicle? From the front, middle, rear? Over your head...under your head? Record the sound et post it on youtube with the link
I'm dropping the Edge to my dealer Monday morning (October 5) to fix (I wish) all the trouble... -
Same thing here about: "Vista glass in the rear makes a creak or snapping sound whenever the body flexes" ... !?$@#% -
My dealer took a look one month ago...They didn't find nothing. I have 3 annoying rattle... The back seat!!! From the top near of B pillar https://youtu.be/i9LM1kwmJtA During pano roof opening https://youtu.be/JNCl9w7ng4Y And...since 1 month, at low speed, the pano roof make noise when the surface are not flat (the gap between the street and the sidewalk)... -
THAT fucking sound? http://youtu.be/njUo8tj8-rU Coming from the back seat/passenger side... -
Seat Height??? What's yours?
Frank Drebin replied to FINFAN3DP's topic in Interior, A.C., Heat, Interior Trim
@Djtj... http://www.fordedgeforum.com/topic/18083-driver-seat-off-vs-steering-wheel/?view=getnewpost http://www.fordedgeforum.com/topic/18643-seats-giving-me-a-back-problem/?view=getnewpost -
Nope, already fixed since day 1. It's clearly the back rest of the rear passenger seat (right side)
WTF...your dealer is a idiot! The noise come from the back rest of the back seat (passenger side) for sure. To test it...fold the split 40 (right side) of your back rest. While driving over 60 and hearing noise...push lateraly (toward the door) on the back rest and the noise is suppose to disappear... Try it and give me a feed back. PS: the dealer haven't fix my problem yet. They tried but...they failed.
18 mpg...Sport 2015...40% city / 60% highway... Drive like I stole it ?
